Ketta : 3 pour 2 !
Messagepar Lithium » 09 Mar 2010 11:53
Je continue les tests avec les Datawrite Titanium lightscribe
Unique Disc Identifier : [DVD-R:CMC MAG. AM3]
Disc & Book Type : [DVD-R] - [DVD-R]
Manufacturer Name : [CMC Magnetics Corp.]
Manufacturer ID : [CMC MAG. AM3]
Blank Disc Capacity : [2,298,496 Sectors = 4.71 GB (4.38 GiB)]
** INFO : Drive = Optiarc DVD RW AD-7240S - [FW 1.03] - [USB]
** INFO : Write Capabilities = DVD+R DVD+R-DL DVD+RW
** INFO : Write Capabilities = DVD-R DVD-R-DL DVD-RW DVD-RAM
** INFO : Disc = [DVD-R:CMC MAG. AM3]
** INFO : Reference Speed : 1x DVD = 1385 kBps
** INFO : An Writeable Disc Is Recommended For Accurate Results
** INFO : Write Speeds (Supported By This Drive On This Disc) Listed Below
** INFO : GET PERFORMANCE Write Speed Descriptor(s)
Descriptor #1 = 22160 kBps (16.00x) - [CLV/Non-Pure CAV]
Descriptor #2 = 16620 kBps (12.00x) - [CLV/Non-Pure CAV]
Descriptor #3 = 11080 kBps ( 8.00x) - [CLV/Non-Pure CAV]
Descriptor #4 = 8310 kBps ( 6.00x) - [CLV/Non-Pure CAV]
Descriptor #5 = 5540 kBps ( 4.00x) - [CLV/Non-Pure CAV]
** INFO : MODE SENSE Write Speed Descriptor(s) [Legacy Command]
** WARNING : MODE SENSE Is Obsolete And Not Always Properly Supported
Descriptor #1 = 22160 kBps (16.00x) - [Pure CAV]
Descriptor #2 = 16620 kBps (12.00x) - [Pure CAV]
** INFO : Hex Dump Of 'Media Code'-Block Listed Below
** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded
** INFO : Format 0Eh - Pre-Recorded Information In Lead-In
0000 : 01 40 c1 fd 9e d8 52 00 02 84 0d 12 98 99 90 00 .@....R.........
0010 : 03 43 4d 43 20 4d 41 00 04 47 2e 20 41 4d 33 00 .CMC MA..G. AM3.
0020 : 05 88 80 00 00 00 02 00 06 09 0d 14 98 88 90 00 ................
0030 : 07 88 80 00 00 00 00 00 08 07 17 0a 0e 09 04 00 ................
0040 : 09 95 07 0d 0b 88 88 00 0a 80 00 00 00 00 10 00 ................
0050 : 0b 06 17 15 b8 99 85 00 0c b8 9a 32 03 20 32 00 ...........2. 2.
0060 : 0d 00 00 d0 00 00 00 00 ........
** INFO : Hex Dump Of 'Control Data Zone'-Block Listed Below
** INFO : 4-Byte Header Preceding 'CDZ'-Block Discarded
** INFO : Format 10h - Physical Format Information Of Control Data Zone
0000 : 25 0f 02 00 00 03 00 00 00 26 12 7f 00 00 00 00 %........&......
Hub code : MFP665ND17070942 5
Stamper code : CMDR47G-CTMWM02-LS-028 0226
Le disque étant "gravable" à 16x maximum dans ce graveur, j'ai choisi une vitesse de 8x (soyons sympa avec ce média CMC).
J'ai aussi testé l'étiquetage lightscribe, aucun problème à signaler, excellent résultat, bien contrasté en un seul passage avec le iHAS424 en qualité maxi (que de progrès depuis le BenQ DW-1625 !).
Pour ne pas alourdir inutilement le post, je ne fais pas figurer la TRT, aucun problème de lisibilité, TRT "parfaite".
Globalement je trouve que ça va, le prix annonce la couleur, je ne pense pas que ce soient des fake (si Franz a un truc pour reconnaître les vrais cmc ?).
Modifié en dernier par Lithium le 09 Mar 2010 12:30, modifié 2 fois.
- BenQ DW1620
- Lite-on IHAS424 @ iHAS624A
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar Lithium » 09 Mar 2010 11:54
franz99 a écrit:Dans cet ordre d'idées, pourrait-on avoir aussi un scan fait avec un graveur BenQ,
ces graveurs qui ont été et restent des scanneurs de référence ...
Pourquoi pas, je n'ai plus trop confiance dans mon BenQ à ce sujet, mais je rajouterai un scan BenQ aux posts (j'editerai) ;)
- BenQ DW1620
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar franz99 » 09 Mar 2010 13:17
Lithium a écrit:Je continue les tests avec les Datawrite Titanium lightscribe
Je m’excuse, mais ayant déjà assez de mal à distinguer le bon du moins bon à l'intérieur des Taiyo Yuden et des Verbatim, je ne peux pas encore m’intéresser de près à cette jungle des Titanium:
http://www.ketta.com/catalog/advanced_s ... m&x=20&y=0
http://www.nierle2.com/s01.php?suchstr= ... =10&I1.y=5
http://www.dvdshoponline.co.uk/Titanium_DVD.html
http://www.videohelp.com/dvdmedia?dvdme ... List+Media
J'espère que vous comprendrez que lorsqu’on explique de la façon suivante ce qu’est un DVD de nom de code “Titanium”,
le chasseur de MID codes authentiques coule … comme le Titanic !
J’ai même cru pendant un moment le 11 octobre 2009 qu’ils avaient un revêtement en titane
Nom de code “Titanium”, grâce à la force des processus chimiques utilisés , il s’est rapidement retrouvé à l’avant garde du marché des médias optique.
La mise en place du DVD-R 8x en Novembre 2004 a placée la première pierre à l’établissement d’une large gamme de médias optiques qui englobent la qualité, l’excellence et des prix très avantageux.
Grâce au solide effet de sablage en titane et au haut niveau de polycarbonate plastique utilisé, la gamme de médias optiques Titanium garantit moins de 0.00001% de défaut.
Modifié en dernier par franz99 le 09 Mar 2010 17:40, modifié 5 fois.
Messagepar Lithium » 09 Mar 2010 13:51
Là je rigole... moins de 0,00001% de défauts... quand on voit que dans un pack de 50 ou 100 TY ou Verbatim il y a bien souvent un disque dont la gravure foire...
Le polycarbonate de ces Datawrite titanium lightscribe n'a en tout cas pas résisté aux rayures du transport, quand au titane je pense que ça se résume à la couleur (datawrite fait aussi des jaunes, des rouges, etc... il paraît que les rouges sont mieux :o) ?
Enfin, sans parler d'excellence, ce sont des CMC, à mon humble avis pas des fake (les résultats ressemblent à ce qu'on peut avoir avec des CMC Memorex), qualité correcte, sans atteindre des sommets. Je ne sais pas ce que ça vaut niveau conservation en revanche, on dit parfois que les médias CMC sont considérés comme stables (cf cdrfreaks, là encore je ne retrouve pas la discussion), mais je ne sais pas ce qu'il en est...
- BenQ DW1620
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar Lithium » 09 Mar 2010 17:29
Je continue les tests avec les Ridata 8x DVD+R DL :
Unique Disc Identifier : [DVD+R-DL:RITEK-D03-001]
Disc & Book Type : [DVD+R DL] - [DVD+R DL]
Manufacturer Name : [Ritek Corp.]
Manufacturer ID : [RITEK]
Media Type ID : [D03]
Product Revision : [001]
Blank Disc Capacity : [4,173,824 Sectors = 8.55 GB (7.96 GiB)]
Recording Speeds : [2.4x , 3.3x-8x]
** INFO : Format 11h (Method 1) - ADIP Information
0000 : e1 0f 32 10 00 03 00 00 00 fc ff ff 00 22 d7 ff ..2.........."..
0010 : 00 00 03 52 49 54 45 4b 00 00 00 44 30 33 01 40 ...RITEK...D03.@
0020 : 25 25 37 0e 00 10 69 00 10 69 1e 1c 0c 0c 10 10 %%7...i..i......
0030 : 00 00 00 00 00 1e 1c 0c 0c 10 10 00 00 00 00 00 ................
0040 : 04 00 33 7b 5c 00 21 64 1b 20 12 09 08 20 01 00 ..3{\.!d. ... ..
0050 : 00 00 00 4b 64 40 28 1a 0c 0b 20 01 00 00 00 4b ...Kd@(... ....K
0060 : 84 00 00 3c 64 1b 28 1a 0c 0b 20 01 00 00 00 00 ...<d.(... .....
0070 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00a0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00b0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00c0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00d0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00e0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00f0 : 00 00 00 00 00 00 00 00 ........
Hub code : J3-06P08602212283E04 / J6-07D08802070272F16
Stamper code : VR9P08-00093
Le disque étant "gravable" à 8x maximum dans ce graveur, j'ai choisi une vitesse de 8x, une fois n'est pas coutume !
Et puis je les sentais bien, mid code RITEK D003, ça ne sentait pas le fake :D
Encore cette courbe jaune délirante, je ne sais pas d'où vient le bug :?:
8X ZCLV, le graveur a réduit la vitesse à 4x sur la deuxième couche.
TRT : (rien à redire)
Scan lite-on :
Encore une fois pas possible de scanner le jitter plus loin que la première couche (j'en suis à me demander si ça ne vient pas du graveur)
Scan BenQ :
Modifié en dernier par Lithium le 09 Mar 2010 19:37, modifié 1 fois.
- BenQ DW1620
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar franz99 » 09 Mar 2010 17:46
Lithium a écrit:Je continue les tests avec les Ridata 8x DVD+R DL :
Des identifiants montant une fabrication authentique par Ritek
et un surprenant MID code RITEK-D03: on a eu un bon tirage au Loto !
Malheureusement ce pack d'essai de 3 est le seul média de marque Ridata actuellement en vente chez ketta:
http://www.ketta.com/catalog/ridata-m-42.html
Alors que tous les DVD+D DL aux noms voisins: RiDisc, Rivision, ...
sont le plus souvent douteux:
http://forum.gravure-news.com/pb-gravur ... tm?start=7
http://forum.gravure-news.com/rivision- ... t26152.htm
Ce code Ritek-D03 est également vendu sous la marque Philips:
http://www.nierle2.com/fr/article/3718/ ... piece.html
Modifié en dernier par franz99 le 10 Mar 2010 10:09, modifié 4 fois.
Messagepar Lithium » 09 Mar 2010 19:39
Oui, apparemment Ritek vends sous la marque Ridata (parfois ?)
Quoiqu'il en soit, même si c'est mieux que des fake ricoh comme les Elite, ça reste pas génial....s'il n'y a pas de problème de lisibilité, il y a pas mal d'erreur....
En DL, Verbatim (MKM), et à la limite des Ricoh (des vrais)
On ne le dira jamais assez ?
- BenQ DW1620
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar franz99 » 09 Mar 2010 20:05
Lithium a écrit:On ne le dira jamais assez ?
de suivre la recommandation faite pour le double couche par les « perroquets experts »
http://forum.gravure-news.com/gravure-a ... m?start=12
http://forum.gravure-news.com/pb-gravur ... ht=parrots
Messagepar Lithium » 10 Mar 2010 14:41
X-LAYER 8X DL :
Unique Disc Identifier : [DVD+R-DL:RICOHJPN-D01-067]
Disc & Book Type : [DVD+R DL] - [DVD-ROM]
Manufacturer Name : [Ricoh Co. Ltd.]
Manufacturer ID : [RICOHJPN]
Media Type ID : [D01]
Product Revision : [067]
0010 : 00 00 03 52 49 43 4f 48 4a 50 4e 44 30 31 43 40 ...RICOHJPND01C@
0020 : 25 25 37 10 00 2c 6c 00 2c 6c 20 1f 0c 0c 14 14 %%7..,l.,l .....
0030 : 02 01 01 20 00 20 1f 0c 0c 14 14 02 01 01 20 00 ... . ........ .
0040 : 04 00 33 7b 5c 00 25 69 3a 26 1c 0a 0b 20 02 01 ..3{\.%i:&... ..
0050 : 01 00 00 58 62 42 26 1c 0a 0b 20 02 01 01 00 5f ...XbB&... ...._
0060 : 84 00 00 43 66 3e 26 1c 0a 0b 20 02 01 01 00 00 ...Cf>&... .....
Hub code : M4DL+1801031SMS1 0117SFM4......
Stamper code: DL+18011 0179 / DL+18010 0019
Gravure à 6x, et encore ce bug d'affichage...
TRT OK
Scan Lite-on :
Scan BenQ :
Fake définitivement, mais de meilleure qualité que les "Elite" testés précédemment. Le prix est plus élevé aussi... enfin à choisir, je prends les Ridata, au moins on sait à quoi s'attendre...
Modifié en dernier par Lithium le 11 Mar 2010 14:40, modifié 2 fois.
- BenQ DW1620
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar franz99 » 10 Mar 2010 15:20
Lithium a écrit:Fake définitivement, mais de meilleure qualité que les "Elite" testés précédemment. Le prix est plus élevé aussi... enfin à choisir, je prends les Ridata, au moins on sait à quoi s'attendre...
franz99 a écrit:Malheureusement ce pack d'essai de 3 est le seul média de marque Ridata actuellement en vente chez ketta:
Modifié en dernier par franz99 le 10 Mar 2010 15:38, modifié 5 fois.
Messagepar franz99 » 10 Mar 2010 15:32
Sur cdfreaks ici:
http://club.myce.com/f76/fake-ricoh-dvd ... ost2492187
Womi donne les identifiants des « DVD+R DL 8x X-Layer » vendus en spindle de 25
mais non imprimables:
hub code (clear): M4DL+1801022M5S5 0240FM13 0R18 0R18 3 4 091014 18 29
stamper code: DL+18011 0240 FM13 / DL+18010 0022 0505
Pour vos X-layer blancs imprimables avez-vous les mêmes ou quelque chose d’approchant ?
Modifié en dernier par franz99 le 10 Mar 2010 16:05, modifié 1 fois.
Messagepar Lithium » 10 Mar 2010 15:52
Tout à fait :
- BenQ DW1620
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar Lithium » 13 Mar 2010 21:05
Le meilleur pour la fin... de vrais Tayo Yuden :praise:
Unique Disc Identifier : [DVD-R:TYG03]
Manufacturer Name : [Taiyo Yuden Co. Ltd.]
Manufacturer ID : [TYG03]
0000 : 01 40 c1 fd 9e d8 52 00 02 84 0d 11 66 78 90 00 .@....R.....fx..
0010 : 03 54 59 47 30 33 00 00 04 00 00 00 00 00 00 00 .TYG03..........
0020 : 05 a8 82 00 20 00 02 00 06 09 09 15 a9 9a 90 00 .... ...........
0030 : 07 88 80 00 00 00 00 00 08 07 11 0c 10 0b 06 00 ................
0040 : 09 95 07 0d 0b 68 88 00 0a 80 00 00 00 00 10 00 .....h..........
0050 : 0b 08 16 17 96 88 85 00 0c b7 89 33 83 30 33 00 ...........3.03.
0060 : 0d 00 00 d0 00 00 00 00 00 00 ..........
Gravure à 8x :
TRT :
Scan Lite-on :
Je m'attendais à un peu mieux, surtout en fin de disque. Au vu de ce que j'obtiens avec ce même graveur sur des médias JVC de même mid code, disque "moyen", gravure "moyenne" ? Peut être aussi que ces Tayo Yuden font partie de la gamme "value" du contructeur ? Là je laisse la parole aux experts.
Scan BenQ :
Modifié en dernier par Lithium le 14 Mar 2010 16:02, modifié 2 fois.
- BenQ DW1620
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar franz99 » 14 Mar 2010 10:45
Voici une boutique qui indique clairement qu'elle vend des Taiyo Yuden value line:
« DVD-R 4,7 GB TAIYO YUDEN (VALUE LINE) 16x imprimable blanc FS 100 pièces »
http://www.iwonatec.de/product_info.php ... ts_id=2773
Ces value line sont vendus 36,99 € les 100
alors que les mêmes imprimables blanc sont vendus par le même Iwonatec
49,98 € s’il ne s’agit pas de value line:
« DVD-R 4,7 GB TAIYO YUDEN 16x Speed BLANCHE imprimable Encre FS 100 »
http://www.iwonatec.de/product_info.php ... ts_id=1472
Par comparaison ketta vend les siens (value line ou premium ?) au prix intermédiaire de 44,42 € les 100:
« Taiyo Yuden DVD-R 16x Face blanche inprimable - paquet de 100 »
http://www.ketta.com/catalog/taiyo-yude ... rers_id=29
Modifié en dernier par franz99 le 14 Mar 2010 11:53, modifié 11 fois.
Messagepar franz99 » 14 Mar 2010 10:49
Voici les explications que le vendeur Iwonatec donne au sujet de
ce que sont ces fameux « Taiyo Yuden value line »
What is Taiyo Yuden “Value Line” DVD media ?
“Value Line” DVDs are made by Taiyo Yuden but don’t meet their high standards for premium DVDs. Then the manufacturer sells them as “Value Line”
Are Value Line DVDs made in Japan ?
Same as premium Taiyo Yuden DVDs, Value Line DVDs are also made in Japan by Taiyo Yuden
Modifié en dernier par franz99 le 14 Mar 2010 11:34, modifié 2 fois.
Messagepar franz99 » 14 Mar 2010 11:33
Il y a bien longtemps en l'an de grâce 2007
j'ai reporté de cdfreaks ce qui concernait cette "value line" de Taiyo Yuden:
Lire à partir d'ici:
http://forum.gravure-news.com/liste-pos ... m?start=62
Messagepar franz99 » 14 Mar 2010 11:50
Il existait en ce temps-là sur cdfreaks un consensus pour éviter les médias Taiyo Yuden dits « Value Line »
et n’acheter que des DVD de la ligne « Premium »
http://club.cdfreaks.com/f33/ty-media-269579/
koba a écrit:ATM i would stay away from everything that is TY.
For DVDs i would get Verbatims.
Atal a écrit:I guess the general consensus here is to avoid TY at all costs. Buy Verbatim or Mitsui instead.
DrageMester a écrit:There is no such consensus. :disagree:
negritude a écrit:Yep, no consensus, but caution is recommended.
The only definite consensus is to buy Premium instead of Value Line TY.
Right now, in the states, the only place guaranteed to have Premium TY, with no possibility of mixup or confusion, is Rima.com.
There may be similar places recommended in other parts of the world.
Modifié en dernier par franz99 le 14 Mar 2010 19:10, modifié 1 fois.
Messagepar Lithium » 14 Mar 2010 11:56
Bien, je dirais donc qu'il s'agit là d'une gravure "moyenne". Si j'avais eu un pack de 100 de ces dvd, j'aurais envisagé "d'apprendre" à mon graveur à mieux les graver, mais comme je n'en ai que 3...
A propos des tests de gravure de dvd double couche, j'ai tenté de graver un DVD-vidéo d'un taille de 7,5 GB sur un dvd vierge "Elite", mais malheureusement la gravure a échoué au passage à la seconde couche, je n'ai donc pas pu aller plus loin :/
- BenQ DW1620
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar Lithium » 14 Mar 2010 14:10
Un autre test de média de chez Ketta :
(La photo ne correspond pas, j'ai bien reçu des 16x et pas des 8x)
Unique Disc Identifier : [DVD+R:MBIPG101-R05-001]
Disc & Book Type : [DVD+R] - [DVD-ROM]
Manufacturer Name : [Moser Baer India Ltd.]
Manufacturer ID : [MBIPG101]
Media Type ID : [R05]
Blank Disc Capacity : [2,295,104 Sectors = 4.70 GB (4.38 GiB)]
Recording Speeds : [1x-2.4x , 4x , 6x-8x , 6x-16x]
0000 : a1 0f 02 00 00 03 00 00 00 26 05 3f 00 00 00 00 .........&.?....
0010 : 00 00 07 4d 42 49 50 47 31 30 31 52 30 35 01 38 ...MBIPG101R05.8
0020 : 23 54 37 13 02 50 6b 02 8c 63 15 15 0b 0b 08 08 #T7..Pk..c......
0030 : 01 19 1b 0c 0c 0c 0d 01 00 00 00 00 00 00 00 00 ................
0040 : 01 00 38 38 02 28 60 1a 05 2e 23 10 04 1e 1d 01 ..88.(`...#.....
0050 : 00 00 02 28 60 1a 05 2e 23 10 04 1e 1d 01 00 00 ...(`...#.......
0060 : 02 00 54 70 02 2e 62 3c 24 14 0c 0c 01 20 00 00 ..Tp..b<$.... ..
0070 : 00 00 02 3f 66 42 24 14 0c 0c 01 20 00 00 00 2f ...?fB$.... .../
0080 : 03 00 54 df 02 2e 62 3c 24 14 0c 0c 01 20 00 00 ..T...b<$.... ..
0090 : 00 00 02 76 63 58 24 14 0c 0c 01 20 00 00 00 66 ...vcX$.... ...f
Pas de chance, je suis tombé sur du MBI et pas du Daxon comme j'espérais...
Gravure à 12x avec Optiarc AD-7240S
TRT :
Scan Lite-on :
Rien de particulier, j'ai déja vu mieux avec ce mid code, mais la qualité a tendance à varier entre du très bon et du moyen je trouve, selon la marque sous laquelle ils sont vendus.
Ce qui m'inquiète plus, ce sont les zones de PIF étendues... ces médias auraient-ils attendu longtemps dans un entrepôt avant que je ne les achète ?
Scan BenQ :
- BenQ DW1620
- Optiarc AD-7241S
Lithium
Membre prometteur
Membre prometteur
Messagepar franz99 » 14 Mar 2010 18:57
Ce que l'on peut trouver sous la marque Pleomax peut beaucoup varier en origine de fabrication et en qualité:
http://forum.gravure-news.com/pleomax-d ... t27152.htm
Et sous ce MID code MBIPG101-R05 du format DVD+R, on retrouve vraiment énormément de marques:
http://www.nierle2.com/s01.php?suchstr= ... hstrprice=
Et sur le site de vente ketta on indique [nous sommes le 13 mars 2010]
pour ces « Samsung 16x DVD+R (paquet de 25) »
le MID code MCC-004 ! !
http://www.ketta.com/catalog/samsung-16 ... -1876.html
Information Technique:
Media Code: MCC 004
