problème de gravage aprés convertion
Messagepar caramel » 14 Jan 2007 19:28
Bonjour, cela fait plusieurs fois que je fais des dvd qui marchent et parfois j'ai au gravage un code d'erreur qui est toujours le même. code 04 3E 02 (HW error, timeout on logical unit)
Je vous joins le rapport. Pourriez vous me dire pourquoi ? Merci d'avance
14.01.2007 12:40:38 information ********** fin de la session ***********
14.01.2007 12:39:49 information User default language : 4108 (0x100Ch) - French (Switzerland)
14.01.2007 12:39:49 information System default language : 1036 (0x040Ch) - French (Standard)
14.01.2007 12:39:49 information Version 2.1.8.191
14.01.2007 12:39:49 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
14.01.2007 12:39:49 information OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
14.01.2007 12:39:48 information ******************** Report session started ********************
13.01.2007 18:07:47 information ********** fin de la session ***********
13.01.2007 18:07:26 information Media removed. Burning layer not ready to write
13.01.2007 18:07:06 information Finalization Time 00:00:50 - Total completion time 00:09:20
13.01.2007 18:06:15 information Write finished in 00:08:29 - Finalization start here. Avg. burn rate 3.98
13.01.2007 17:58:00 information Lead-in burning time (mS) 14006
13.01.2007 17:57:45 information Write started 1247616 sectors to write
13.01.2007 17:57:45 information Init success: DVD-R packet writing
13.01.2007 17:57:45 information Writing speed requested x6.0, effective x4.0
13.01.2007 17:57:45 information Available write speed: 8x, 6x, 4x, 2x
13.01.2007 17:57:45 information Media ID: TYG02
13.01.2007 17:57:45 information Scanned files #8, folder #2 - total size 2553993216 b. (2.38 Gb.)
13.01.2007 17:57:45 information Inserted media type : DVD-R
13.01.2007 17:57:43 information Write started
13.01.2007 17:57:42 information --------------Encoding end--------------
13.01.2007 17:57:42 information Media name: "Mon DVD"
13.01.2007 17:57:42 information Burned folder: "C:\Documents and Settings\user\Mes documents\ConvertXtoDVD\Pirates des Caraibes 2 - Le coffre du mort\"
13.01.2007 17:57:27 information New media inserted. Burning layer is ready to write
13.01.2007 17:57:26 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW
13.01.2007 17:57:25 information New Drive selected : 16:0:0 - _NEC DVD_RW ND-2500A 1.06 [E] (Usb)
13.01.2007 17:57:25 information Total size in built folder 2435 Mb., Target size DVD5 4400 Mb., Occupation 55.36%
13.01.2007 17:57:25 information Conversion terminée en 04:41:54
13.01.2007 17:56:43 information ------------Conversion du Menu--------------
13.01.2007 17:56:43 Avertissement Estimated Duration of the video was inaccurate. Output size may greatly differ from target size.
13.01.2007 17:56:43 information Generated duration 8550.04 sec., expected 7132.19 sec.
13.01.2007 17:01:29 information Stream #1 - Audio sync at 5784947.49 ms: 24.02 ms added
13.01.2007 16:49:53 information Chapter #12 start at 110:0.120
13.01.2007 16:29:24 information Chapter #11 start at 100:0.040
13.01.2007 16:09:33 information Chapter #10 start at 89:59.720
13.01.2007 16:04:21 information Stream #1 - Audio sync at 4386717.25 ms: 24.07 ms added
13.01.2007 15:49:30 information Chapter #9 start at 79:59.800
13.01.2007 15:48:13 information Stream #1 - Audio sync at 3970226.33 ms: 132.36 ms added
13.01.2007 15:30:22 information Chapter #8 start at 69:59.760
13.01.2007 15:11:32 information Chapter #7 start at 59:59.680
13.01.2007 15:03:40 information Stream #1 - Audio sync at 2799231.42 ms: 24.02 ms added
13.01.2007 14:51:37 information Chapter #6 start at 50:0.120
13.01.2007 14:31:05 information Chapter #5 start at 40:0.040
13.01.2007 14:11:52 information Chapter #4 start at 30:0.000
13.01.2007 14:07:55 information Stream #1 - Audio sync at 1401001.23 ms: 24.02 ms added
13.01.2007 13:52:29 information Chapter #3 start at 19:59.680
13.01.2007 13:34:06 information Chapter #2 start at 9:59.680
13.01.2007 13:15:31 information Stream #1 Sync. delay : 0.00 ms
13.01.2007 13:15:31 information Stream #0 Sync. delay : 0.00 ms
13.01.2007 13:15:31 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
13.01.2007 13:15:31 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, 1/25, q=2-31, 4783 kb/s
13.01.2007 13:15:31 information Video Stream #0 framerate : 25.00 Fps (source 25.00 Fps), no pulldown
13.01.2007 13:15:31 information Padded source image : Left 0, Top 88, Right 0, Bottom 88
13.01.2007 13:15:31 information No pulldown: Frame duplication/removal will be used.
13.01.2007 13:15:31 information Video source original frame rate: 29.97
13.01.2007 13:15:31 information PAL 25 FPS output format set by user
13.01.2007 13:15:31 information Widescreen (16:9) set automatically
13.01.2007 13:15:31 information Bitrate vidéo 0/4783/8308 Kbps (min/avg/max)
13.01.2007 13:15:31 information Conversion "C:\Documents and Settings\user\Shared\Pirates des Caraibes 2 - Le coffre du mort.avi"
13.01.2007 13:15:31 information ----------------Titre #1----------------
13.01.2007 13:15:31 information New media inserted. Burning layer is ready to write
13.01.2007 13:15:31 information Taille du projet 4.3 Gb. (163 Mb. audio - 4.14 Gb. video)
13.01.2007 13:15:31 information Stream #1 - Audio: mp3, 44100 Hz, stereo, 128 kb/s
13.01.2007 13:15:31 information Stream #0 - Video: mpeg4, yuv420p, 640x242, 2186/65535
13.01.2007 13:15:31 information 2 Stream(s) found - est. duration 01:58:52.192
13.01.2007 13:15:31 information Opening file "C:\Documents and Settings\user\Shared\Pirates des Caraibes 2 - Le coffre du mort.avi"
13.01.2007 13:15:29 information [ ] Ne pas corriger les vides (trou) audio
13.01.2007 13:15:29 information [ ] Rapport du moteur
13.01.2007 13:15:29 information Qualité de l'encodeur: 50%
13.01.2007 13:15:29 information --------------Encoding begin--------------
13.01.2007 13:15:29 information --------------Menu settings end--------------
13.01.2007 13:15:29 information [ ] Lecture séquentielle
13.01.2007 13:15:29 information [ ] Jouer en boucle
13.01.2007 13:15:29 information [ ] Démarrer automatiquement la lecture
13.01.2007 13:15:29 information [X] Menu
13.01.2007 13:15:29 information --------------Menu settings begin--------------
13.01.2007 13:15:29 information --------------Default burn settings end--------------
13.01.2007 13:15:29 information Default speed selected: 6x
13.01.2007 13:15:29 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW
13.01.2007 13:15:29 information New Drive selected : 16:0:0 - _NEC DVD_RW ND-2500A 1.06 [E] (Usb)
13.01.2007 13:15:29 information [ ] Delete files after burn complete
13.01.2007 13:15:29 information [ ] Don't eject after burn complete
13.01.2007 13:15:29 information [ ] Prefer SAO for DVD-R
13.01.2007 13:15:29 information [ ] Include originals
13.01.2007 13:15:29 information [X] Burn result to DVD
13.01.2007 13:15:29 information --------------Default burn settings begin--------------
13.01.2007 13:13:43 information User default language : 4108 (0x100Ch) - French (Switzerland)
13.01.2007 13:13:43 information System default language : 1036 (0x040Ch) - French (Standard)
13.01.2007 13:13:43 information Version 2.1.8.191
13.01.2007 13:13:43 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
13.01.2007 13:13:43 information OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
13.01.2007 13:13:41 information ******************** Report session started ********************
12.01.2007 21:53:04 information ********** fin de la session ***********
12.01.2007 21:52:48 information Media removed. Burning layer not ready to write
12.01.2007 21:52:10 Erreur Write error at 488144 (16) - Code 04 3E 02 [HW error, Timeout on logical unit]
12.01.2007 21:44:13 information Lead-in burning time (mS) 22129
12.01.2007 21:43:51 information Write started 858848 sectors to write
12.01.2007 21:43:51 information Init success: DVD-R packet writing
12.01.2007 21:43:51 information Writing speed requested x6.0, effective x4.0
12.01.2007 21:43:50 information Available write speed: 8x, 6x, 4x, 2x
12.01.2007 21:43:50 information Media ID: TYG02
12.01.2007 21:43:50 information Scanned files #7, folder #2 - total size 1757806592 b. (1.64 Gb.)
12.01.2007 21:43:50 information Inserted media type : DVD-R
12.01.2007 21:43:50 information Write started
12.01.2007 21:43:49 information --------------Encoding end--------------
12.01.2007 21:43:49 information Media name: "Mon DVD"
12.01.2007 21:43:49 information Burned folder: "C:\Documents and Settings\user\Mes documents\ConvertXtoDVD\La.Belle.et.le.Clochard\"
12.01.2007 21:43:34 information New media inserted. Burning layer is ready to write
12.01.2007 21:43:32 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW
12.01.2007 21:43:32 information New Drive selected : 16:0:0 - _NEC DVD_RW ND-2500A 1.06 [E] (Usb)
12.01.2007 21:43:32 information Total size in built folder 1676 Mb., Target size DVD5 4400 Mb., Occupation 38.10%
12.01.2007 21:43:32 information Conversion terminée en 01:49:04
12.01.2007 21:42:59 information ------------Conversion du Menu--------------
12.01.2007 21:42:59 information Generated duration 4374.08 sec., expected 4374.28 sec.
12.01.2007 21:42:59 Avertissement 206 frames duplicated
12.01.2007 21:38:32 information Chapter #8 start at 69:59.880
12.01.2007 21:23:47 information Chapter #7 start at 59:59.640
12.01.2007 21:09:25 information Chapter #6 start at 50:0.080
12.01.2007 20:54:56 information Chapter #5 start at 40:0.000
12.01.2007 20:39:25 information Chapter #4 start at 29:59.920
12.01.2007 20:23:58 information Chapter #3 start at 19:59.680
12.01.2007 20:09:06 information Chapter #2 start at 9:59.680
12.01.2007 19:54:28 information Stream #1 Sync. delay : 0.00 ms
12.01.2007 19:54:28 information Stream #0 Sync. delay : 0.00 ms
12.01.2007 19:54:28 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
12.01.2007 19:54:28 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, 1/25, q=2-31, 7916 kb/s
12.01.2007 19:54:28 information Video Stream #0 framerate : 25.00 Fps (source 25.00 Fps), no pulldown
12.01.2007 19:54:28 information Padded source image : Left 16, Top 0, Right 16, Bottom 0
12.01.2007 19:54:27 information No pulldown: Frame duplication/removal will be used.
12.01.2007 19:54:27 information Video source original frame rate: 25.00
12.01.2007 19:54:27 information PAL 25 FPS output format set by user
12.01.2007 19:54:27 information Fullscreen (4:3) set automatically
12.01.2007 19:54:27 information Bitrate vidéo 0/7916/8308 Kbps (min/avg/max)
12.01.2007 19:54:27 information Conversion "C:\Documents and Settings\user\Shared\La.Belle.et.le.Clochard.avi"
12.01.2007 19:54:27 information ----------------Titre #1----------------
12.01.2007 19:54:27 information Taille du projet 4.3 Gb. (100 Mb. audio - 4.2 Gb. video)
12.01.2007 19:54:27 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 96 kb/s
12.01.2007 19:54:27 information Stream #0 - Video: msmpeg4, yuv420p, 720x576, 1/25
12.01.2007 19:54:27 information 2 Stream(s) found - est. duration 01:12:54.280
12.01.2007 19:54:27 information Opening file "C:\Documents and Settings\user\Shared\La.Belle.et.le.Clochard.avi"
12.01.2007 19:54:27 information [ ] Ne pas corriger les vides (trou) audio
12.01.2007 19:54:27 information [ ] Rapport du moteur
12.01.2007 19:54:27 information Qualité de l'encodeur: 50%
12.01.2007 19:54:27 information --------------Encoding begin--------------
12.01.2007 19:54:27 information --------------Menu settings end--------------
12.01.2007 19:54:27 information [ ] Lecture séquentielle
12.01.2007 19:54:27 information [ ] Jouer en boucle
12.01.2007 19:54:27 information [ ] Démarrer automatiquement la lecture
12.01.2007 19:54:27 information [X] Menu
12.01.2007 19:54:27 information --------------Menu settings begin--------------
12.01.2007 19:54:27 information --------------Default burn settings end--------------
12.01.2007 19:54:27 information Default speed selected: 6x
12.01.2007 19:54:27 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW
12.01.2007 19:54:27 information New Drive selected : 16:0:0 - _NEC DVD_RW ND-2500A 1.06 [E] (Usb)
12.01.2007 19:54:27 information [ ] Delete files after burn complete
12.01.2007 19:54:27 information [ ] Don't eject after burn complete
12.01.2007 19:54:27 information [ ] Prefer SAO for DVD-R
12.01.2007 19:54:27 information [ ] Include originals
12.01.2007 19:54:27 information [X] Burn result to DVD
12.01.2007 19:54:27 information --------------Default burn settings begin--------------
12.01.2007 19:52:58 information User default language : 4108 (0x100Ch) - French (Switzerland)
12.01.2007 19:52:58 information System default language : 1036 (0x040Ch) - French (Standard)
12.01.2007 19:52:58 information Version 2.1.8.191
12.01.2007 19:52:58 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
12.01.2007 19:52:58 information OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
12.01.2007 19:52:57 information ******************** Report session started ********************
12.01.2007 14:52:55 information ********** fin de la session ***********
12.01.2007 14:52:53 Erreur Write error at 41616 (16) - Code 04 3E 02 [HW error, Timeout on logical unit]
12.01.2007 14:47:55 information Lead-in burning time (mS) 13133
12.01.2007 14:47:42 information Write started 990208 sectors to write
12.01.2007 14:47:42 information Init success: DVD-R packet writing
12.01.2007 14:47:42 information Writing speed requested x6.0, effective x4.0
12.01.2007 14:47:42 information Available write speed: 8x, 6x, 4x, 2x
12.01.2007 14:47:42 information Media ID: TYG02
12.01.2007 14:47:42 information Scanned files #7, folder #2 - total size 2026846208 b. (1.89 Gb.)
12.01.2007 14:47:42 information Inserted media type : DVD-R
12.01.2007 14:47:41 information --------------Encoding end--------------
12.01.2007 14:47:41 information Media name: "Mon DVD"
12.01.2007 14:47:41 information Burned folder: "C:\Documents and Settings\user\Mes documents\ConvertXtoDVD\Le.Livre.de.la.Jungle.2\"
12.01.2007 14:47:26 information New media inserted. Burning layer is ready to write
12.01.2007 14:47:24 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW
12.01.2007 14:47:24 information New Drive selected : 16:0:0 - _NEC DVD_RW ND-2500A 1.06 [E] (Usb)
12.01.2007 14:47:24 information Total size in built folder 1932 Mb., Target size DVD5 4400 Mb., Occupation 43.93%
12.01.2007 14:47:24 information Conversion terminée en 02:20:45
12.01.2007 14:46:51 information ------------Conversion du Menu--------------
12.01.2007 14:46:51 information Generated duration 4336.42 sec., expected 4336.42 sec.
12.01.2007 14:42:57 information Chapter #8 start at 70:19.600
12.01.2007 14:23:21 information Chapter #7 start at 60:8.740
12.01.2007 14:03:45 information Chapter #6 start at 50:3.260
12.01.2007 13:44:16 information Chapter #5 start at 40:17.800
12.01.2007 13:24:47 information Chapter #4 start at 30:2.060
12.01.2007 13:06:04 information Chapter #3 start at 20:16.600
12.01.2007 12:45:38 information Chapter #2 start at 10:0.860
12.01.2007 12:26:39 information Stream #1 Sync. delay : 0.00 ms
12.01.2007 12:26:39 information Stream #0 Sync. delay : 0.00 ms
12.01.2007 12:26:39 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, 1001/24000, q=2-31, 7802 kb/s
12.01.2007 12:26:39 information Video Stream #0 Pulldown : 23.976 -> 25.00 Fps
12.01.2007 12:26:39 information Video source original frame rate: 23.98
12.01.2007 12:26:39 information PAL 25 FPS output format set by user
12.01.2007 12:26:39 information Widescreen (16:9) set automatically
12.01.2007 12:26:39 information Bitrate vidéo 0/7802/8116 Kbps (min/avg/max)
12.01.2007 12:26:39 information Conversion "C:\Documents and Settings\user\Shared\Le.Livre.de.la.Jungle.2.avi"
12.01.2007 12:26:39 information ----------------Titre #1----------------
12.01.2007 12:26:39 information New media inserted. Burning layer is ready to write
12.01.2007 12:26:39 information Taille du projet 4.3 Gb. (199 Mb. audio - 4.1 Gb. video)
12.01.2007 12:26:39 information Stream #1 - Audio: ac3, 48000 Hz, 5:1, 384 kb/s
12.01.2007 12:26:39 information Stream #0 - Video: mpeg4, yuv420p, 576x336, 911/21845
12.01.2007 12:26:39 information 2 Stream(s) found - est. duration 01:12:16.420
12.01.2007 12:26:39 information Opening file "C:\Documents and Settings\user\Shared\Le.Livre.de.la.Jungle.2.avi"
12.01.2007 12:26:38 information [ ] Ne pas corriger les vides (trou) audio
12.01.2007 12:26:38 information [ ] Rapport du moteur
12.01.2007 12:26:38 information Qualité de l'encodeur: 50%
12.01.2007 12:26:38 information --------------Encoding begin--------------
12.01.2007 12:26:38 information --------------Menu settings end--------------
12.01.2007 12:26:38 information [ ] Lecture séquentielle
12.01.2007 12:26:38 information [ ] Jouer en boucle
12.01.2007 12:26:38 information [ ] Démarrer automatiquement la lecture
12.01.2007 12:26:38 information [X] Menu
12.01.2007 12:26:38 information --------------Menu settings begin--------------
12.01.2007 12:26:38 information --------------Default burn settings end--------------
12.01.2007 12:26:38 information Default speed selected: 6x
12.01.2007 12:26:38 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW
12.01.2007 12:26:38 information New Drive selected : 16:0:0 - _NEC DVD_RW ND-2500A 1.06 [E] (Usb)
12.01.2007 12:26:38 information [ ] Delete files after burn complete
12.01.2007 12:26:38 information [ ] Don't eject after burn complete
12.01.2007 12:26:38 information [ ] Prefer SAO for DVD-R
12.01.2007 12:26:38 information [ ] Include originals
12.01.2007 12:26:38 information [X] Burn result to DVD
12.01.2007 12:26:38 information --------------Default burn settings begin--------------
12.01.2007 12:25:12 information User default language : 4108 (0x100Ch) - French (Switzerland)
12.01.2007 12:25:12 information System default language : 1036 (0x040Ch) - French (Standard)
12.01.2007 12:25:12 information Version 2.1.8.191
12.01.2007 12:25:12 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
12.01.2007 12:25:12 information OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
12.01.2007 12:25:10 information ******************** Report session started ********************
12.01.2007 10:06:27 information ********** fin de la session ***********
12.01.2007 10:06:26 Erreur Write error at 41552 (16) - Code 04 3E 02 [HW error, Timeout on logical unit]
12.01.2007 10:01:23 information Lead-in burning time (mS) 12607
12.01.2007 10:01:11 information Write started 1044352 sectors to write
12.01.2007 10:01:11 information Init success: DVD-R packet writing
12.01.2007 10:01:10 information Writing speed requested x6.0, effective x4.0
12.01.2007 10:01:10 information Available write speed: 8x, 6x, 4x, 2x
12.01.2007 10:01:10 information Media ID: TYG02
12.01.2007 10:01:10 information Scanned files #7, folder #2 - total size 2137741312 b. (1.99 Gb.)
12.01.2007 10:01:10 information Inserted media type : DVD-R
12.01.2007 10:01:10 information Write started
12.01.2007 10:01:09 information --------------Encoding end--------------
12.01.2007 10:01:09 information Media name: "Mon DVD"
12.01.2007 10:01:09 information Burned folder: "C:\Documents and Settings\user\Mes documents\ConvertXtoDVD\Le livre de la Jungle\"
12.01.2007 10:00:54 information New media inserted. Burning layer is ready to write
12.01.2007 10:00:52 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW
12.01.2007 10:00:52 information New Drive selected : 16:0:0 - _NEC DVD_RW ND-2500A 1.06 [E] (Usb)
12.01.2007 10:00:52 information Total size in built folder 2038 Mb., Target size DVD5 4400 Mb., Occupation 46.33%
12.01.2007 10:00:52 information Conversion terminée en 02:35:40
12.01.2007 10:00:16 information ------------Conversion du Menu--------------
12.01.2007 10:00:16 information Generated duration 4521.96 sec., expected 4522.84 sec.
12.01.2007 10:00:16 Avertissement 112 frames duplicated
12.01.2007 09:49:35 information Chapter #8 start at 70:0.000
12.01.2007 09:28:19 information Chapter #7 start at 59:59.960
12.01.2007 09:08:07 information Chapter #6 start at 49:59.880
12.01.2007 08:47:44 information Chapter #5 start at 39:59.800
12.01.2007 08:26:59 information Chapter #4 start at 30:0.120
12.01.2007 08:06:13 information Chapter #3 start at 19:59.800
12.01.2007 07:45:42 information Chapter #2 start at 9:59.720
12.01.2007 07:25:11 information Stream #1 Sync. delay : 0.00 ms
12.01.2007 07:25:11 information Stream #0 Sync. delay : 0.00 ms
12.01.2007 07:25:11 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
12.01.2007 07:25:11 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, 1/25, q=2-31, 7650 kb/s
12.01.2007 07:25:11 information Video Stream #0 framerate : 25.00 Fps (source 25.00 Fps), no pulldown
12.01.2007 07:25:11 information Padded source image : Left 24, Top 0, Right 24, Bottom 0
12.01.2007 07:25:11 information No pulldown: Frame duplication/removal will be used.
12.01.2007 07:25:11 information Video source original frame rate: 25.00
12.01.2007 07:25:11 information PAL 25 FPS output format set by user
12.01.2007 07:25:11 information Fullscreen (4:3) set automatically
12.01.2007 07:25:11 information Bitrate vidéo 0/7650/8308 Kbps (min/avg/max)
12.01.2007 07:25:11 information Conversion "C:\Documents and Settings\user\Shared\Le livre de la Jungle.avi"
12.01.2007 07:25:11 information ----------------Titre #1----------------
12.01.2007 07:25:11 information New media inserted. Burning layer is ready to write
12.01.2007 07:25:11 information Taille du projet 4.3 Gb. (104 Mb. audio - 4.2 Gb. video)
12.01.2007 07:25:11 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 128 kb/s
12.01.2007 07:25:11 information Stream #0 - Video: msmpeg4, yuv420p, 352x288, 1/25
12.01.2007 07:25:11 information 2 Stream(s) found - est. duration 01:15:22.840
12.01.2007 07:25:11 information Opening file "C:\Documents and Settings\user\Shared\Le livre de la Jungle.avi"
12.01.2007 07:25:11 information [ ] Ne pas corriger les vides (trou) audio
12.01.2007 07:25:11 information [ ] Rapport du moteur
12.01.2007 07:25:11 information Qualité de l'encodeur: 50%
12.01.2007 07:25:11 information --------------Encoding begin--------------
12.01.2007 07:25:11 information --------------Menu settings end--------------
12.01.2007 07:25:11 information [ ] Lecture séquentielle
12.01.2007 07:25:11 information [ ] Jouer en boucle
12.01.2007 07:25:11 information [ ] Démarrer automatiquement la lecture
12.01.2007 07:25:11 information [X] Menu
12.01.2007 07:25:11 information --------------Menu settings begin--------------
12.01.2007 07:25:11 information --------------Default burn settings end--------------
12.01.2007 07:25:11 information Default speed selected: 6x
12.01.2007 07:25:11 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW
12.01.2007 07:25:11 information New Drive selected : 16:0:0 - _NEC DVD_RW ND-2500A 1.06 [E] (Usb)
12.01.2007 07:25:11 information [ ] Delete files after burn complete
12.01.2007 07:25:11 information [ ] Don't eject after burn complete
12.01.2007 07:25:11 information [ ] Prefer SAO for DVD-R
12.01.2007 07:25:11 information [ ] Include originals
12.01.2007 07:25:11 information [X] Burn result to DVD
12.01.2007 07:25:11 information --------------Default burn settings begin--------------
12.01.2007 07:22:14 information User default language : 4108 (0x100Ch) - French (Switzerland)
12.01.2007 07:22:14 information System default language : 1036 (0x040Ch) - French (Standard)
12.01.2007 07:22:14 information Version 2.1.8.191
12.01.2007 07:22:14 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
12.01.2007 07:22:14 information OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
12.01.2007 07:22:13 information ******************** Report session started ********************
caramel
Messagepar Laddyc » 15 Jan 2007 9:13
Bonjour de quel film s'agit il ? le dernier ou sur tout vos fichiers ?
re probleme de gravage
Messagepar caramel » 15 Jan 2007 14:07
il s'agit de 3 films fait le 12.01.2007 et qui ont fait le même message.
Le livre de la jungle, le livre de la jungle 2 et la belle et le clochard.
Merci d'avance
caramel
Messagepar cougar_ii » 18 Jan 2007 19:03
Dans les configuration de gravage, il y a une option qui choissit
[X] Prefer SAO for DVD-R
Je ne sais pas comment elle s'appelle en francais mais regarde pour l'option SAO pour les DVD-R
Ceci va faire grave en "Session At Once" au lieu de Packet Writting.
Aussi, ton graveur a le firmware v1.06
http://forum.rpc1.org/dl_firmware.php?download_id=1740
http://www.de.nec.de/software/2482_Firm ... WIN10B.zip
Le firmware v1.0b est disponible pour ton graveur.
J'ai jamais fais la mise a jour d'un graveur USB personnellement, mais ce firmware devrais être pour ton graveur !
cougar_ii
[VSO] Client En Or
