Probleme avec mon Graveur DVD Sony RW DRU-800A double layer
Messagepar tig3rvinc3 » 19 Jan 2006 0:44
Bonjours, j'ai un serieu probleme pas capable de faire un seul DVD sa fais 8 DVD que je met a la poubelle mon graveur arrete de graver a environ 5% pour aucune raison. J'ai changer le Firmware sans résultat voici mon dernier log.
WinAspi: File 'Wnaspi32.dll': Ver=2.0.0.0, size=17920 bytes, created 2005-01-31 14:05:30
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32
NT-SPTI used
Nero Version: 7.0.1.4
Internal Version: 7, 0, 1, 4
Recorder: <SONY DVD RW DRU-800A> Version: KY04 - HA 1 TA 1 - 7.0.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
CD-ROM: <IDE DVD-ROM 16X >Version: 2.21 - HA 1 TA 0 - 7.0.1.4
DiskPeripheral : ST380011A 3.06 nvidesm Port 0 ID 0 DMA: Off
CdRomPeripheral : IDE DVD-ROM 16X 2.21 nvidesm Port 0 ID 0 DMA: Off
CdRomPeripheral : SONY DVD RW DRU-800A KY04 nvidesm Port 0 ID 1 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 1 ID 0 DMA: Off
IDE DVD-ROM 16X D: CDRom0
SONY DVD RW DRU-800A E: CDRom1
AXV CD/DVD-ROM J: CDRom2
WriteBufferSize: 70254592 (0) Byte
Physical memory : 479MB (490992kB)
Free physical memory: 181MB (186136kB)
Memory in use : 62
18.1.2006
Compilation UDF/ISO
09:56:00 #1 Phase 112 File dlgbrnst.cpp, Line 1725
09:56:00 #2 Phase 114 File dlgbrnst.cpp, Line 1725
09:56:00 #3 Text 0 File Isodoc.cpp, Line 6411
UDF document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
Character set : ISO 9660
Joliet :FALSE
09:56:00 #4 Phase 111 File dlgbrnst.cpp, Line 1725
DVD-Video files sorted
09:56:00 #5 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 68608KB of Memory
09:56:00 #6 Text 0 File Reader.cpp, Line 124
09:56:00 #7 Text 0 File Writer.cpp, Line 113
Writer E: SONY DVD RW DRU-800A running
09:56:00 #8 ISO9660GEN -11 File Geniso.cpp, Line 3312
09:56:00 #9 ISO9660GEN -11 File Geniso.cpp, Line 3312
09:56:00 #10 Text 0 File Burncd.cpp, Line 3342
09:56:22 #11 Text 0 File DlgWaitCD.cpp, Line 279
Last address to be written: 886511 (197:00.11, 1731MB)
09:56:22 #12 Text 0 File DlgWaitCD.cpp, Line 291
09:56:23 #13 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: SONY DVD RW DRU-800A, Media type: DVD+R
Disc Manufacturer ID: RICOHJPN, Media Type ID: R01, Product revision number: 2
09:56:23 #14 Text 0 File DlgWaitCD.cpp, Line 458
(Medium in drive: inconnu. Medium required by compilation: DVD+R/RW; DVD-R/RW; DVD-R DL; DVD+R DL.)
09:56:23 #15 Text 0 File ThreadedTransferInterface.cpp, Line 847
0: TRM_DATA_MODE1 ()
original disc pos #0 + 886512 (886512) = #886512/197:0.12
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 886512 blocks [E: SONY DVD RW DRU-800A]
09:56:23 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [E: SONY DVD RW DRU-800A] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1815576576, ISRC ""
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
886512 | lead-out | 1 | 0x41 | 0x00
09:56:23 #17 Text 0 File SCSIPassThrough.cpp, Line 36
09:56:23 #18 Phase 24 File dlgbrnst.cpp, Line 1725
09:56:23 #19 Text 0 File Burncd.cpp, Line 4176
09:56:23 #20 Phase 25 File dlgbrnst.cpp, Line 1725
09:56:23 #21 Phase 36 File dlgbrnst.cpp, Line 1725
09:56:23 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2685
09:56:23 #23 Text 0 File Cdrdrv.cpp, Line 8411
Media type ID: R01
Media Specific [16..63]:
00 00 01 52 49 43 4F 48 - 4A 50 4E 52 30 31 02 38 ...RICOHJPNR01.8
23 54 37 09 00 3C 67 00 - AC 62 16 18 0B 0B 0A 0B #T7..<g.¬b......
01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................
09:56:23 #24 Text 0 File DVDR.cpp, Line 5900
Drive: SONY DVD RW DRU-800A
Book Type request [LO], rev 1: DVD-ROM
09:56:23 #25 CDR -1207 File DVDR.cpp, Line 5330
09:56:23 #26 Text 0 File DVDPlusRW.cpp, Line 666
09:56:30 #27 SPTI -500 File SCSIPassThrough.cpp, Line 323
E: CdRom1: SCSIStatus(x00) WinError(1117) NeroError(-500)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x05bd0000: Len x10000
09:56:35 #28 SPTI -1033 File SCSIPassThrough.cpp, Line 323
E: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1033)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x01
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01
Buffer x05881000: Len x10000
09:56:35 #29 CDR -1033 File Writer.cpp, Line 302
Drive not ready
09:56:35 #30 Text 0 File ThreadedTransfer.cpp, Line 228
09:56:35 #31 Text 0 File ThreadedTransfer.cpp, Line 222
09:56:35 #32 SPTI -1033 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
09:56:36 #33 SPTI -1033 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
09:56:36 #34 Phase 127 File dlgbrnst.cpp, Line 1725
09:56:38 #35 Phase 129 File dlgbrnst.cpp, Line 1725
09:56:38 #36 Text 0 File DVDR.cpp, Line 5900
Book Type request [LO], rev 1: DVD+R
09:56:38 #37 Phase 38 File dlgbrnst.cpp, Line 1725
File 'Drivers\CDRALW2K.SYS': Ver=6.1.1.7 , size=24698 bytes, created 2003-06-24 23:18:48
File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 2005-02-22 23:00:00
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 2004-12-20 13:37:14 (Prassi/Veritas driver for win 2K)
Présentement mon graveur est en Esclave demain ma tente de le mettre en maitre en esperant que sa face quelque chose merci de votre aide
tig3rvinc3
Messagepar Stef » 19 Jan 2006 6:43
Tu dois réactiver ton mode DMA :
http://www.gravure-news.com/html/tuto/03/page01.php :wink:
Messagepar tig3rvinc3 » 19 Jan 2006 15:48
Merci de ton aide :) mais le gros du problème ca j'avais déjà esseyer sauf que je vois pas Canal IDE !!!!!!!!!!!!
J'ai juste NVidia NForce :(
tig3rvinc3
Messagepar tig3rvinc3 » 19 Jan 2006 23:00
Bon ben probleme résolue, tu m'avais donné une bonne piste sa pris la journee a trouver comment activer les Canal IDE et maintenant c fait mais j'arrive pas a comprendre que chez Radio Shack il m'avais pas installer ca comme du monde une fois j'ai eu installé les Canal IDE Principal et secondaire, sa ma installer trois disque. sois : Le DD , le lecteur DVD et le Graveur DVD pourtant sa fais 1 ans et demi que je run avec cet ordi la sans trop probleme.
tig3rvinc3
Messagepar slywall » 20 Jan 2006 8:45
Tant mieux que tu aies résolu ton problème, rappelons au passage que les pilote N'force pour les IDE sont en général déconseillés pour la gravure, mieux vaut laisser ceux de windows (refuser l'installatation des IDE-SW lors de l'installation des pilotes n'force)
Retourner vers Configuration
