probleme de gravure avec un NEC ND-3520A
Messagepar seb57000 » 04 Nov 2005 11:48
voila...
j'ai essaye de graver un film avec ce graveur (avec un firmaware datant du 10/10/05 : 3.06)j'ai le meme prob avec nero 7 ou 6....
:praise: please , help me... :praise:
le log :
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
Recorder: <_NEC DVD_RW ND-3520AW> Version: 3.06 - HA 1 TA 0 - 6.6.0.16
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
CD-ROM: <TSSTcorp DVD-ROM TS-H352A>Version: TS03 - HA 1 TA 1 - 6.6.0.16
DiskPeripheral : Maxtor 6B200P0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-3520AW atapi Port 1 ID 0 DMA: On
CdRomPeripheral : TSSTcorp DVD-ROM TS-H352A atapi Port 1 ID 1 DMA: On
CdRomPeripheral : SCSIVAX DVD/CD-ROM 2.7a Vax347s Port 2 ID 0 DMA: Off
_NEC DVD_RW ND-3520AW D: CDRom0
TSSTcorp DVD-ROM TS-H352A E: CDRom1
SCSIVAX DVD/CD-ROM F: CDRom2
Physical memory : 1022MB (1047340kB)
Free physical memory: 612MB (626888kB)
Memory in use : 40 %
4.11.2005
CD-ROM (ISO)
10:34:38 #1 Text 0 File Isodoc.cpp, Line 6356
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
10:34:38 #2 Text 0 File Burncd.cpp, Line 2948
10:34:38 #3 Text 0 File Reader.cpp, Line 127
10:34:38 #4 Text 0 File Writer.cpp, Line 122
Writer _NEC DVD_RW ND-3520AW running
10:34:38 #5 ISO9660GEN -11 File geniso.cpp, Line 3309
10:34:38 #6 Text 0 File Burncd.cpp, Line 3233
10:34:38 #7 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 409472 ( 91:01.47)
Last address to be written: 360430 ( 80:07.55)
10:34:38 #8 Text 0 File DlgWaitCD.cpp, Line 282
10:34:38 #9 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: _NEC DVD_RW ND-3520AW;
CDR code: 00 97 15 05; OSJ entry from: TDK Corporation
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
10:34:38 #10 Text 0 File DlgWaitCD.cpp, Line 448
10:34:38 #11 Text 0 File ThreadedTransferInterface.cpp, Line 838
0: TRM_DATA_MODE1 ()
original disc pos #0 + 360431 (360431) = #360431/80:5.56
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 360429 blocks [_NEC DVD_RW ND-3520AW]
10:34:38 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [_NEC DVD_RW ND-3520AW] for write in TAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 738469888, ISRC ""
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
360431 | lead-out | 1 | 0x41 | 0x00
10:34:38 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1119
Removed 2 run-out blocks from end of track 1. Length: 360431 -> 360429.
10:34:38 #14 Phase 24 File dlgbrnst.cpp, Line 1832
10:34:39 #15 Text 0 File Burncd.cpp, Line 4120
10:34:39 #16 Phase 25 File dlgbrnst.cpp, Line 1832
10:34:39 #17 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 16x (2 400 KB/s)
10:34:39 #18 SCSI -1189 File Cdrdrv.cpp, Line 1180
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03AA5800
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0x40 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x30 0x02
10:34:39 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2654
10:34:39 #20 Text 0 File Mmc.cpp, Line 21708
10:39:58 #21 Text 0 File ThreadedTransfer.cpp, Line 228
10:40:13 #22 Text 0 File Mmc.cpp, Line 16352
<_NEC DVD_RW ND-3520AW> start Close Session
10:40:46 #23 SCSI -1135 File Cdrdrv.cpp, Line 1180
Sense Code: 0x0C
Sense Qual: 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x05 0x7F 0xEF 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
10:40:46 #24 CDR -1135 File ThreadedTransferInterface.cpp, Line 1294
Write error
10:40:46 #25 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1294
Could not perform Fixation
10:40:46 #26 Text 0 File Mmc.cpp, Line 16352
10:41:04 #27 SCSI -1135 File Cdrdrv.cpp, Line 1180
Sense Code: 0x0C
Sense Qual: 0x00
Sense Data: 0x70 0x00 0x03 0xFF 0xFF 0xCF 0x18 0x0A
10:41:04 #28 CDR -1135 File ThreadedTransferInterface.cpp, Line 1294
Write error
10:41:04 #29 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1294
10:41:04 #30 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 16x (2 400 KB/s)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 05/08/2004 13:00:00 (Adapter driver for rec)
seb57000
Messagepar garfield67 » 04 Nov 2005 18:02
Salut et bienvenue sur GN,
Donner un peu plus de details n'aurait pas été un luxe... :?
Avec quelle marque de CD graves-tu ?? Est-ce que tu rencontre ce problème avec tous les types de fichiers ?? Est-ce que ce problème se pose uniquement avec les CD ou avec les DVD également ??
Pas d'aide par MSN ou MP
garfield67
Matou alsacien
Messagepar seb57000 » 05 Nov 2005 23:33
que veux tu d'autre comme info ??
sinon, je grave avec des TDK (j'en ai pleins...) et suis entrain d'essayer avec un dvd)
j'ai gravé avec un dvd sur alcohol et ca marche...
mais pas les cd
NEC n'aime pas TDK ??
Il faut koi comme cd alors:?:
seb57000
Messagepar seb57000 » 06 Nov 2005 13:19
bahhh :shock:
pas de reponse ??? :shock: :!: :!:
seb57000
Messagepar garfield67 » 06 Nov 2005 15:10
Tu n'es pas sur une hot-line alors il n'y a rien d'affolant si il n'y a pas de réponse au bout de 10h... :?
Donc le problème se pose uniquement avec les CD... et avec tous les types de fichiers (données, musique, films) ??
garfield67
Matou alsacien
Messagepar seb57000 » 06 Nov 2005 17:06
ouais avec tout types de fichiers SEULEMENT avec mes cd TDK (j'ai pas d'autres marques pour le test...)
seb57000
meme probleme Could not perform Fixation
Messagepar Rage » 24 Déc 2007 1:15
moi aussi , j'ai ce probleme : Could not perform Fixation
j'ai le meme NEC 3520AW. (48x)
Ca fait longtemps que j'ai pas gravé et je ne sui spas un expert dans tous les parametres possibles...
EN gros, je fusille un CD sur deux...
des verbatim 700 mo 52x.
je colle mon log, quelqu'un y connait qqchose ?
Is
1A23-0009-7030-1745-0668-7176
ahead WinASPI: File 'D:\logiciels\Nero6.3.1.20\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22/07/2004 17:33:44
Nero version: 6.3.1.20 (Nero Express)
Recorder: <_NEC DVD_RW ND-3520AW> Version: 3.04 - HA 3 TA 1 - 6.3.1.20
Adapter driver: <> HA 3
CD-ROM: <Generic DVD-ROM >Version: 1.0 - HA 1 TA 0 - 6.3.1.20
Adapter driver: <st3shark> HA 1
DiskPeripheral : HDS722516VLAT80 V34O nvidesm Port 0 ID 0 DMA: Off
DiskPeripheral : WDC WD200EB-00CSF0 04.0 nvidesm Port 0 ID 1 DMA: Off
CdRomPeripheral : _NEC DVD_RW ND-3520AW3.04 nvidesm Port 0 ID 0 DMA: Off
CdRomPeripheral : HL-DT-STDVD-ROM GDR8162B0015 nvidesm Port 0 ID 1 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 st3shark Port 1 ID 0 DMA: Off
CdRomPeripheral : JY4630H IEA097F 2.0B vaxscsi Port 2 ID 0 DMA: Off
CdRomPeripheral : JY4630H IEA097F 2.0B vaxscsi Port 2 ID 1 DMA: Off
CdRomPeripheral : JY4630H IEA097F 2.0B vaxscsi Port 2 ID 2 DMA: Off
CdRomPeripheral : JY4630H IEA097F 2.0B vaxscsi Port 2 ID 3 DMA: Off
Generic DVD-ROM J: CDRom2
JY4630H IEA097F K: CDRom3
JY4630H IEA097F L: CDRom4
JY4630H IEA097F M: CDRom5
JY4630H IEA097F N: CDRom6
HL-DT-ST DVD-ROM GDR8162 G: CDRom1
_NEC DVD_RW ND-3520AW F: CDRom0
AutoRun : 0
Free physical memory: 248MB (254632kB)
Memory in use : 51 %
23.12.2007
CD-ROM (ISO)
23:52:18 #1 Text 0 File Isodoc.cpp, Line 6065
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : TAO
Mode : 1
Joliet : TRUE
23:52:18 #2 Phase 90 File dlgbrnst.cpp, Line 1855
Buffer Underrun Protection activated
23:52:18 #3 Text 0 File Reader.cpp, Line 126
23:52:18 #4 Text 0 File Writer.cpp, Line 124
23:52:18 #5 ISO9660GEN -11 File geniso.cpp, Line 3899
23:52:18 #6 Text 0 File Burncd.cpp, Line 3173
Turn on Track-at-once, using CD-R/RW media
23:52:18 #7 Text 0 File DlgWaitCD.cpp, Line 247
Last address to be written: 337709 ( 75:04.59)
23:52:18 #8 Text 0 File DlgWaitCD.cpp, Line 259
23:52:18 #9 Text 0 File DlgWaitCD.cpp, Line 2162
CDR code: 00 97 17 06; OSJ entry from: Moser Baer India Limited
ATIP Data:
23:52:18 #10 Text 0 File DlgWaitCD.cpp, Line 420
23:52:18 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
original disc pos #0 + 337710 (337710) = #337710/75:2.60
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 337708 blocks [_NEC DVD_RW ND-3520AW]
23:52:18 #12 Text 0 File ThreadedTransferInterface.cpp, Line 984
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 691937280, ISRC ""
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
337710 | lead-out | 1 | 0x00 | 0x41
23:52:18 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1030
Removed 2 run-out blocks from end of track 1. Length: 337710 -> 337708.
23:52:18 #14 Phase 24 File dlgbrnst.cpp, Line 1855
23:52:18 #15 Text 0 File Burncd.cpp, Line 4183
23:52:18 #16 Phase 25 File dlgbrnst.cpp, Line 1855
23:52:18 #17 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 48x (7 200 KB/s)
23:52:18 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2344
23:52:18 #19 Text 0 File Mmc.cpp, Line 20531
Set BUFE: supported -> ON
23:54:49 #20 Text 0 File ThreadedTransfer.cpp, Line 229
23:54:51 #21 Text 0 File Mmc.cpp, Line 15356
23:55:19 #22 SCSI -1135 File Cdrdrv.cpp, Line 1188
SCSI Exec, HA 3, TA 1, LUN 0
Sense Code: 0x0C
Sense Qual: 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x05 0x27 0x2E 0x0A
23:55:19 #23 CDR -1135 File ThreadedTransferInterface.cpp, Line 1183
Write error
23:55:19 #24 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1183
23:55:19 #25 Text 0 File Mmc.cpp, Line 15356
23:55:51 #26 Text 0 File dlgbrnst.cpp, Line 1713
23:55:51 #27 Phase 38 File dlgbrnst.cpp, Line 1855
Burn process failed at 48x (7 200 KB/s)
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 25/08/2006 04:47:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 30/05/2007 21:30:21 (Prassi/Veritas driver for win 2K)
File 'Drivers\st3shark.sys': Ver=3.41.0.0 built by: WinDDK, size=5504 bytes, created 27/09/2003 13:37:16 (Adapter driver for src)
Rage
Retourner vers Configuration
