Firmware avec Fabriquant et Modèle Inconnu
Messagepar pihug12 » 13 Oct 2004 18:03
Bonjour tout le monde !!!
J'explique mon problème :
Je souhaiterai mettre le firmware de mon lecteur de DVD à jour.
Seulement je n'arrive pas à obtenir des informations sur le fabriquant te le modèle, je ne sais que ça : ATAPI DVD DUAL 4XMax.
Voici le rapport de Alcohol 120% :
Alcohol 120% a écrit:################## Detailed Information of Device(s) ##################
(F:) ATAPI DVD DUAL 4XMax(1:0) detail information.
Vendor Identification: ATAPI
Product Identification: DVD DUAL 4XMax
Production Revision Level: 2.17
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), TAO, DVD DAO
BURN-Free Technology: BURN-Proof
Auto-Select best write speed: Not Supported
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 01h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: No/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: Yes
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved and Corrected: Yes
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
Maximum Read Speed Supported (with current disc): 40X (6000 Ko/Sec)
Maximum Write Speed Supported (with current Disc): 24X (3600 Ko/Sec)
Current Read Speed Supported (with current Disc): 40X (6000 Ko/Sec)
Current Write Speed Supported (with current Disc): 24X (3600 Ko/Sec)
Merci de m'éclairer !!!
pihug12 :P
pihug12
Messagepar Scaramanga » 13 Oct 2004 18:50
En fesant une recherche sur le firmaware actuel, tu peux en déduire lle modéle.
Pour faire rapide > Par exmple : avec Nero : dans le menu tu fais graveur/choisir le graveur , et dans la fenêtre qui s'ouvre , tu as révision Firmaware : xxxxx
Fait une recherche dans google avec cette info : firmware + "la versionactuelle". Tu connaitra ainsi la marque et le modéle.
8))
Messagepar pihug12 » 13 Oct 2004 19:56
Merci pour cette réponse rapide !!!
J'ai donc un firmware 2.17.
Je dois trouver mon bonheur ici ???
pihug12 :D
pihug12
