Problème de conversion
Messagepar Pili » 10 Fév 2007 14:20
J'ai un projet avec 2 films au format ".rmvb".
Lorsque je lance la conversion du projet, celle-ci plante dès le début.
Dans le fichier Log :
10/02/2007 12:47:17 information --------------Encoding end--------------
10/02/2007 12:47:12 information New media inserted. Burning layer is ready to write
10/02/2007 12:47:10 information Echec de la conversion en 00:00:00
10/02/2007 12:47:10 Erreur Error while opening decoder for stream #0.1
10/02/2007 12:47:10 information Video Stream #1 framerate : 25,00 Fps (source 25,00 Fps), no pulldown
10/02/2007 12:47:10 information Padded source image : Left 0, Top 120, Right 0, Bottom 120
10/02/2007 12:47:09 Avertissement Unknown input Stream #2 - Will be discarded
10/02/2007 12:47:09 information No pulldown: Frame duplication/removal will be used.
10/02/2007 12:47:09 information Video source original frame rate: 12,00
10/02/2007 12:47:09 information PAL 25 FPS output format set by user
10/02/2007 12:47:09 information Widescreen (16:9) set automatically
10/02/2007 12:47:09 information Bitrate vidéo 0/2974/8308 Kbps (min/avg/max)
10/02/2007 12:47:09 information Conversion "C:\Documents and Settings\Pili\RW\Gasthaus1.rmvb"
10/02/2007 12:47:09 information ----------------Titre #1----------------
10/02/2007 12:47:09 information Taille du projet 4,3 Gb. (257 Mb. audio - 4,05 Gb. video)
10/02/2007 12:47:09 Avertissement Stream #2 (data): skipped (codec type 2)
10/02/2007 12:47:09 information Stream #2 - Data: 0x0000
10/02/2007 12:47:09 information Stream #1 - Video: Real Video 10, 512x272, 1/12, 432 kb/s
10/02/2007 12:47:09 information Stream #0 - Audio: cook, 44100 Hz, stereo, 64 kb/s
10/02/2007 12:47:09 information 3 Stream(s) found - est. duration 01:31:45.938
10/02/2007 12:47:09 information Opening file "C:\Documents and Settings\Pili\RW\Gasthaus2.rmvb"
10/02/2007 12:47:09 information Stream #1 - Video: Real Video 10, 512x288, 1/12, 400 kb/s
10/02/2007 12:47:09 information Stream #0 - Audio: cook, 44100 Hz, stereo, 96 kb/s
10/02/2007 12:47:09 information 3 Stream(s) found - est. duration 01:35:10.274
10/02/2007 12:47:09 information Opening file "C:\Documents and Settings\Pili\RW\Gasthaus1.rmvb"
10/02/2007 12:47:09 information [ ] Ne pas réparer les "trous" dans l'audio
10/02/2007 12:47:09 information [ ] Engine Log
10/02/2007 12:47:09 information Qualité de l'encodeur: 100%
10/02/2007 12:47:09 information --------------Encoding begin--------------
10/02/2007 12:47:09 information --------------Menu settings end--------------
10/02/2007 12:47:09 information [ ] Lecture séquentielle
10/02/2007 12:47:09 information [ ] Jouer en boucle
10/02/2007 12:47:09 information [ ] Démarrer automatiquement la lecture
10/02/2007 12:47:09 information [X] Menu
10/02/2007 12:47:09 information --------------Menu settings begin--------------
10/02/2007 12:47:09 information --------------Default burn settings end--------------
10/02/2007 12:47:09 information Default speed selected: x6
10/02/2007 12:47:09 information Compatible media types : DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
10/02/2007 12:47:09 information New Drive selected : 0:0:0 - Philips DVD+RW DVD8601 6D11 [D] (Ide)
10/02/2007 12:47:09 information [X] Delete files after burn complete
10/02/2007 12:47:09 information [ ] Don't eject after burn complete
10/02/2007 12:47:09 information [ ] Prefer SAO for DVD-R
10/02/2007 12:47:09 information [ ] Include originals
10/02/2007 12:47:09 information [X] Burn result to DVD
10/02/2007 12:47:09 information --------------Default burn settings begin--------------
Merci pour votre aide. :wink:
Pili
Messagepar Laddyc » 10 Fév 2007 14:32
avez vous les codecs installés ?
Messagepar Pili » 10 Fév 2007 18:14
Je ne crois pas : je n'ai pas installé de codecs particuliers avec ConvertXToDVD.
Quelle est la procédure pour les installer ? Où puis-je les trouver ?
Merci.
Pili
Re: Problème de conversion
Messagepar couleurs78 » 10 Fév 2007 18:48
Bonsoir Pili
Pili a écrit:Bonjour,
Merci.
ConvertXToDVD n'installe pas de Codec
Tu peux touver les DLL concernant le Real Video 10 ici:
http://www.portmac.com/modules.php?name=Downloads&d_op=getit&lid=197
Tu les télécharge puis tu les mets les dans le même répertoire que ConvertXtoDVD.
couleurs78
Messagepar Pili » 11 Fév 2007 13:20
C'est parfait : ça marche.
Merci !
Pili
