probleme encodage mpeg4
Messagepar leclercq.c » 28 Fév 2007 21:08
bonjour a vous j ai la derniere version et mise a jour faite mais j ai un soucis des que je veut encoder un fichiers mpeg4 j ai dans mon log un echec et mon fichier qui ce créer est vide je vous donne le resultat de mon log, merci d avance. pour info le mpeg2 marche tres bien.....
27/02/2007 23:11:58 information ********** Fin de la session ***********
27/02/2007 23:11:14 information --------------Encoding end--------------
27/02/2007 23:11:12 information Echec de la conversion en 00:00:00
27/02/2007 23:11:12 Erreur Exception raised in conversion Thread with message "List index out of bounds (-1)"
27/02/2007 23:11:12 Avertissement Estimated Duration of the video was inaccurate. Output size may greatly differ from target size.
27/02/2007 23:11:12 information Generated duration 0,00 sec., expected 10,00 sec.
27/02/2007 23:11:12 Avertissement Stream #0 has produced NO data (empty). Result may miss some stream(s).
27/02/2007 23:11:12 information Stream #1 - Audio sync at 5820,00 ms: 510,00 ms added
27/02/2007 23:11:12 information Stream #1 - Audio sync at 4710,00 ms: 630,00 ms added
27/02/2007 23:11:12 information Stream #1 - Audio sync at 2760,00 ms: 780,00 ms added
27/02/2007 23:11:12 information Stream #1 - Audio sync at 1020,00 ms: 660,00 ms added
27/02/2007 23:11:12 information Stream #1 Sync. delay : 0,00 ms
27/02/2007 23:11:12 information Stream #0 Sync. delay : 0,00 ms
27/02/2007 23:11:12 information Output Stream#1 - Audio: ac3, 48000 Hz, mono, 192 kb/s, no automatic gain control
27/02/2007 23:11:12 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x480, 1001/30000, q=2-31, 6000 kb/s
27/02/2007 23:11:12 information Video Stream #0 framerate : 29,97 Fps (source 29,97 Fps), no pulldown
27/02/2007 23:11:12 information No pulldown: Frame duplication/removal will be used.
27/02/2007 23:11:12 information Video source original frame rate: 1000,00
27/02/2007 23:11:12 information NTSC 29.97 FPS output format set automatically
27/02/2007 23:11:12 information Fullscreen (4:3) set automatically
27/02/2007 23:11:12 information Bitrate vidéo 0/6000/9000 Kbps (min/avg/max)
27/02/2007 23:11:12 information Conversion "C:\Documents and Settings\christophe aurelie\Mes documents\vacance ski 2007\video gp4\MOL00A.ASF"
leclercq.c
