probleme plextor 716 AL
Messagepar malcolm89 » 26 Avr 2007 11:07
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 06/05/2002 12:01:14
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero Version: 6.6.0.12
Internal Version: 6, 6, 0, 12c
Recorder: <PLEXTOR DVDR PX-716AL> Version: 1.02 - HA 3 TA 1 - 6.6.0.12
Adapter driver: <atapi> HA 3
Drive buffer : 8192kB
CD-ROM: <PLEXTOR CD-R PREMIUM >Version: 1.06 - HA 3 TA 0 - 6.6.0.12
DiskPeripheral : WDC WD205BA atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST380011A atapi Port 0 ID 1 DMA: On
DiskPeripheral : Maxtor 6Y200M0 atapi Port 2 ID 0 DMA: On
CdRomPeripheral : PLEXTOR CD-R PREMIUM atapi Port 3 ID 0 DMA: On
CdRomPeripheral : PLEXTOR DVDR PX-716AL atapi Port 3 ID 1 DMA: On
CdRomPeripheral : UD3289Q GHV815P 1.0 a4p7t4om Port 4 ID 0 DMA: Off
PLEXTOR CD-R PREMIUM G: CDRom0
PLEXTOR DVDR PX-716AL H: CDRom1
UD3289Q GHV815P I: CDRom2
Physical memory : 1022MB (1047280kB)
Free physical memory: 446MB (457132kB)
Memory in use : 56 %
25.4.2007
Compilation UDF/ISO
12:09:13 #1 Phase 112 File dlgbrnst.cpp, Line 1832
12:09:13 #2 Phase 114 File dlgbrnst.cpp, Line 1832
12:09:13 #3 Text 0 File Isodoc.cpp, Line 6194
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet :FALSE
12:09:13 #4 Phase 111 File dlgbrnst.cpp, Line 1832
DVD-Video files sorted
12:09:13 #5 Text 0 File Reader.cpp, Line 127
12:09:13 #6 Text 0 File Writer.cpp, Line 122
Writer PLEXTOR DVDR PX-716AL running
12:09:13 #7 ISO9660GEN -11 File geniso.cpp, Line 3293
12:09:13 #8 ISO9660GEN -11 File geniso.cpp, Line 3293
12:09:13 #9 Text 0 File Burncd.cpp, Line 3153
12:09:13 #10 Text 0 File DlgWaitCD.cpp, Line 260
Last address to be written: 2237007 (497:06.57, 4369MB)
12:09:13 #11 Text 0 File DlgWaitCD.cpp, Line 272
12:09:13 #12 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: PLEXTOR DVDR PX-716AL, Media type: DVD+R
Disc Manufacturer ID: AML, Media Type ID: 002, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
12:09:13 #13 Text 0 File DlgWaitCD.cpp, Line 438
12:09:13 #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 2237008 (2237008) = #2237008/497:6.58
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2237008 blocks [PLEXTOR DVDR PX-716AL]
12:09:13 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [PLEXTOR DVDR PX-716AL] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4581392384, ISRC ""
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2237008 | lead-out | 1 | 0x41 | 0x00
12:09:13 #16 Phase 24 File dlgbrnst.cpp, Line 1832
12:09:13 #17 Text 0 File Burncd.cpp, Line 4037
12:09:13 #18 Phase 25 File dlgbrnst.cpp, Line 1832
12:09:13 #19 Phase 36 File dlgbrnst.cpp, Line 1832
12:09:14 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2609
12:09:14 #21 Text 0 File Cdrdrv.cpp, Line 8438
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 258
Book Type: DVD+R (10), Part Version: 1
Extended Information indicators: 3 h
Disc Manufacturer ID: AML.....
Media type ID: 002
Media Specific [16..63]:
00 00 03 41 4D 4C 00 00 - 00 00 00 30 30 32 00 38 ...AML.....002.8
23 54 37 10 02 4E 72 02 - 8C 63 16 16 0B 0B 0A 0A #T7..Nr..c......
12:09:14 #22 Text 0 File DVDR.cpp, Line 5130
Drive: PLEXTOR DVDR PX-716AL
Book Type request [PX]: DVD-ROM
12:09:14 #23 CDR -1207 File DVDR.cpp, Line 4777
12:09:14 #24 Text 0 File DVDPlusRW.cpp, Line 648
12:09:16 #25 Text 0 File Cdrdrv.cpp, Line 1288
12:09:16.359 - PLEXTOR DVDR PX-716AL\H3 T1 : Queue again later
12:09:41 #26 SCSI -1039 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 3, TA 1, LUN 0, buffer 0x03BF4A00
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x5C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x09 0x01
12:09:41 #27 SCSI -1066 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 3, TA 1, LUN 0, buffer 0x03640000
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x24 0x00
12:09:41 #28 CDR -1039 File Writer.cpp, Line 311
Focus or tracking error
12:09:41 #29 Text 0 File ThreadedTransfer.cpp, Line 228
12:09:42 #30 Text 0 File ThreadedTransfer.cpp, Line 222
12:09:42 #31 SCSI -1176 File Cdrdrv.cpp, Line 1182
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x04
12:09:42 #32 Phase 127 File dlgbrnst.cpp, Line 1832
12:09:42 #33 Phase 129 File dlgbrnst.cpp, Line 1832
12:09:42 #34 Text 0 File DVDR.cpp, Line 5130
Book Type request [PX]: DVD+R
12:09:42 #35 Phase 38 File dlgbrnst.cpp, Line 1832
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 25/08/2006 05:47:00
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 06/05/2002 12:01:08
File 'Drivers\PXHELP20.SYS': Ver=3.00.33a, size=36528 bytes, created 25/08/2006 05:47:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 22:59:44 (Adapter driver for rec)
Voila toujours des probleme avec mon putain de graveur. En fait le scsi raid c'est un truc qu'installe alcohol donc je l'ai reinstaller mais sa veux toujours pas graver. J'espere que la solution ce trouve dans ce log. Merci d'avance car j'aimerai eviter de devoir racheter un graveur :(
malcolm89
