probleme gravure avec nero burn 6.6
Messagepar nonofr » 26 Juin 2008 23:45
Bonjour,j'ai du reinstaller windows xp suite au crash de mon DD ... depuis, la gravure ne marche plus ... ci dessous, le log generé par nero 6.6 :
je suis completement paumé ...
merci pour votre aide
(P.S.: je peux lire les dvd mais plus les dvd rw enregistrés sur mon dvd de salon)
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23/12/1997 02:23:24
ahead WinASPI: File 'E:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:32
Nero Version: 6.6.0.17
Internal Version: 6, 6, 0, 17f
Recorder: <PHILIPS DVDR1648P1> Version: P2.4 - HA 1 TA 2 - 6.6.0.17
Adapter driver: <nvatabus> HA 1
Drive buffer : 2048kB
CD-ROM: <PHILIPS DVDR1648P1 >Version: P2.4 - HA 1 TA 2 - 6.6.0.17
DiskPeripheral : ST3160815A nvatabus Port 1 ID 0 DMA: Off
CdRomPeripheral : PHILIPS DVDR1648P1 nvatabus Port 1 ID 2 DMA: Off
PHILIPS DVDR1648P1 D: CDRom0
Physical memory : 1023MB (1047856kB)
Free physical memory: 600MB (615364kB)
Memory in use : 41 %
26.6.2008
Compilation ISO
21:25:31 #1 Text 0 File Isodoc.cpp, Line 6356
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
21:25:31 #2 Text 0 File Reader.cpp, Line 127
21:25:31 #3 Text 0 File Writer.cpp, Line 122
Writer PHILIPS DVDR1648P1 running
21:25:31 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
21:25:31 #5 Text 0 File Burncd.cpp, Line 3233
21:25:31 #6 Text 0 File DlgWaitCD.cpp, Line 270
Last address to be written: 2060159 (457:48.59, 4023MB)
21:25:31 #7 Text 0 File DlgWaitCD.cpp, Line 282
21:25:31 #8 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: PHILIPS DVDR1648P1, Media type: DVD+RW
21:25:31 #9 Text 0 File DlgWaitCD.cpp, Line 448
21:25:31 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838
0: TRM_DATA_MODE1 ()
original disc pos #0 + 2060160 (2060160) = #2060160/457:48.60
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2060160 blocks [PHILIPS DVDR1648P1]
21:25:31 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [PHILIPS DVDR1648P1] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4219207680, ISRC ""
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2060160 | lead-out | 1 | 0x41 | 0x00
21:25:32 #12 Phase 24 File dlgbrnst.cpp, Line 1832
21:25:32 #13 Text 0 File Burncd.cpp, Line 4120
21:25:32 #14 Phase 25 File dlgbrnst.cpp, Line 1832
21:25:32 #15 Phase 28 File dlgbrnst.cpp, Line 1832
Speed measurement started
21:25:33 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2661
21:27:15 #17 Text 0 File WriterStatus.cpp, Line 116
<PHILIPS DVDR1648P1 > start writing Lead-Out at LBA 2060160 (1F6F80h), lenght 0 blocks
21:27:15 #18 Text 0 File ThreadedTransfer.cpp, Line 228
21:27:15 #19 Phase 29 File dlgbrnst.cpp, Line 1781
Speed measurement completed: 29,7x (41 054 Ko/s)
21:27:15 #20 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 2,4x (3 324 Ko/s)
21:27:15 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2661
21:27:15 #22 SCSI -1066 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 1, TA 2, LUN 0, buffer 0x03945800
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x24 0x00
21:27:15 #23 Phase 98 File dlgbrnst.cpp, Line 1832
21:27:46 #24 SCSI -1135 File Cdrdrv.cpp, Line 1182
Sense Code: 0x0C
Sense Qual: 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x0C 0x00
21:27:46 #25 Phase 101 File dlgbrnst.cpp, Line 1832
Formatting disc failed
21:27:46 #26 Text 0 File DVDPlusRW.cpp, Line 659
21:27:46 #27 CDR -1135 File ThreadedTransferInterface.cpp, Line 1778
Write error
21:27:46 #28 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1778
21:27:46 #29 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 2,4x (3 324 Ko/s)
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23/12/1997 03:02:46
File 'Drivers\nvatabus.sys': Ver=5.10.2600.0446 built by: WinDDK, size=79360 bytes, created 03/06/2004 04:40:46 (Adapter driver for rec)
nonofr
Messagepar Scaramanga » 28 Juin 2008 15:18
Le mode DMA n'est pas actif pour tes périphriques.
Code: Tout sélectionner
Ta version de Nero n'est pas à jour ;:
Messagepar nonofr » 28 Juin 2008 19:12
Bonjour et merci Scaramanga.
Comment puis je activer le mode DMA ?
Il me semblait deja l'etre:
-bios: AUTO
-dans le gestionnaire de peripheriques : ultra DMA 2
donc je ne comprends pas pourquoi cela ne fonctionne pas ...
Merci d'avance
nonofr
Messagepar Stef » 28 Juin 2008 19:29
Messagepar nonofr » 28 Juin 2008 19:49
Merci Stef ...
mais j'ai un probleme ; dans le tuto, on parle de canal ide principal ; à la place, j'ai "NVIDIA nForce3 250 Parallel ata controller v2.6"
que dois je faire ?
nonofr
Messagepar nonofr » 01 Juil 2008 12:40
est ce que cela pourrait venir du graveur ?
nonofr
Messagepar Scaramanga » 01 Juil 2008 17:05
TU as un chispet Nvidia qui gére les ports IDE.
Essais de mettre a jour le drivers de ce chispet .
