par aldemon » 05 Juin 2004 18:50
J'ai déactivé la gravure d'XP (Enregistrement dévalidé), les DMA du DD et du graveur sont ON.
Je joins le log d'erreur de NERO si çà peux aider...
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17/07/2002 10:03:20
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 19:18:06
Version de Nero : 6.3.1.6
Graveur : <ARTEC WRR-52Z> Version: 1.25 - HA 1 TA 0 - 6.3.1.6
Drive buffer : 2048kB
CD-ROM : <ARTEC WRR-52Z >Version: 1.25 - HA 1 TA 0 - 6.3.1.6
DiskPeripheral : WDC WD400BB-00CAA0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : ARTEC WRR-52Z atapi Port 1 ID 0 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a sojuscsi Port 2 ID 0 DMA: Off
ARTEC WRR-52Z D: CDRom0
AXV CD/DVD-ROM E: CDRom1
AutoRun : 0
CmdQueuing : 1
CmdNotification: 2
EraseSpeed : 0
Free physical memory: 252MB (258844kB)
Memory in use : 50 %
5.6.2004
CD-ROM (ISO)
10:28:41 #1 Text 0 File Isodoc.cpp, Line 6062
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Continue multisession
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
10:28:41 #2 Phase 75 File dlgbrnst.cpp, Line 1841
JustLink activé
10:28:41 #3 Text 0 File Reader.cpp, Line 118
10:28:41 #4 Text 0 File Writer.cpp, Line 124
Writer ARTEC WRR-52Z running
10:28:41 #5 ISO9660GEN -11 File geniso.cpp, Line 3898
10:28:41 #6 Text 0 File Burncd.cpp, Line 3198
Turn on Piste par piste, using CD-R/RW media
10:28:42 #7 Text 0 File DlgWaitCD.cpp, Line 244
Last possible write address on media: 336074 ( 74:42.74)
Last address to be written: 155963 ( 34:41.38)
10:28:42 #8 Text 0 File DlgWaitCD.cpp, Line 249
10:28:42 #9 Text 0 File DlgWaitCD.cpp, Line 2107
Recorder: ARTEC WRR-52Z;
CDRW code: 00 00 00 00; CD manufacturer unknown
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
10:28:42 #10 Text 0 File DlgWaitCD.cpp, Line 410
10:28:42 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
original disc pos #0 + 5896 (5896) = #5896/1:18.46
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 5894 blocks [ARTEC WRR-52Z ]
10:28:42 #12 Text 0 File ThreadedTransferInterface.cpp, Line 982
Prepare recorder [ARTEC WRR-52Z ] for write in TAO
Tracks 2 to 2:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 12382208, ISRC ""
149918 | lead-in | 0 | 0x00 | 0x41
149918 | 2 | 0 | 0x00 | 0x41
150068 | 2 | 1 | 0x00 | 0x41
155964 | lead-out | 1 | 0x00 | 0x41
10:28:42 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1028
Removed 2 run-out blocks from end of track 2. Length: 5896 -> 5894.
10:28:42 #14 Phase 24 File dlgbrnst.cpp, Line 1841
10:28:42 #15 Text 0 File Burncd.cpp, Line 4214
10:28:42 #16 Phase 25 File dlgbrnst.cpp, Line 1841
Cache des fichiers terminé
10:28:42 #17 Phase 36 File dlgbrnst.cpp, Line 1841
Début de gravure à 4x (600 Ko/s)
10:28:42 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2342
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #150068
10:28:42 #19 Text 0 File Mmc.cpp, Line 19864
Set BUFE: JustLink -> ON , JustSpeed : ON
10:28:43 #20 SCSI -1173 File Cdrdrv.cpp, Line 1437
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03D50000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x90
Sense Qual: 0x82
CDB Data: 0x2A 0x00 0x00 0x02 0x4A 0x34 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x90 0x82
10:28:43 #21 CDR -1173 File Writer.cpp, Line 304
Erreur de tâche de contrôle lecture écriture
10:28:43 #22 Text 0 File ThreadedTransfer.cpp, Line 229
10:28:43 #23 CDR -201 File WriterStatus.cpp, Line 196
Fonction writestate invalide
ARTEC WRR-52Z\H1 T0
10:28:43 #24 TRANSFER -18 File WriterStatus.cpp, Line 196
Impossible d'exécuter EndTrack
10:28:43 #25 Text 0 File Mmc.cpp, Line 14708
<ARTEC WRR-52Z > start Close Session
10:28:43 #26 SCSI -1176 File Cdrdrv.cpp, Line 1183
Sense Code: 0x72
Sense Qual: 0x04
Sense Data: 0x71 0x00 0x05 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x72 0x04
10:28:43 #27 CDR -1176 File WriterStatus.cpp, Line 245
Erreur fixation session
10:28:43 #28 TRANSFER -19 File WriterStatus.cpp, Line 245
Impossible d'effectuer la fonction Fixation
10:28:43 #29 Text 0 File WriterStatus.cpp, Line 254
falling back to disc fixation
10:28:43 #30 Text 0 File Mmc.cpp, Line 14708
10:28:43 #31 SCSI -1176 File Cdrdrv.cpp, Line 1183
Sense Code: 0x72
Sense Qual: 0x04
10:28:43 #32 CDR -1176 File WriterStatus.cpp, Line 245
10:28:43 #33 TRANSFER -19 File WriterStatus.cpp, Line 245
10:28:43 #34 Text 0 File dlgbrnst.cpp, Line 1699
10:28:43 #35 Phase 38 File dlgbrnst.cpp, Line 1841
La gravure a échoué à 4x (600 Ko/s)
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 17/07/2002 09:05:10
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 28/09/2001 14:00:00 (Adapter driver for rec)
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
- Fichiers joints
- Log.txt
- (8.05 Kio) Téléchargé 355 fois
