Pb conversion fichiers MKV
Messagepar couleurs78 » 05 Juil 2007 20:56
Problème de conversion avec des fichiers MKV Audio: mpeg4aac, 48000 Hz, mono : Error while decoding stream #0.0
Ci joint fichier log
Code: Tout sélectionner
04/07/2007 21:36:54   information   --------------Encoding end--------------
04/07/2007 21:36:53   information   Echec de la conversion en 00:00:35
04/07/2007 21:36:53   information   User cancellation requested
04/07/2007 21:36:52   Avertissement   Error while decoding stream #0.0
04/07/2007 21:36:49   Avertissement   Error while decoding stream #0.0
04/07/2007 21:36:46   Avertissement   Error while decoding stream #0.0
04/07/2007 21:36:42   Avertissement   Error while decoding stream #0.0
04/07/2007 21:36:39   Avertissement   Error while decoding stream #0.0
04/07/2007 21:36:17   information   Stream #2 Sync. delay : 0,00 ms
04/07/2007 21:36:17   information   Stream #1 Sync. delay : 0,00 ms
04/07/2007 21:36:17   information   Stream #0 Sync. delay : 0,00 ms
04/07/2007 21:36:17   information   Output Stream#2 - Audio: ac3, 48000 Hz, mono, 192 kb/s, Automatic gain control 5,0 dB
04/07/2007 21:36:17   information   Output Stream#1 - Audio: ac3, 48000 Hz, mono, 192 kb/s, Automatic gain control 5,0 dB
04/07/2007 21:36:17   information   Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=1-31, 3170 kb/s
04/07/2007 21:36:17   information   Video Stream #0 framerate : 25,00 Fps (source 25,00 Fps), no pulldown
04/07/2007 21:36:17   information   Image processing: Fast bilinear resampler (512*288)->(720*576)
04/07/2007 21:36:17   information   Image processing: Deinterleave (512*288)
04/07/2007 21:36:17   information   No pulldown: Frame duplication/removal will be used.
04/07/2007 21:36:17   information   Video source original frame rate: 25,00
04/07/2007 21:36:17   information   Output resolution: FULL D1 [720*576]
04/07/2007 21:36:17   information   PAL 25 FPS output format set by user
04/07/2007 21:36:17   information   Widescreen (16:9) set automatically
04/07/2007 21:36:17   information   Bitrate vidéo 0/3170/8616 Kbps (min/avg/max)
04/07/2007 21:36:17   information   Conversion "H:\Dvd\Séries Télévisées\Prison Break saison 1\Prison Break S01E01.mkv"
04/07/2007 21:36:17   information   ----------------Titre #1----------------
04/07/2007 21:36:17   information   Taille du projet 4,3 Gb. (471 Mb. audio - 3,82 Gb. vidéo)
04/07/2007 21:36:17   information   Stream #2 - Audio: mpeg4aac, 48000 Hz, mono
04/07/2007 21:36:17   information   Stream #1 - Audio: mpeg4aac, 48000 Hz, mono
04/07/2007 21:36:17   information   Stream #0 - Video: h264, yuv420p, 512x288
04/07/2007 21:36:17   information   3 Stream(s) found - est. duration 00:42:14.102
04/07/2007 21:36:17   information   Opening file "H:\Dvd\Séries Télévisées\Prison Break saison 1\Prison Break S01E04.mkv"
04/07/2007 21:36:17   information   3 Stream(s) found - est. duration 00:42:11.115
04/07/2007 21:36:17   information   Opening file "H:\Dvd\Séries Télévisées\Prison Break saison 1\Prison Break S01E03.mkv"
04/07/2007 21:36:17   information   3 Stream(s) found - est. duration 00:42:19.648
04/07/2007 21:36:17   information   Opening file "H:\Dvd\Séries Télévisées\Prison Break saison 1\Prison Break S01E02.mkv"
04/07/2007 21:36:17   information   3 Stream(s) found - est. duration 00:41:52.342
04/07/2007 21:36:17   information   Opening file "H:\Dvd\Séries Télévisées\Prison Break saison 1\Prison Break S01E01.mkv"
04/07/2007 21:36:14   information   [ ] Ne pas réparer les "trous" dans l'audio
04/07/2007 21:36:14   information   [ ] Engine Log
04/07/2007 21:36:14   information   Qualité de l'encodeur: 100%
04/07/2007 21:36:14   information   --------------Encoding begin--------------
04/07/2007 21:36:14   information   --------------Menu settings end--------------
04/07/2007 21:36:14   information   [ ] Lecture séquentielle
04/07/2007 21:36:14   information   [ ] Jouer en boucle
04/07/2007 21:36:14   information   [ ] Démarrer automatiquement la lecture
04/07/2007 21:36:14   information   [X] Menu
04/07/2007 21:36:14   information   --------------Menu settings begin--------------
04/07/2007 21:36:14   information   --------------Default burn settings end--------------
04/07/2007 21:36:14   information   Default speed selected: Max
04/07/2007 21:36:14   information    Compatible media types : DVD-R, DVD-RW Seq., DVD+R, DVD+RW, CD-R, CD-RW
04/07/2007 21:36:14   information    New Drive selected : 1:1:0 - PHILIPS DVDR824P P2.2 [G] (Ide)
04/07/2007 21:36:14   information   [ ] Delete files after burn complete
04/07/2007 21:36:14   information   [ ] Don't eject after burn complete
04/07/2007 21:36:14   information   [ ] Prefer SAO for DVD-R
04/07/2007 21:36:14   information   [ ] Include originals
04/07/2007 21:36:14   information   [ ] Burn result to DVD
04/07/2007 21:36:14   information   --------------Default burn settings begin--------------
04/07/2007 21:35:19   information   User default language : 1036 (0x040Ch) - French (Standard)
04/07/2007 21:35:19   information   System default language : 1036 (0x040Ch) - French (Standard)
04/07/2007 21:35:19   information   Version 2.2.3.258
04/07/2007 21:35:19   information   ExeName : "C:\Program Files\VSO\ConvertXtoDVD\ConvertXtoDvd.exe"
04/07/2007 21:35:19   information   OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
04/07/2007 21:35:19   information   ******************** Report session started ********************
J'ai oublié de préciser, c'est avec la dernière version (2.2.3.258) de ConvertXToDvd
couleurs78
Messagepar cougar_ii » 05 Juil 2007 23:52
Habituellement, je t'aurais dit de communiquer avec
lionel(at) vso-software.fr pour lui offrir une copie d'un des fichiers, ce que tu peux faire pareil.
Mais VSO travaille fort sur ConvertXtoDVD v3.00 alors il est possible que la résolution de ce problème peux prendre un peu plus de temps qu'a la normale.
J'ai ouvert un bug officiel:
http://bugs.vso-software.fr/view.php?id=1006
cougar_ii
[VSO] Client En Or
Messagepar couleurs78 » 06 Juil 2007 9:20
Salut Cougar
Merci pour ta réponse et pour l'ouverture du Bug Officiel.
Ce n'est pas bloquant, je laisse les programmeurs travailler sur la nouvelle version de ConvertXtoDvd
couleurs78
Messagepar cougar_ii » 06 Juil 2007 18:26
Voici un petit appercu des menus qui seront disponible dans ConvertXtoDVD v3.00
http://www.youtube.com/watch?v=EY5CAka2Rrg
Wow, ça va être pas mal "Cool" et bye bye la compétition :lol:
cougar_ii
[VSO] Client En Or
Messagepar couleurs78 » 07 Juil 2007 0:10
Salut
Je viens de visonner la démo : quel changement !
Vraiment super les menus
:praise: :clap2: les programmeurs
couleurs78
