Kit d'utilitaire et de réparation pour PC
Messagepar Scaramanga » 05 Fév 2009 19:33
Le site anglophone Technibble met a disposition un recueille de logiciels portable pour PC, qui vous permettrons de palier à la plus part des petitq soucis du quotidien des geeks en herbe.... :D
Voici le contenu :
File Management
* CCleaner - Cleans up Windows systems. Clears temporary internet files, cookies, history etc..
* JkDefragGUI - An advanced defragging tool far superior to the built in Windows one
* DriveimageXML - Hard drive imaging tool. Allows you to get a single file out of a whole image too
* Explore2fs - Allows you to explore hard drives with Linux file systems
* Double Killer - Finds duplicate files and deletes them
* Deep Burner - CD/DVD Burning software
* 7-Zip Portable - Archive creating and extraction tool. Can handle most compression formats
* PC-Decrapifier - Cleans out the crap that comes installed on new brand name computers (Norton trials, toolbars etc.)
Information
* Process Explorer - Allows you to view system processes
* System Information - View lots of information about a system (specs, passwords, temperatures etc.)
* ProduKey - View software cdkeys and serials
* Autoruns - Autostart program viewer
* HWMonitor - View hardware information
* GPU-Z - Show video card information (chipset, bios version, shaders, memory size etc.)
* Wireless Key View - Shows saved wireless network keys
* TreeSize Free - Show how much space each folder on a system uses
* Game Key Revealer - View CDKeys and Serials for popular games
* USBDView - Allows you to list and manage USB devices (including devices that arent currently plugged in)
* TrID - Identifies file types for extension-less files
* Codec Installer - Finds and analyzes video codecs
* Unknown Devices - Tells you what a “Unknown Device” in system properties actually is
* GSpot - Video analyizer
Repair Tools
* Norton Removal Tool - Removes Symantec products
* McAfee Removal Tool - Removes McAfee products
* LSPFix - Fixes broken Winsock entries
* Dial-a-Fix - Repair Windows files and registries
Recovery
* Recuva - Recovers deleted files
* Restoration - Recovers deleted files
* Photorec - Recover deleted/damaged files from Flash memory (like digital cameras)
* DBXTract - Recover emails from damaged DBX files (like Outlook Express)
Network Tools
* Wireshark - View network packets
* Network Scanner - Scans the network for devices
* Putty - SSH/Telnet/RLogin client
* Network Stumbler - Wireless Network Scanner
Virus and Malware Removal Tools
* Clamwin Antivirus - Virus scanner/remover
* Rootkit Revealer - Detects rootkits on a system
* Combofix - Malware finder and remover
* SmitFraudFix - Malware finder and remover
* RogueFix - Malware finder and remover
* Hijack This! - Malware remover
* SUPERAntiSpyware - Malware scanner and remover
* Malwarebytes - Malware scanner and remover
Misc
* Mozilla Firefox - Web browser
* JavaRa - Find and remove old Java versions
* Monitor Tester - Test monitors from problems
* Dead Pixel Tester - Finds and fixes dead pixels on LCDs
* ChkFlsh - Check flash drives for errors or test their real size (as fake ones appear on eBay)
* Double Driver - Driver backup tool
* SumatraPDF - Lightweight PDF viewer
* Revo Uninstaller - Advanced application uninstaller
Tweaks
* TweakUI - Windows XP tweaking tool
* VistaTweaker - Vista tweaking tool
Scripts
* Quickly Make a System Restore Point - Makes restore point
* Reset Network - Releases/Renews IP and flushes DNS
* Clear Printer Spooler - Clears stuck print jobs from spooler
* Stop Automatic Updates - Stops “Windows has installed updates, restart now” dialog temporarily
* Start Automatic Updates - Switches it back on
To start the toolkit. Extract the zip file to your portable media and run “Launcher.exe”. You can also add your own utilities to the menu by going to File > and make it so it autoruns when you insert your portable media into the system.
Download:
Mirror 1: Computer-Repair-Utility-Kit-V2.zip - 88.4mb @ Sharebee.com (multiple locations like Rapidshare, Megaupload etc.). Thanks to Ron for uploading.
Mirror 2: Computer-Repair-Utility-Kit-V2.zip - 88.4mb @ Generously hosted at JasonRoss.name
Mirror 3: Computer-Repair-Utility-Kit-V2.zip - 88.4mb @ Generously hosted at AlibabaComputech.com
Mirror 4: Computer-Repair-Utility-Kit-V2.zip - 88.4mb @ Generously hosted at KCCSOnline.com
Mirror 5: Computer-Repair-Utility-Kit-V2.zip - 88.4mb @ Generously hosted at ChatNFiles.com
Le tout pése 175 Mo , de quoi coller sur une clé USB ou dans ce que vous voudrez. ( 90 Mo zippé à DL)
La package contient un lanceur ( + icone dans la barre de tâche) , dont voici une capture :
Un vrai couteau suisse !
:arrow: http://www.technibble.com/computer-repair-utility-kit/
Messagepar Pierre G » 05 Fév 2009 21:08
très utile en effet.
domage qu'il n'existe pas la même chose "in french" .
A plus.
Messagepar Burnitall » 05 Fév 2009 21:54
Il existe quelque chose in french doc, et de plus totalement personnalisable.
> http://www.liberkey.com/
Tout simplement indispensable pour le geek en herbe ou non. :P
Messagepar slywall » 06 Fév 2009 8:04
Merci pour ces précieuses interventions, je suis certain que cela ne manquera pas de rendre service :clap2:
Messagepar slywall » 11 Fév 2009 11:57
J'ai testé la liberkey en version ultimate, c'est un vrai petit chef d'oeuvre ce truc, moyennant une inscription gratuite sur le site, on bénéfice du module de mise à jour automatique des logiciels.
Je l'ai installé sur une de mes clés USB, la trousse à outils pour tous les besoins ou les problèmes ou presque. Génial !
Messagepar Burnitall » 11 Fév 2009 20:53
Et bien plus encore, l'association de fichiers provisoire, la personnalisation, un suivi des mises à jour presque en temps réel, les sauvegardes, une sélection de logiciels freewares pertinente et traduit en fr...
slywall a écrit:Je l'ai installé sur une de mes clés USB, la trousse à outils pour tous les besoins ou les problèmes ou presque. Génial !
Le fruit d'une équipe dynamique et réactive. :clap2:
