probleme gravure nero 9 ou 8 c pareil
Messagepar DREF33 » 19 Juil 2009 13:57
Bonjour je cherche deseperement mon probleme de gravure j ai 2 graveur dvd et j ai le meme probleme sur les 2 avec nero 8 et nero 9. Pouvez m aider ? merci d avance je vous laisse le rapport d erreur que nero me donne
NT-SPTI used
Nero Version: 9.0.9.100
Internal Version: 9, 0, 9, 100
(Nero Express)
Recorder: <PIONEER DVD-RW DVR-212> Version: 1.28 - HA 1 TA 0 - 9.0.9.100
Adapter driver: <Serial ATA> HA 1
Drive buffer : 2000kB
Bus Type : default
CD-ROM: <BSLYDY 9M3CPIVW5UJ0 >Version: 1.03 - HA 1 TA 2 - 9.0.9.100
Adapter driver: <IDE> HA 1
CdRomPeripheral : PIONEER DVD-RW DVR-212 atapi Port 2 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-212D atapi Port 2 ID 1 DMA: On
DiskPeripheral : WDC WD1002FBYS-01A6B0 atapi Port 3 ID 0 DMA: On
CdRomPeripheral : BSLYDY 9M3CPIVW5UJ0 1.03 agptxohs Port 6 ID 0 DMA: Off
PIONEER DVD-RW DVR-212 F: CdRom0
PIONEER DVD-RW DVR-212D E: CdRom1
BSLYDY 9M3CPIVW5UJ0 G: CdRom2
Physical memory : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use : 20 %
19.7.2009
Compilation UDF
13:45:36 #1 Text 0 File SCSIPTICommands.cpp, Line 450
13:45:36 #2 Text 0 File Isodoc.cpp, Line 6789
UDF document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
13:45:37 #3 Text 0 File Burncd.cpp, Line 3563
13:45:37 #4 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
13:45:37 #5 Text 0 File DlgWaitCD.cpp, Line 312
Last address to be written: 359039 ( 79:47.14, 701MB)
13:45:37 #6 Text 0 File DlgWaitCD.cpp, Line 324
13:45:37 #7 Text 0 File DlgWaitCD.cpp, Line 2951
Recorder: PIONEER DVD-RW DVR-212, Media type: DVD-RW
Disc Manufacturer ID: <MCC 01> <RW4X >
Disc Application Code: 2, Disc Physical Code: 214
13:45:37 #8 Text 0 File DlgWaitCD.cpp, Line 499
13:45:37 #9 Text 0 File ThreadedTransferInterface.cpp, Line 756
0: TRM_DATA_MODE1 ()
original disc pos #0 + 359040 (359040) = #359040/79:47.15
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 359040 blocks [F: PIONEER DVD-RW DVR-212]
13:45:37 #10 Text 0 File ThreadedTransferInterface.cpp, Line 958
Prepare [F: PIONEER DVD-RW DVR-212] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 735313920, ISRC ""
0 | 1 | 1 | 0x41 | 359040 | 0 | 0x00
359040 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
13:45:37 #11 Text 0 File SCSIPTICommands.cpp, Line 240
13:45:37 #12 Text 0 File Burncd.cpp, Line 4362
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
13:45:37 #13 Phase 24 File dlgbrnst.cpp, Line 1767
13:45:37 #14 Text 0 File Burncd.cpp, Line 4484
13:45:37 #15 Phase 25 File dlgbrnst.cpp, Line 1767
13:45:37 #16 Phase 36 File dlgbrnst.cpp, Line 1767
13:45:38 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2675
13:45:38 #18 Text 0 File DVDR.cpp, Line 3259
13:45:38 #19 Text 0 File DVDR.cpp, Line 3413
13:45:38 #20 SPTI -1066 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Code: 0x24
Sense Qual: 0x00
Buffer x088b7100: Len x648
13:45:38 #21 Text 0 File Cdrdrv.cpp, Line 10187
Book Type: DVD-RW (3), Extended Part Version: 1.2 (18)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Outer Limit of Data Recordable Area: 0 h
Revision number of maximum recording speed: 2.0
Revision number of minimum recording speed: 1.0
Revision number table of recording speed: - - - - - - -
Class: 3, Extended part version: 18
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 20 10 00 00 00 00 00 - 00 00 03 12 00 00 00 00 ................
0D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 02 D6 FD 9E D8 31 00 - 02 00 00 00 00 00 00 00 ......1.........
03 4D 43 43 20 30 31 00 - 04 52 57 34 58 20 20 00 .MCC.01..RW4X...
05 00 00 00 00 00 00 00 - 06 15 0C 05 50 10 10 00 ............P...
07 15 0C 05 88 50 10 00 - 08 1A 0A 08 80 01 00 00 .....P..........
09 1A 0A 08 88 80 01 00 - 0A 00 00 00 00 00 00 00 ................
0B 16 0C 13 0B 04 10 00 - 0C 10 10 03 16 1A 03 00 ................
13:45:38 #22 Text 0 File DVDR.cpp, Line 3551
Reserved Track size: 359040 (57A80h, 701MB) -> return code 0
13:45:38 #23 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
13:45:38 #24 Text 0 File CUDFTransferItem2.cpp, Line 660
GenUDF2 FS Layout:
Sectors to be written: 359040
Session Start: Sector 0
Volume Structure: Sector [0, 256] (257 Sectors)
Meta Data: Sector [257, 260] (4 Sectors)
Data: Sector [261, 358748] (358488 Sectors)
After Data: Sector [358749, 358751] (3 Sectors)
Trailer Track: Sector [358752, 359039] (288 Sectors)
GenUDF2 Parameters:
PrepTime: 07-19-2009 13:45:37
UDF Revision: 1.02
UDF Partition Type: Physical
UDF Special Mode: None
Bytes per Sector: 2048
Session Start: 0
Physical Partition Start: -1
Total Capacity: 2298496
Multi Session Mode: None
Disc Type: DVD-RW
OS Class: 0
Volume ID: Mon disque
Allow Unicode Labels: 0
Duplicate Meta Data: 1
MS Info File: 00000000
VMS Rollback File: 00000000
Create ISO bridge: 0
ECC Block Length: 16
Sparing Packet Length: 32
Allocation Unit Size: 32
Alignment Unit Size: 16
Make Writable: 0
Access Type: Read-only
13:46:29 #25 SPTI -1064 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1064)
CDB Data: 0x2A 00 00 00 03 80 00 00 20 00 00 00
Sense Code: 0x21
Sense Qual: 0x02
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 21 02
Buffer x09fa0740: Len x10000
0x0B D4 0E AA 99 AA EA AD CF 5C 02 EF FF E4 57 AA
0x97 8B A8 B8 95 39 A0 65 60 1E 08 37 C2 47 95 0F
0xC0 3D 59 71 70 1E A5 C3 E1 20 7B 31 51 7F 98 FA
13:46:29 #26 CDR -1064 File Writer.cpp, Line 306
Invalid block address
13:46:29 #27 Phase 181 File dlgbrnst.cpp, Line 1767
Writing lead-out...
13:46:29 #28 Text 0 File DVDR.cpp, Line 3819
EndDAO: Last written address was 895 (37Fh)Estimated time for 30mm Borders: 3min 52sec
13:46:29 #29 Text 0 File DVDPlusDualLayer.cpp, Line 1424
SetDriveCaps: Set LAST LBA of layer 1 to 0
13:46:29 #30 Phase 38 File dlgbrnst.cpp, Line 1767
13:46:29 #31 Text 0 File SCSIPTICommands.cpp, Line 287
13:46:33 #32 Text 0 File Cdrdrv.cpp, Line 11444
13:46:33 #33 Text 0 File SCSIPTICommands.cpp, Line 450
DREF33
Messagepar Scaramanga » 19 Juil 2009 16:26
La partie interessante du fichier Log de Nero est les erreur ATAPI :
Code: Tout sélectionner
Sense Code: 0x24
Sense Qual: 0x00
Soit le code :
052400
Si on vérifie les source possible du dysfonctionnemùent sur cette page, ou trouve comme source possible :
These errors are difficult to specify a cause for. Most of the times the problem is in the system.
Ahem...pas terrible comme piste....
Tu peux commencer par vérifier si tes firmwares sont à jour, les pilotes des chispset de ta mobo sont à jour ( très important !).
Est ce que ça merdouille avec tous les types de médias viérges ?
Messagepar DREF33 » 19 Juil 2009 19:43
salut oui le drivers sont ok du chipset j ai verifier sur toutlesdrivers.com tout est bon les medias sa me le fait sur des verbatim et des phillips.Je ne comprends pas.
DREF33
Messagepar DREF33 » 19 Juil 2009 19:46
voila vous penser plus que sa soit hardware ou firmware car la carte mere a moins de 1 ans les drivers sont okfranchement j ai jamais eu ce probleme
DREF33
Messagepar Scaramanga » 19 Juil 2009 19:54
Quel modèle de CM ?
Messagepar DREF33 » 19 Juil 2009 20:59
c est une gigabyte ep45t ud3r sa peut venir du parametrage du bios ?
DREF33
Messagepar DREF33 » 17 Aoû 2009 11:14
Bonjour a tous c 'est bon j ai trouvé la solution a mon probleme en faite sa venait de l antivirus kaspersky qui me bloquer nero va savoir pourquoi ? La solution est d autoriser nero dans le controle d application mais aussi de faire modifier et aller sur l onglet exclusion est de selectionner tout les ne pas analyser.Voila c'est tout en cas j ai remerci quand meme l'aide qui m a été donné ici et j espere que j aurai aider certaines personnes sur le forum
DREF33
Messagepar Stef » 17 Aoû 2009 11:21
Je te remercie de partager la solution à ton problème. J'utilise Kaspersky antivirus également mais je n'ai jamais rencontré de problème.
Faut dire que j'ai abandonné Néro déjà depuis quelques temps aussi.
Messagepar DREF33 » 19 Aoû 2009 22:34
je precise que c est avec kaspersky internet security 2009 :)
DREF33
Messagepar Stef » 20 Aoû 2009 9:06
Merci de la précision, lorsque tu rencontrais ce problème particulier, tu n'as jamais essayé un autre logiciel de gravure :?:
Messagepar DREF33 » 23 Aoû 2009 17:02
Si mais ca me faisait pareil donc j ai essayer avec quasiment tout les nero et toujours plantage et meme avec d autres logiciel pareil donc je sais pas mais bon maintenant sa tourne bien j ai graver 6 dvd hier sans auncun probleme avec nero.J ai trouvé que ce probleme apres je sais pas ce que kaspersky pour que nero ne marche pas.Mais maintenant sa marche :D
DREF33
