Problème Gravure Lite-On DVDRW SHM-165H6S
Messagepar gellek » 24 Nov 2007 20:56
Je possède le graveur Lite-On DVDRW SHM-165H6S et depuis hier impossible de graver, à chaque fois Nero me marque :
1C82-0000-19E5-MAAX-4003-9801-****
WinAspi: File 'Wnaspi32.dll': Ver=5, 0, 0, 1, size=22528 bytes, created 17/03/2001 20:34:12
ahead WinASPI: File 'C:\Program Files\Nero\Nero Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero Version: 7.5.1.1
Internal Version: 7, 5, 1, 1
Recorder: <LITE-ON DVDRW SHM-165H6S>Version: HS0E - HA 1 TA 0 - 7.5.1.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
CD-ROM: <LITE-ON DVDRW SHM-165H6S>Version: HS0E - HA 1 TA 0 - 7.5.1.1
DiskPeripheral : ST3200827AS iaStor Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW SHM-165H6S atapi Port 1 ID 0 DMA: On
LITE-ON DVDRW SHM-165H6S E: CDRom0
Physical memory : 1022MB (1046924kB)
Free physical memory: 541MB (554596kB)
Memory in use : 47 %
24.11.2007
Compilation ISO
18:17:46 #1 Text 0 File Isodoc.cpp, Line 6510
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
18:17:46 #2 Text 0 File ThreadedTransfer.cpp, Line 540
18:17:46 #3 Text 0 File Reader.cpp, Line 126
18:17:46 #4 Text 0 File Writer.cpp, Line 123
Writer E: LITE-ON DVDRW SHM-165H6S running
18:17:46 #5 ISO9660GEN -11 File Geniso.cpp, Line 3313
18:17:46 #6 Text 0 File Burncd.cpp, Line 3443
18:17:47 #7 Text 0 File DlgWaitCD.cpp, Line 300
Last address to be written: 1437327 (319:24.27, 2807MB)
18:17:47 #8 Text 0 File DlgWaitCD.cpp, Line 312
18:17:47 #9 Text 0 File DlgWaitCD.cpp, Line 2851
Recorder: LITE-ON DVDRW SHM-165H6S, Media type: DVD-R
Disc Manufacturer: DAXON0 - 08S
18:17:47 #10 Text 0 File DlgWaitCD.cpp, Line 484
18:17:47 #11 Text 0 File ThreadedTransferInterface.cpp, Line 863
0: TRM_DATA_MODE1 ()
original disc pos #0 + 1437328 (1437328) = #1437328/319:24.28
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1437328 blocks [E: LITE-ON DVDRW SHM-165H6S]
18:17:47 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1079
Prepare recorder [E: LITE-ON DVDRW SHM-165H6S] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2943647744, ISRC ""
0 | 1 | 0 | 0x41 | 1437328 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1437328 | 0 | 0x00
1437328 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
18:17:47 #13 Text 0 File SCSIPassThrough.cpp, Line 39
18:17:47 #14 Phase 24 File dlgbrnst.cpp, Line 1730
18:17:47 #15 Text 0 File Burncd.cpp, Line 4274
18:17:47 #16 Phase 25 File dlgbrnst.cpp, Line 1730
18:17:47 #17 Phase 36 File dlgbrnst.cpp, Line 1730
18:17:47 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2746
18:17:47 #19 Text 0 File DVDR.cpp, Line 2969
18:17:47 #20 Text 0 File DVDR.cpp, Line 3125
18:17:47 #21 Text 0 File Cdrdrv.cpp, Line 9215
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Media Specific [16..63]:
18:18:26 #22 Text 0 File Cdrdrv.cpp, Line 1290
18:18:26.281 - E: LITE-ON DVDRW SHM-165H6S : Queue again later
18:22:10 #23 SPTI -1046 File SCSIPassThrough.cpp, Line 291
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x2A 00 00 00 15 60 00 00 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05
Buffer x075e0000: Len x10000
0xE3 16 ED 8A 37 D4 F4 D7 10 85 B1 A7 3C 24 0A A9
0xE1 F7 60 67 33 CC F7 0E 8E EC FB DC DA E2 B8 EA
0xAD 3D CF BB BD 3E ED BE 3D 5E 14 C9 CE E2 E2 AC
18:22:10 #24 CDR -1046 File Writer.cpp, Line 312
Illegal disc
18:22:10 #25 Text 0 File ThreadedTransfer.cpp, Line 229
18:22:10 #26 Text 0 File ThreadedTransfer.cpp, Line 223
18:22:11 #27 Text 0 File DVDR.cpp, Line 3341
EndDAO: Last written address was 5471
18:22:11 #28 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 4x (5 540 Ko/s)
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19/08/2005 02:00:00
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 17/07/2002 08:05:10
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 08/03/2007 00:51:00 (Prassi/Veritas driver for win 2K)
Donc si quelqu'un pouvait m'aider, ca serait sympa. J'ai des choses importantes à graver. Merci d'avance.
Nero : 7.5.1.1
DVD : DVD-R Phillips
Vitesse de Gravure avant le problème : 8x
Graveur : Lite-On DVDRW SHM-165H6S
Autres :
- XP Media Center SP2
- ASPI 4.60 installé suite à votre tuto, avant 4.1.72
- Aide gravure XP désactivé
- Mode DMA activé
- Autorun désactivé
Quand je veux graver, ca grave jusqu'à 3-4% puis ca bloque quand la vitesse d'ecriture atteint 6.5x , le DVD continuer de tourner puis 2-3 minutes après ca me marque " Disque Non Valable " puis je vous ai posté le log.
Je grave depuis pas mal de temps avec ce graveur donc je ne pense pas qu'il y ait un rapport avec la compatibilité du CD car j'ai toujours utilisé les phillips.
Merci d'avance pour vos reponses.
gellek
Messagepar gellek » 24 Nov 2007 21:31
Je viens d'essater un CD-R Verbatim , ca a marché donc je vais essayer un DVDR W Verbatim.
gellek
Messagepar Scaramanga » 24 Nov 2007 21:34
Code: Tout sélectionner
-Le disque inséré n'est pas reconnu. Qulle est la marque de ces médias ?
-Met a jour ton firmware.
http://www.liteonit.com/global/index.ph ... &Itemid=75
Messagepar gellek » 25 Nov 2007 1:32
J'ai mis à jour le firmware et le disque inséré est un DVD-R Phillips. Je réesaye demain, je vous tiens au courant.
gellek
