probleme gravure pioneer 108
Messagepar zozomas » 26 Nov 2004 4:03
Bonjour à tous
j'ai acheté un graveur pioneer 108 que j'ai installé dans un boitier usb. Celui ci parvient à lire les dvd, cd sans probleme mais il m'est impossible de graver.
Ni avec Nero, ni avec d'autres logiciels
Voici le message d'erreur:
[mod="Sam58"]Oh le beau numéro de série que voilà
Faire attention à bien le supprimer la prochaine fois. :wink: [/mod]
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 28/07/2004 16:51:12
Nero API version: 6.6.0.1
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <PIONEER DVD-RW DVR-108> Version: 1.14 - HA 2 TA 0 - 6.6.0.1
Adapter driver: <> HA 2
Drive buffer : 2000kB
DiskPeripheral : IC25N060ATMR04-0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : QSI DVDRW SDW-041 atapi Port 1 ID 0 DMA: On
QSI DVDRW SDW-041 F: CDRom0
PIONEER DVD-RW DVR-108 G: CDRom1
Physical memory : 510MB (523244kB)
Free physical memory: 195MB (200140kB)
Memory in use : 61 %
26.11.2004
NeroAPI
00:39:23 #1 Phase 112 File APIProgress.cpp, Line 276
00:39:23 #2 Phase 114 File APIProgress.cpp, Line 276
00:39:23 #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
00:39:23 #4 Text 0 File Reader.cpp, Line 127
00:39:23 #5 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-108 running
00:39:23 #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: Beginning burn process.
00:39:23 #7 ISO9660GEN -11 File geniso.cpp, Line 3286
00:39:23 #8 ISO9660GEN -11 File geniso.cpp, Line 3286
00:39:23 #9 Text 0 File Burncd.cpp, Line 3117
00:39:59 #10 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 3883423 (862:58.73, 7584MB)
00:39:59 #11 Text 0 File DlgWaitCD.cpp, Line 268
Write in overburning mode: NO
00:39:59 #12 Text 0 File DlgWaitCD.cpp, Line 2309
Recorder: PIONEER DVD-RW DVR-108, Media type: DVD+R9 Double Layer
Disc Manufacturer ID: RITEK, Media Type ID: D01, Product revision number: 1
00:39:59 #13 Text 0 File DlgWaitCD.cpp, Line 430
(Medium in drive: unknown. Medium required by compilation: DVD+R/RW; DVD-R/RW; DVD+R9 Double Layer.)
00:39:59 #14 Text 0 File ThreadedTransferInterface.cpp, Line 844
0: TRM_DATA_MODE1 ()
original disc pos #0 + 3883424 (3883424) = #3883424/862:58.74
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3883424 blocks [PIONEER DVD-RW DVR-108]
00:39:59 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1047
Prepare recorder [PIONEER DVD-RW DVR-108] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7953252352, ISRC ""
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
3883424 | lead-out | 1 | 0x00 | 0x41
00:40:00 #16 Phase 24 File APIProgress.cpp, Line 276
00:40:00 #17 Text 0 File Burncd.cpp, Line 4003
00:40:00 #18 Phase 25 File APIProgress.cpp, Line 276
00:40:00 #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 2.4x (3 324 KB/s)
00:40:00 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2497
00:40:20 #21 Text 0 File DVDPlusDualLayer.cpp, Line 481
L0 Data Zone Capacity set to 1957904 (1DE010h, 3824MB) -> OK, confirmed setting
00:40:20 #22 CDR -1205 File DVDPlusDualLayer.cpp, Line 506
Burning Layer 1
00:40:20 #23 Text 0 File DVDPlusDualLayer.cpp, Line 514
Start writing layer 1 at address 0 (0h)
00:40:20 #24 Text 0 File Cdrdrv.cpp, Line 8281
Book Type: DVD+R DL (14), Part Version: 1
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
End Physical Sector Number of Data Area: FCFFFF h
End Sector Number in Layer 0: 20E00F h
Extended Information indicators: 0 h
Disc Manufacturer ID: RITEK...
Media type ID: D01
Number of Physical format information bytes in use in ADIP up to byte 63: 64
Media Specific [16..63]:
00 00 00 52 49 54 45 4B - 00 00 00 44 30 31 01 40 ...RITEK...D01.@
25 25 37 00 00 28 64 00 - 28 64 14 14 0A 0A 0A 0A %%7..(d.(d......
01 00 00 00 00 19 1B 0B - 0B 0E 0F 01 00 00 00 00 ................
00:40:20 #25 Text 0 File DVDPlusRW.cpp, Line 632
00:40:24 #26 Text 0 File Cdrdrv.cpp, Line 1284
00:40:24.500 - PIONEER DVD-RW DVR-108\H2 T0 : Queue again later
01:00:29 #27 CDR -1206 File DVDPlusDualLayer.cpp, Line 1680
Burning Layer 2
01:00:29 #28 Text 0 File DVDPlusDualLayer.cpp, Line 1687
Perform layer 1 to 2 jump before writing at address 1957920 (1DE020h)
01:00:30 #29 Text 0 File Cdrdrv.cpp, Line 1284
01:00:30.171 - PIONEER DVD-RW DVR-108\H2 T0 : Queue again later
01:00:31 #30 SCSI -500 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x01580000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x1D 0xE3 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
01:00:31 #31 CDR -500 File Writer.cpp, Line 311
SCSI command aborted
01:00:31 #32 Text 0 File ThreadedTransfer.cpp, Line 229
01:00:31 #33 Text 0 File ThreadedTransfer.cpp, Line 223
01:10:50 #34 CDR -1169 File WriterStatus.cpp, Line 167
Logical unit not ready, operation in progress
01:10:50 #35 TRANSFER -24 File WriterStatus.cpp, Line 167
01:10:50 #36 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 2.4x (3 324 KB/s)
01:10:50 #37 Text 0 File AudioCompilationImpl.cpp, Line 867
01:10:50 #38 Text 0 File AudioCompilationImpl.cpp, Line 896
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 11:02:00 (Prassi/Veritas driver for win 2K)
je suis novice. J'espère que vous pourrez m'aider.
Merci d'avance
Zozomas
zozomas
Messagepar Scaramanga » 27 Nov 2004 9:00
XP + SP1 ?
