Problème avec convertxtodvd
Messagepar Nichockeyfan » 07 Juin 2006 4:54
Bonjour, je débute avec convertxtodvd et je n'ai jamais réussi à convertir des fichiers car j'ai toujours un message d'erreur à la fin de la convertion je vais copier ici mon log avec le message d'erreur que je peux rencontrer. Merci de m'aider si vous le pouvez.
Code: Tout sélectionner
2006-06-06 07:28:55 information --------------Encoding end--------------
2006-06-06 07:28:55 information Conversion échouée en 10:10:44
2006-06-06 07:28:55 Erreur Exception raised in conversion Thread with message "Assertion failure (C:\Workplace\IFO\U_Subtitles.pas, line 1076)"
2006-06-06 07:28:47 information ------------Converting Menu--------------
2006-06-06 07:18:08 information Chapter #8 start at 34:59.630
2006-06-06 07:04:28 information Chapter #7 start at 29:59.614
2006-06-06 06:51:04 information Chapter #6 start at 24:59.631
2006-06-06 06:37:29 information Chapter #5 start at 19:59.615
2006-06-06 06:24:02 information Chapter #4 start at 14:59.615
2006-06-06 06:10:41 information Chapter #3 start at 9:59.615
2006-06-06 05:57:12 information Chapter #2 start at 4:59.615
2006-06-06 05:44:05 Avertissement Audio discrepancy in input stream at 120,00 ms: 120,00 ms of audio missing
2006-06-06 05:44:05 information Stream #1 Sync. delay : 0,00 ms
2006-06-06 05:44:05 information Stream #0 Sync. delay : 0,00 ms
2006-06-06 05:44:05 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
2006-06-06 05:44:05 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x480, q=2-31, 3731 kb/s
2006-06-06 05:44:05 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2006-06-06 05:44:01 information Video source original frame rate: 25,00
2006-06-06 05:44:01 information NTSC 29.97 FPS output format set by user
2006-06-06 05:44:01 information Fullscreen (4:3) set by user
2006-06-06 05:44:01 information Bitrate vidéo 0/3731/8308 Kbps (min/avg/max)
2006-06-06 05:44:01 information Conversion "C:\Mes documents\Nicolas\films\Game.One.-.Big.Show.-.E3-.25.05.2006.avi"
2006-06-06 05:44:00 information ----------------Title #4----------------
2006-06-06 05:30:40 information Chapter #8 start at 34:59.630
2006-06-06 05:17:25 information Chapter #7 start at 29:59.614
2006-06-06 05:03:48 information Chapter #6 start at 24:59.631
2006-06-06 04:50:27 information Chapter #5 start at 19:59.631
2006-06-06 04:37:07 information Chapter #4 start at 14:59.615
2006-06-06 04:24:02 information Chapter #3 start at 9:59.632
2006-06-06 04:10:51 information Chapter #2 start at 4:59.632
2006-06-06 03:57:50 information Stream #1 Sync. delay : 0,00 ms
2006-06-06 03:57:49 information Stream #0 Sync. delay : 0,00 ms
2006-06-06 03:57:49 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
2006-06-06 03:57:49 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x480, q=2-31, 3665 kb/s
2006-06-06 03:57:49 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2006-06-06 03:57:45 information Video source original frame rate: 25,00
2006-06-06 03:57:45 information NTSC 29.97 FPS output format set by user
2006-06-06 03:57:45 information Fullscreen (4:3) set by user
2006-06-06 03:57:45 information Bitrate vidéo 0/3665/8308 Kbps (min/avg/max)
2006-06-06 03:57:45 information Conversion "C:\Mes documents\Nicolas\films\Game.One.-.Big.Show.-.E3-.24.05.2006.avi"
2006-06-06 03:57:44 information ----------------Title #3----------------
2006-06-06 03:33:37 information Chapter #8 start at 34:59.614
2006-06-06 03:07:38 information Chapter #7 start at 29:59.631
2006-06-06 02:43:24 information Chapter #6 start at 24:59.631
2006-06-06 02:19:05 information Chapter #5 start at 19:59.631
2006-06-06 01:54:18 information Chapter #4 start at 14:59.632
2006-06-06 01:28:37 information Chapter #3 start at 9:59.615
2006-06-06 01:03:01 information Chapter #2 start at 4:59.632
2006-06-06 00:40:28 information Stream #1 Sync. delay : 0,00 ms
2006-06-06 00:40:28 information Stream #0 Sync. delay : 0,00 ms
2006-06-06 00:40:28 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
2006-06-06 00:40:28 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x480, q=2-31, 3561 kb/s
2006-06-06 00:40:28 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2006-06-06 00:40:23 information Video source original frame rate: 25,00
2006-06-06 00:40:23 information NTSC 29.97 FPS output format set by user
2006-06-06 00:40:23 information Fullscreen (4:3) set by user
2006-06-06 00:40:23 information Bitrate vidéo 0/3561/8308 Kbps (min/avg/max)
2006-06-06 00:40:23 information Conversion "C:\Mes documents\Nicolas\films\Game.One.-.Big.Show.-.E3-.23.05.2006.avi"
2006-06-06 00:40:23 information ----------------Title #2----------------
2006-06-06 00:14:37 information Chapter #8 start at 34:59.630
2006-06-05 23:50:19 information Chapter #7 start at 29:59.614
2006-06-05 23:25:21 information Chapter #6 start at 24:59.631
2006-06-05 22:59:32 information Chapter #5 start at 19:59.631
2006-06-05 22:29:21 information Chapter #4 start at 14:59.632
2006-06-05 22:05:01 information Chapter #3 start at 9:59.632
2006-06-05 21:41:48 information Chapter #2 start at 4:59.632
2006-06-05 21:18:12 information Stream #1 Sync. delay : 0,00 ms
2006-06-05 21:18:12 information Stream #0 Sync. delay : 0,00 ms
2006-06-05 21:18:12 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
2006-06-05 21:18:12 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x480, q=2-31, 3541 kb/s
2006-06-05 21:18:12 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2006-06-05 21:18:10 information Video source original frame rate: 25,00
2006-06-05 21:18:10 information NTSC 29.97 FPS output format set by user
2006-06-05 21:18:10 information Fullscreen (4:3) set by user
2006-06-05 21:18:10 information Bitrate vidéo 0/3541/8308 Kbps (min/avg/max)
2006-06-05 21:18:10 information Conversion "C:\Mes documents\Nicolas\films\Game.One.-.Big.Show.-.E3-.22.05.2006.avi"
2006-06-05 21:18:10 information ----------------Title #1----------------
2006-06-05 21:18:10 information Taille du projet 4,3 Gb. (218 Mb. audio - 4,08 Gb. video)
2006-06-05 21:18:10 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 128 kb/s
2006-06-05 21:18:10 information Stream #0 - Video: mpeg4, yuv420p, 640x468
2006-06-05 21:18:10 information 2 Stream(s) found - est. duration 00:38:54.240
2006-06-05 21:18:10 information Opening file "C:\Mes documents\Nicolas\films\Game.One.-.Big.Show.-.E3-.25.05.2006.avi"
2006-06-05 21:18:10 information 2 Stream(s) found - est. duration 00:39:59.920
2006-06-05 21:18:10 information Opening file "C:\Mes documents\Nicolas\films\Game.One.-.Big.Show.-.E3-.24.05.2006.avi"
2006-06-05 21:18:09 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 128 kb/s
2006-06-05 21:18:09 information Stream #0 - Video: mpeg4, yuv420p, 640x468
2006-06-05 21:18:09 information 2 Stream(s) found - est. duration 00:39:40.560
2006-06-05 21:18:09 information Opening file "C:\Mes documents\Nicolas\films\Game.One.-.Big.Show.-.E3-.23.05.2006.avi"
2006-06-05 21:18:09 information 2 Stream(s) found - est. duration 00:39:55.880
2006-06-05 21:18:09 information Opening file "C:\Mes documents\Nicolas\films\Game.One.-.Big.Show.-.E3-.22.05.2006.avi"
2006-06-05 21:18:09 information [ ] Engine Log
2006-06-05 21:18:09 information Qualité de l'encodeur: 50%
2006-06-05 21:18:09 information --------------Encoding begin--------------
2006-06-05 21:18:09 information --------------Menu settings end--------------
2006-06-05 21:18:09 information [X] Lecture séquentielle
2006-06-05 21:18:09 information [X] Jouer en boucle
2006-06-05 21:18:09 information [ ] Démarrer automatiquement la lecture
2006-06-05 21:18:09 information [X] Menu
2006-06-05 21:18:09 information --------------Menu settings begin--------------
2006-06-05 21:18:09 information --------------Default burn settings end--------------
2006-06-05 21:18:09 information Default speed selected: Max
2006-06-05 21:18:09 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2006-06-05 21:18:09 information New Drive selected : 1:1:0 - HL-DT-ST DVDRAM GSA-4167B DL12 [E] (Scsi)
2006-06-05 21:18:09 information [ ] Delete files after burn complete
2006-06-05 21:18:09 information [ ] Don't eject after burn complete
2006-06-05 21:18:09 information [ ] Prefer SAO for DVD-R
2006-06-05 21:18:09 information [ ] Include originals
2006-06-05 21:18:09 information [X] Burn result to DVD
2006-06-05 21:18:09 information --------------Default burn settings begin--------------
2006-06-05 21:15:17 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2006-06-05 21:15:17 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2006-06-05 21:15:17 information Version 2.0.8.117
2006-06-05 21:15:17 information ExeName : "C:\PROGRAM FILES\VSO\CONVERTXTODVD\CONVERTXTODVD.EXE"
2006-06-05 21:15:17 information OS : Microsoft Windows Me
2006-06-05 21:15:14 information ******************** Report session started ********************
[mod="Stef"]Merci d'utiliser la fonction [ Code ] pour poster vos logs.[/mod]
Nichockeyfan
Messagepar Laddyc » 07 Juin 2006 7:58
Ta version n'est pas à jour, je te conseillerai vivement de la faire.
est ce un format de sous-titre ? si oui je pense que ce type n'est pas supporté par convertxtodvd.
Messagepar cougar_ii » 07 Juin 2006 14:29
v2.0.13.128 vient de sortir (En test, ßeta)
http://download.vso-software.fr/vsoConv ... p_2013.exe
Cette version corrige une erreur, qui produit le même genre d'erreur que tu as dans ton log.
Je ne suis pas sur si c'est le même problème, mais depuis v2.0.8 il y a eu beaucoup de changements .
Fait la mise-à-jour et retest les mêmes fichiers !
cougar_ii
[VSO] Client En Or
Messagepar Nichockeyfan » 07 Juin 2006 23:41
Merci, je vais faire la mise à jour et réessayer et je vous en redonne des nouvelles.
Nichockeyfan
