pas possible d'encoder un dvd
Messagepar quebecor » 18 Fév 2007 19:39
depuis hier, je ne peux plus encoder de dvd.
ca me donne ca comme erreur:
Error while opening decoder for stream #0.0
pouvez vous m'aider.
pourtant j'ai la derniere version.
en plus, j'ai utilise cette version pendant 3 jours, et pas de probleme.
d'un coup, plus rien ne marche.
voila mon log:
2007-02-18 12:24:52 information ********** Fin de la session ***********
2007-02-18 12:24:43 Avertissement DirectX preview is not available (filter not installed).
2007-02-18 12:24:43 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:24:43 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:24:43 information Version 2.1.14.223
2007-02-18 12:24:43 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDvd.exe"
2007-02-18 12:24:43 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:24:42 information ******************** Report session started ********************
2007-02-18 12:24:38 information ********** Fin de la session ***********
2007-02-18 12:24:26 information --------------Encoding end--------------
2007-02-18 12:24:22 information Echec de la conversion en 00:00:00
2007-02-18 12:24:22 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:24:22 information Video Stream #0 framerate : 25,00 Fps (source 25,00 Fps), no pulldown
2007-02-18 12:24:22 Avertissement DirectX preview is not available (filter not installed).
2007-02-18 12:24:22 information No pulldown: Frame duplication/removal will be used.
2007-02-18 12:24:22 information Video source original frame rate: 25,00
2007-02-18 12:24:22 information PAL 25 FPS output format set automatically
2007-02-18 12:24:22 information Widescreen (16:9) set automatically
2007-02-18 12:24:22 information Bitrate vidéo 0/6826/8808 Kbps (min/avg/max)
2007-02-18 12:24:22 information Conversion "D:\films normaux\the.Substitute.3.avi"
2007-02-18 12:24:22 information ----------------Titre #1----------------
2007-02-18 12:24:22 information Taille du projet 4,3 Gb. (120 Mb. audio - 4,18 Gb. video)
2007-02-18 12:24:22 information Stream #1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
2007-02-18 12:24:22 information Stream #0 - Video: mpeg4, 704x392, 1/25
2007-02-18 12:24:22 information 2 Stream(s) found - est. duration 01:26:08.040
2007-02-18 12:24:22 information Opening file "D:\films normaux\the.Substitute.3.avi"
2007-02-18 12:24:22 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:24:22 information [ ] Engine Log
2007-02-18 12:24:22 information Qualité de l'encodeur: 50%
2007-02-18 12:24:22 information --------------Encoding begin--------------
2007-02-18 12:24:22 information --------------Menu settings end--------------
2007-02-18 12:24:22 information [ ] Menu
2007-02-18 12:24:22 information --------------Menu settings begin--------------
2007-02-18 12:24:22 information --------------Default burn settings end--------------
2007-02-18 12:24:22 information Default speed selected: Max
2007-02-18 12:24:22 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:24:22 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:24:22 information [ ] Delete files after burn complete
2007-02-18 12:24:22 information [ ] Don't eject after burn complete
2007-02-18 12:24:22 information [X] Prefer SAO for DVD-R
2007-02-18 12:24:22 information [ ] Include originals
2007-02-18 12:24:22 information [ ] Burn result to DVD
2007-02-18 12:24:22 information --------------Default burn settings begin--------------
2007-02-18 12:24:15 Avertissement DirectX preview is not available (filter not installed).
2007-02-18 12:24:08 Avertissement DirectX preview is not available (filter not installed).
2007-02-18 12:24:02 information --------------Encoding end--------------
2007-02-18 12:23:54 information Echec de la conversion en 00:00:00
2007-02-18 12:23:54 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:23:54 information Video Stream #0 framerate : 25,00 Fps (source 25,00 Fps), no pulldown
2007-02-18 12:23:54 Avertissement DirectX preview is not available (filter not installed).
2007-02-18 12:23:54 information No pulldown: Frame duplication/removal will be used.
2007-02-18 12:23:54 information Video source original frame rate: 25,00
2007-02-18 12:23:54 information PAL 25 FPS output format set automatically
2007-02-18 12:23:54 information Widescreen (16:9) set automatically
2007-02-18 12:23:54 information Bitrate vidéo 0/2904/8808 Kbps (min/avg/max)
2007-02-18 12:23:54 information Conversion "D:\Apocalypse Now .mkv"
2007-02-18 12:23:54 information ----------------Titre #1----------------
2007-02-18 12:23:54 information Taille du projet 4,3 Gb. (271 Mb. audio - 4,03 Gb. video)
2007-02-18 12:23:54 information Stream #1 - Audio: vorbis, 44100 Hz, stereo
2007-02-18 12:23:54 information Stream #0 - Video: Real Video 10, 640x352, 1/25
2007-02-18 12:23:54 information 2 Stream(s) found - est. duration 03:13:59.278
2007-02-18 12:23:54 information Opening file "D:\Apocalypse Now .mkv"
2007-02-18 12:23:53 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:23:53 information [ ] Engine Log
2007-02-18 12:23:53 information Qualité de l'encodeur: 50%
2007-02-18 12:23:53 information --------------Encoding begin--------------
2007-02-18 12:23:53 information --------------Menu settings end--------------
2007-02-18 12:23:53 information [ ] Menu
2007-02-18 12:23:53 information --------------Menu settings begin--------------
2007-02-18 12:23:53 information --------------Default burn settings end--------------
2007-02-18 12:23:53 information Default speed selected: Max
2007-02-18 12:23:53 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:23:53 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:23:53 information [ ] Delete files after burn complete
2007-02-18 12:23:53 information [ ] Don't eject after burn complete
2007-02-18 12:23:53 information [X] Prefer SAO for DVD-R
2007-02-18 12:23:53 information [ ] Include originals
2007-02-18 12:23:53 information [ ] Burn result to DVD
2007-02-18 12:23:53 information --------------Default burn settings begin--------------
2007-02-18 12:23:37 Avertissement DirectX preview is not available (filter not installed).
2007-02-18 12:23:37 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:23:37 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:23:37 information Version 2.1.14.223
2007-02-18 12:23:37 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDvd.exe"
2007-02-18 12:23:37 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:23:36 information ******************** Report session started ********************
2007-02-18 12:20:33 information ********** Fin de la session ***********
2007-02-18 12:20:30 information --------------Encoding end--------------
2007-02-18 12:20:26 information Echec de la conversion en 00:00:00
2007-02-18 12:20:26 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:20:26 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 12:20:26 information Video source original frame rate: 25,00
2007-02-18 12:20:26 information NTSC 29.97 FPS output format set by user
2007-02-18 12:20:26 information Fullscreen (4:3) set automatically
2007-02-18 12:20:26 information Bitrate vidéo 0/8808/8808 Kbps (min/avg/max)
2007-02-18 12:20:26 information Conversion "I:\DOSSIER FRIENDS\10\S10 Ep8.avi"
2007-02-18 12:20:26 information ----------------Titre #1----------------
2007-02-18 12:20:26 information Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2007-02-18 12:20:26 information Taille du projet 4,3 Gb. (31 Mb. audio - 4,27 Gb. video)
2007-02-18 12:20:26 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 128 kb/s
2007-02-18 12:20:26 information Stream #0 - Video: mpeg4, 512x368, 1/30000
2007-02-18 12:20:26 information 2 Stream(s) found - est. duration 00:22:12.360
2007-02-18 12:20:26 information Opening file "I:\DOSSIER FRIENDS\10\S10 Ep8.avi"
2007-02-18 12:20:26 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:20:26 information [ ] Engine Log
2007-02-18 12:20:26 information Qualité de l'encodeur: 50%
2007-02-18 12:20:26 information --------------Encoding begin--------------
2007-02-18 12:20:26 information --------------Menu settings end--------------
2007-02-18 12:20:26 information [ ] Menu
2007-02-18 12:20:26 information --------------Menu settings begin--------------
2007-02-18 12:20:26 information --------------Default burn settings end--------------
2007-02-18 12:20:26 information Default speed selected: Max
2007-02-18 12:20:26 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:20:26 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:20:26 information [ ] Delete files after burn complete
2007-02-18 12:20:26 information [ ] Don't eject after burn complete
2007-02-18 12:20:26 information [X] Prefer SAO for DVD-R
2007-02-18 12:20:26 information [ ] Include originals
2007-02-18 12:20:26 information [ ] Burn result to DVD
2007-02-18 12:20:26 information --------------Default burn settings begin--------------
2007-02-18 12:19:41 information --------------Encoding end--------------
2007-02-18 12:19:38 information Echec de la conversion en 00:00:00
2007-02-18 12:19:38 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:19:38 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 12:19:38 information Video source original frame rate: 25,00
2007-02-18 12:19:38 information NTSC 29.97 FPS output format set by user
2007-02-18 12:19:38 information Widescreen (16:9) set automatically
2007-02-18 12:19:38 information Bitrate vidéo 0/2904/8808 Kbps (min/avg/max)
2007-02-18 12:19:38 information Conversion "D:\Apocalypse Now .mkv"
2007-02-18 12:19:38 information ----------------Titre #1----------------
2007-02-18 12:19:38 information Taille du projet 4,3 Gb. (271 Mb. audio - 4,03 Gb. video)
2007-02-18 12:19:38 information Stream #1 - Audio: vorbis, 44100 Hz, stereo
2007-02-18 12:19:38 information Stream #0 - Video: Real Video 10, 640x352, 1/25
2007-02-18 12:19:38 information 2 Stream(s) found - est. duration 03:13:59.278
2007-02-18 12:19:38 information Opening file "D:\Apocalypse Now .mkv"
2007-02-18 12:19:37 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:19:37 information [ ] Engine Log
2007-02-18 12:19:37 information Qualité de l'encodeur: 50%
2007-02-18 12:19:37 information --------------Encoding begin--------------
2007-02-18 12:19:37 information --------------Menu settings end--------------
2007-02-18 12:19:37 information [ ] Menu
2007-02-18 12:19:37 information --------------Menu settings begin--------------
2007-02-18 12:19:37 information --------------Default burn settings end--------------
2007-02-18 12:19:37 information Default speed selected: Max
2007-02-18 12:19:37 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:19:37 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:19:37 information [ ] Delete files after burn complete
2007-02-18 12:19:37 information [ ] Don't eject after burn complete
2007-02-18 12:19:37 information [X] Prefer SAO for DVD-R
2007-02-18 12:19:37 information [ ] Include originals
2007-02-18 12:19:37 information [ ] Burn result to DVD
2007-02-18 12:19:37 information --------------Default burn settings begin--------------
2007-02-18 12:19:28 information La version est à jour
2007-02-18 12:19:25 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:19:25 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:19:25 information Version 2.1.14.223
2007-02-18 12:19:25 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDVD.exe"
2007-02-18 12:19:25 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:19:24 information ******************** Report session started ********************
2007-02-18 12:18:50 information ********** Fin de la session ***********
2007-02-18 12:17:36 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:17:36 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:17:36 information Version 2.1.12.214
2007-02-18 12:17:36 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDvd.exe"
2007-02-18 12:17:36 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:17:35 information ******************** Report session started ********************
2007-02-18 12:17:28 information ********** Fin de la session ***********
2007-02-18 12:17:25 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:17:25 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:17:25 information Version 2.1.12.214
2007-02-18 12:17:25 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDvd.exe"
2007-02-18 12:17:25 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:17:25 information ******************** Report session started ********************
2007-02-18 12:17:22 information ********** Fin de la session ***********
2007-02-18 12:17:03 information --------------Encoding end--------------
2007-02-18 12:17:03 information Echec de la conversion en 00:00:00
2007-02-18 12:17:03 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:17:03 information Video Stream #0 framerate : 29,97 Fps (source 29,97 Fps), no pulldown
2007-02-18 12:17:03 information Padded source image : Left 0, Top 56, Right 0, Bottom 56
2007-02-18 12:17:03 information No pulldown: Frame duplication/removal will be used.
2007-02-18 12:17:03 information Video source original frame rate: 30,00
2007-02-18 12:17:03 information NTSC 29.97 FPS output format set by user
2007-02-18 12:17:03 information Widescreen (16:9) set automatically
2007-02-18 12:17:03 information Bitrate vidéo 0/6814/8308 Kbps (min/avg/max)
2007-02-18 12:17:03 information Conversion "D:\Pedale.dure.mkv"
2007-02-18 12:17:03 information ----------------Titre #1----------------
2007-02-18 12:17:03 information Taille du projet 4,3 Gb. (116 Mb. audio - 4,18 Gb. video)
2007-02-18 12:17:03 information Stream #1 - Audio: vorbis, 48000 Hz, stereo
2007-02-18 12:17:03 information Stream #0 - Video: Real Video 10, 640x272, 1/30
2007-02-18 12:17:03 information 2 Stream(s) found - est. duration 01:24:22.602
2007-02-18 12:17:03 information Opening file "D:\Pedale.dure.mkv"
2007-02-18 12:17:02 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:17:02 information [ ] Engine Log
2007-02-18 12:17:02 information Qualité de l'encodeur: 50%
2007-02-18 12:17:02 information --------------Encoding begin--------------
2007-02-18 12:17:02 information --------------Menu settings end--------------
2007-02-18 12:17:02 information [ ] Menu
2007-02-18 12:17:02 information --------------Menu settings begin--------------
2007-02-18 12:17:02 information --------------Default burn settings end--------------
2007-02-18 12:17:02 information Default speed selected: Max
2007-02-18 12:17:02 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:17:02 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:17:02 information [ ] Delete files after burn complete
2007-02-18 12:17:02 information [ ] Don't eject after burn complete
2007-02-18 12:17:02 information [X] Prefer SAO for DVD-R
2007-02-18 12:17:02 information [ ] Include originals
2007-02-18 12:17:02 information [ ] Burn result to DVD
2007-02-18 12:17:02 information --------------Default burn settings begin--------------
2007-02-18 12:16:54 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:16:54 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:16:54 information Version 2.1.12.214
2007-02-18 12:16:54 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDVD.exe"
2007-02-18 12:16:54 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:16:53 information ******************** Report session started ********************
2007-02-18 12:16:43 information ********** Fin de la session ***********
2007-02-18 12:15:54 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:15:54 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:15:54 information Version 2.1.12.214
2007-02-18 12:15:54 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDvd.exe"
2007-02-18 12:15:54 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:15:54 information ******************** Report session started ********************
2007-02-18 12:14:25 information ********** Fin de la session ***********
2007-02-18 12:14:05 information --------------Encoding end--------------
2007-02-18 12:14:02 information Echec de la conversion en 00:00:00
2007-02-18 12:14:02 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:14:02 information Video Stream #0 Pulldown : 23,976 -> 29,97 Fps
2007-02-18 12:14:01 information Video source original frame rate: 23,98
2007-02-18 12:14:01 information NTSC 29.97 FPS output format set by user
2007-02-18 12:14:01 information Widescreen (16:9) set automatically
2007-02-18 12:14:01 information Bitrate vidéo 0/8052/8052 Kbps (min/avg/max)
2007-02-18 12:14:01 information Conversion "D:\films normaux\c.r.a.z.y.2005.dvdrip.xvid.fragment.cd2.[sharethefiles.com].avi"
2007-02-18 12:14:01 information ----------------Titre #1----------------
2007-02-18 12:14:01 information Taille du projet 4,3 Gb. (202 Mb. audio - 4,1 Gb. video)
2007-02-18 12:14:01 information Stream #1 - Audio: ac3, 48000 Hz, 5:1, 448 kb/s
2007-02-18 12:14:01 information Stream #0 - Video: mpeg4, 640x352, 2733/65534
2007-02-18 12:14:01 information 2 Stream(s) found - est. duration 01:03:01.365
2007-02-18 12:14:01 information Opening file "D:\films normaux\c.r.a.z.y.2005.dvdrip.xvid.fragment.cd2.[sharethefiles.com].avi"
2007-02-18 12:14:01 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:14:01 information [ ] Engine Log
2007-02-18 12:14:01 information Qualité de l'encodeur: 50%
2007-02-18 12:14:01 information --------------Encoding begin--------------
2007-02-18 12:14:01 information --------------Menu settings end--------------
2007-02-18 12:14:01 information [ ] Menu
2007-02-18 12:14:01 information --------------Menu settings begin--------------
2007-02-18 12:14:01 information --------------Default burn settings end--------------
2007-02-18 12:14:01 information Default speed selected: Max
2007-02-18 12:14:01 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:14:01 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:14:01 information [ ] Delete files after burn complete
2007-02-18 12:14:01 information [ ] Don't eject after burn complete
2007-02-18 12:14:01 information [X] Prefer SAO for DVD-R
2007-02-18 12:14:01 information [ ] Include originals
2007-02-18 12:14:01 information [ ] Burn result to DVD
2007-02-18 12:14:01 information --------------Default burn settings begin--------------
2007-02-18 12:13:32 information --------------Encoding end--------------
2007-02-18 12:13:31 information Echec de la conversion en 00:00:00
2007-02-18 12:13:31 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:13:31 information Video Stream #0 framerate : 29,97 Fps (source 29,97 Fps), no pulldown
2007-02-18 12:13:31 information Padded source image : Left 16, Top 0, Right 16, Bottom 0
2007-02-18 12:13:31 information No pulldown: Frame duplication/removal will be used.
2007-02-18 12:13:31 information Video source original frame rate: 30,00
2007-02-18 12:13:31 information NTSC 29.97 FPS output format set by user
2007-02-18 12:13:31 information Widescreen (16:9) set automatically
2007-02-18 12:13:31 information Bitrate vidéo 0/6912/8308 Kbps (min/avg/max)
2007-02-18 12:13:31 information Conversion "D:\Les.Bronzes.Font.Du.Ski.mkv"
2007-02-18 12:13:31 information ----------------Titre #1----------------
2007-02-18 12:13:31 information Taille du projet 4,3 Gb. (114 Mb. audio - 4,19 Gb. video)
2007-02-18 12:13:31 information Stream #1 - Audio: vorbis, 48000 Hz, stereo
2007-02-18 12:13:31 information Stream #0 - Video: Real Video 10, 640x384, 1/30
2007-02-18 12:13:31 information 2 Stream(s) found - est. duration 01:23:12.753
2007-02-18 12:13:31 information Opening file "D:\Les.Bronzes.Font.Du.Ski.mkv"
2007-02-18 12:13:31 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:13:31 information [ ] Engine Log
2007-02-18 12:13:31 information Qualité de l'encodeur: 50%
2007-02-18 12:13:31 information --------------Encoding begin--------------
2007-02-18 12:13:31 information --------------Menu settings end--------------
2007-02-18 12:13:31 information [ ] Menu
2007-02-18 12:13:31 information --------------Menu settings begin--------------
2007-02-18 12:13:31 information --------------Default burn settings end--------------
2007-02-18 12:13:31 information Default speed selected: Max
2007-02-18 12:13:31 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:13:31 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:13:31 information [ ] Delete files after burn complete
2007-02-18 12:13:31 information [ ] Don't eject after burn complete
2007-02-18 12:13:31 information [X] Prefer SAO for DVD-R
2007-02-18 12:13:31 information [ ] Include originals
2007-02-18 12:13:31 information [ ] Burn result to DVD
2007-02-18 12:13:31 information --------------Default burn settings begin--------------
2007-02-18 12:12:37 information --------------Encoding end--------------
2007-02-18 12:12:29 information Echec de la conversion en 00:00:00
2007-02-18 12:12:29 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:12:29 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 12:12:29 information Video source original frame rate: 25,00
2007-02-18 12:12:29 information NTSC 29.97 FPS output format set by user
2007-02-18 12:12:29 information Widescreen (16:9) set automatically
2007-02-18 12:12:29 information Bitrate vidéo 0/2859/8308 Kbps (min/avg/max)
2007-02-18 12:12:29 information Conversion "D:\Apocalypse Now .mkv"
2007-02-18 12:12:29 information ----------------Titre #1----------------
2007-02-18 12:12:29 information Taille du projet 4,3 Gb. (266 Mb. audio - 4,04 Gb. video)
2007-02-18 12:12:29 information Stream #1 - Audio: vorbis, 44100 Hz, stereo
2007-02-18 12:12:29 information Stream #0 - Video: Real Video 10, 640x352, 1/25
2007-02-18 12:12:29 information 2 Stream(s) found - est. duration 03:13:59.278
2007-02-18 12:12:29 information Opening file "D:\Apocalypse Now .mkv"
2007-02-18 12:12:29 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:12:29 information [ ] Engine Log
2007-02-18 12:12:29 information Qualité de l'encodeur: 50%
2007-02-18 12:12:29 information --------------Encoding begin--------------
2007-02-18 12:12:29 information --------------Menu settings end--------------
2007-02-18 12:12:29 information [ ] Menu
2007-02-18 12:12:29 information --------------Menu settings begin--------------
2007-02-18 12:12:29 information --------------Default burn settings end--------------
2007-02-18 12:12:29 information Default speed selected: Max
2007-02-18 12:12:29 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:12:29 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:12:29 information [ ] Delete files after burn complete
2007-02-18 12:12:29 information [ ] Don't eject after burn complete
2007-02-18 12:12:29 information [X] Prefer SAO for DVD-R
2007-02-18 12:12:29 information [ ] Include originals
2007-02-18 12:12:29 information [ ] Burn result to DVD
2007-02-18 12:12:29 information --------------Default burn settings begin--------------
2007-02-18 12:09:37 information La version est à jour
2007-02-18 12:05:40 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:05:40 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:05:40 information Version 2.1.12.214
2007-02-18 12:05:40 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDVD.exe"
2007-02-18 12:05:40 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:05:40 information ******************** Report session started ********************
2007-02-18 12:56:28 information ********** Fin de la session ***********
2007-02-18 12:53:25 information --------------Encoding end--------------
2007-02-18 12:53:15 information Echec de la conversion en 00:00:00
2007-02-18 12:53:15 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:53:15 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 12:53:15 information Video source original frame rate: 25,00
2007-02-18 12:53:15 information NTSC 29.97 FPS output format set by user
2007-02-18 12:53:15 information Fullscreen (4:3) set automatically
2007-02-18 12:53:15 information Bitrate vidéo 0/8308/8308 Kbps (min/avg/max)
2007-02-18 12:53:15 information Conversion "I:\DOSSIER FRIENDS\10\S10 Ep1.avi"
2007-02-18 12:53:15 information ----------------Titre #1----------------
2007-02-18 12:53:15 information Taille du projet 4,3 Gb. (38,5 Mb. audio - 4,26 Gb. video)
2007-02-18 12:53:15 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 128 kb/s
2007-02-18 12:53:15 information Stream #0 - Video: mpeg4, 480x352, 1/30000
2007-02-18 12:53:15 information 2 Stream(s) found - est. duration 00:28:03.408
2007-02-18 12:53:15 information Opening file "I:\DOSSIER FRIENDS\10\S10 Ep1.avi"
2007-02-18 12:53:15 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:53:15 information [X] Engine Log
2007-02-18 12:53:15 information Qualité de l'encodeur: 50%
2007-02-18 12:53:15 information --------------Encoding begin--------------
2007-02-18 12:53:15 information --------------Menu settings end--------------
2007-02-18 12:53:15 information [ ] Menu
2007-02-18 12:53:15 information --------------Menu settings begin--------------
2007-02-18 12:53:15 information --------------Default burn settings end--------------
2007-02-18 12:53:15 information Default speed selected: Max
2007-02-18 12:53:15 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:53:15 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:53:15 information [ ] Delete files after burn complete
2007-02-18 12:53:15 information [ ] Don't eject after burn complete
2007-02-18 12:53:15 information [X] Prefer SAO for DVD-R
2007-02-18 12:53:15 information [ ] Include originals
2007-02-18 12:53:15 information [ ] Burn result to DVD
2007-02-18 12:53:15 information --------------Default burn settings begin--------------
2007-02-18 12:52:05 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:52:05 information [X] Engine Log
2007-02-18 12:52:05 information Qualité de l'encodeur: 50%
2007-02-18 12:52:05 information --------------Encoding begin--------------
2007-02-18 12:52:05 information --------------Menu settings end--------------
2007-02-18 12:52:05 information [ ] Menu
2007-02-18 12:52:05 information --------------Menu settings begin--------------
2007-02-18 12:52:05 information --------------Default burn settings end--------------
2007-02-18 12:52:05 information Default speed selected: Max
2007-02-18 12:52:05 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:52:05 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:52:05 information [ ] Delete files after burn complete
2007-02-18 12:52:05 information [ ] Don't eject after burn complete
2007-02-18 12:52:05 information [X] Prefer SAO for DVD-R
2007-02-18 12:52:05 information [ ] Include originals
2007-02-18 12:52:05 information [ ] Burn result to DVD
2007-02-18 12:52:05 information --------------Default burn settings begin--------------
2007-02-18 12:51:35 information --------------Encoding end--------------
2007-02-18 12:51:33 information Echec de la conversion en 00:00:00
2007-02-18 12:51:33 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:51:33 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 12:51:33 information Padded source image : Left 24, Top 0, Right 24, Bottom 0
2007-02-18 12:51:33 information Video source original frame rate: 25,00
2007-02-18 12:51:33 information NTSC 29.97 FPS output format set by user
2007-02-18 12:51:33 information Widescreen (16:9) set automatically
2007-02-18 12:51:33 information Bitrate vidéo 0/4099/8308 Kbps (min/avg/max)
2007-02-18 12:51:33 information Conversion "D:\Cyrano.de.Bergerac.mkv"
2007-02-18 12:51:33 information ----------------Titre #1----------------
2007-02-18 12:51:33 information Taille du projet 4,3 Gb. (189 Mb. audio - 4,11 Gb. video)
2007-02-18 12:51:33 information Stream #1 - Audio: aac, 44100 Hz, stereo
2007-02-18 12:51:33 information Stream #0 - Video: Real Video 10, 600x360, 1/25
2007-02-18 12:51:33 information 2 Stream(s) found - est. duration 02:17:51.598
2007-02-18 12:51:33 information Opening file "D:\Cyrano.de.Bergerac.mkv"
2007-02-18 12:51:33 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:51:33 information [X] Engine Log
2007-02-18 12:51:33 information Qualité de l'encodeur: 50%
2007-02-18 12:51:33 information --------------Encoding begin--------------
2007-02-18 12:51:33 information --------------Menu settings end--------------
2007-02-18 12:51:33 information [ ] Menu
2007-02-18 12:51:33 information --------------Menu settings begin--------------
2007-02-18 12:51:33 information --------------Default burn settings end--------------
2007-02-18 12:51:33 information Default speed selected: Max
2007-02-18 12:51:33 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:51:33 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:51:33 information [ ] Delete files after burn complete
2007-02-18 12:51:33 information [ ] Don't eject after burn complete
2007-02-18 12:51:33 information [X] Prefer SAO for DVD-R
2007-02-18 12:51:33 information [ ] Include originals
2007-02-18 12:51:33 information [ ] Burn result to DVD
2007-02-18 12:51:33 information --------------Default burn settings begin--------------
2007-02-18 12:44:27 information --------------Encoding end--------------
2007-02-18 12:44:26 information Echec de la conversion en 00:00:10
2007-02-18 12:44:26 information User cancellation requested
2007-02-18 12:44:16 information Stream #1 Sync. delay : 0,00 ms
2007-02-18 12:44:16 information Stream #0 Sync. delay : 0,00 ms
2007-02-18 12:44:16 information Output Stream#1 - Audio: ac3, 48000 Hz, 5:1, 448 kb/s, no automatic gain control
2007-02-18 12:44:16 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x480, 1/25, q=2-31, 5799 kb/s
2007-02-18 12:44:16 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 12:44:16 information Padded source image : Left 0, Top 56, Right 0, Bottom 56
2007-02-18 12:44:16 information Video source original frame rate: 25,00
2007-02-18 12:44:16 information NTSC 29.97 FPS output format set by user
2007-02-18 12:44:16 information Widescreen (16:9) set automatically
2007-02-18 12:44:16 information Bitrate vidéo 0/5799/8052 Kbps (min/avg/max)
2007-02-18 12:44:16 information Conversion "D:\OSS.117.mkv"
2007-02-18 12:44:16 information ----------------Titre #1----------------
2007-02-18 12:44:16 information Taille du projet 4,3 Gb. (304 Mb. audio - 4 Gb. video)
2007-02-18 12:44:16 information Stream #1 - Audio: aac, 48000 Hz, 5:1
2007-02-18 12:44:16 information Stream #0 - Video: h264, yuv420p, 704x304, 1/25
2007-02-18 12:44:16 information 2 Stream(s) found - est. duration 01:34:48.320
2007-02-18 12:44:16 information Opening file "D:\OSS.117.mkv"
2007-02-18 12:44:15 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:44:15 information [X] Engine Log
2007-02-18 12:44:15 information Qualité de l'encodeur: 50%
2007-02-18 12:44:15 information --------------Encoding begin--------------
2007-02-18 12:44:15 information --------------Menu settings end--------------
2007-02-18 12:44:15 information [ ] Menu
2007-02-18 12:44:15 information --------------Menu settings begin--------------
2007-02-18 12:44:15 information --------------Default burn settings end--------------
2007-02-18 12:44:15 information Default speed selected: Max
2007-02-18 12:44:15 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:44:15 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:44:15 information [ ] Delete files after burn complete
2007-02-18 12:44:15 information [ ] Don't eject after burn complete
2007-02-18 12:44:15 information [X] Prefer SAO for DVD-R
2007-02-18 12:44:15 information [ ] Include originals
2007-02-18 12:44:15 information [ ] Burn result to DVD
2007-02-18 12:44:15 information --------------Default burn settings begin--------------
2007-02-18 12:43:55 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:43:55 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:43:55 information Version 2.1.12.214
2007-02-18 12:43:55 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
2007-02-18 12:43:55 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:43:55 information ******************** Report session started ********************
2007-02-18 12:43:46 information ********** Fin de la session ***********
2007-02-18 12:43:02 information --------------Encoding end--------------
2007-02-18 12:43:01 information Echec de la conversion en 00:00:00
2007-02-18 12:43:01 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:43:01 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 12:43:01 information Video source original frame rate: 25,00
2007-02-18 12:43:01 information NTSC 29.97 FPS output format set by user
2007-02-18 12:43:01 information Widescreen (16:9) set automatically
2007-02-18 12:43:01 information Bitrate vidéo 0/2859/8308 Kbps (min/avg/max)
2007-02-18 12:43:01 information Conversion "D:\Apocalypse Now .mkv"
2007-02-18 12:43:01 information ----------------Titre #1----------------
2007-02-18 12:43:01 information Taille du projet 4,3 Gb. (266 Mb. audio - 4,04 Gb. video)
2007-02-18 12:43:01 information Stream #1 - Audio: vorbis, 44100 Hz, stereo
2007-02-18 12:43:01 information Stream #0 - Video: Real Video 10, 640x352, 1/25
2007-02-18 12:43:01 information 2 Stream(s) found - est. duration 03:13:59.278
2007-02-18 12:43:01 information Opening file "D:\Apocalypse Now .mkv"
2007-02-18 12:42:59 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:42:59 information [X] Engine Log
2007-02-18 12:42:59 information Qualité de l'encodeur: 50%
2007-02-18 12:42:59 information --------------Encoding begin--------------
2007-02-18 12:42:59 information --------------Menu settings end--------------
2007-02-18 12:42:59 information [ ] Menu
2007-02-18 12:42:59 information --------------Menu settings begin--------------
2007-02-18 12:42:59 information --------------Default burn settings end--------------
2007-02-18 12:42:59 information Default speed selected: Max
2007-02-18 12:42:59 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:42:59 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:42:59 information [ ] Delete files after burn complete
2007-02-18 12:42:59 information [ ] Don't eject after burn complete
2007-02-18 12:42:59 information [X] Prefer SAO for DVD-R
2007-02-18 12:42:59 information [ ] Include originals
2007-02-18 12:42:59 information [ ] Burn result to DVD
2007-02-18 12:42:59 information --------------Default burn settings begin--------------
2007-02-18 12:41:22 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:41:22 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:41:22 information Version 2.1.12.214
2007-02-18 12:41:22 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDVD.exe"
2007-02-18 12:41:22 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:41:21 information ******************** Report session started ********************
2007-02-18 12:32:17 information ********** Fin de la session ***********
2007-02-18 12:32:09 information --------------Encoding end--------------
2007-02-18 12:32:08 information Echec de la conversion en 00:00:00
2007-02-18 12:32:08 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:32:08 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 12:32:08 information Video source original frame rate: 25,00
2007-02-18 12:32:08 information NTSC 29.97 FPS output format set by user
2007-02-18 12:32:08 information Widescreen (16:9) set automatically
2007-02-18 12:32:08 information Bitrate vidéo 0/2859/8308 Kbps (min/avg/max)
2007-02-18 12:32:08 information Conversion "D:\Apocalypse Now .mkv"
2007-02-18 12:32:08 information ----------------Titre #1----------------
2007-02-18 12:32:08 information Taille du projet 4,3 Gb. (266 Mb. audio - 4,04 Gb. video)
2007-02-18 12:32:08 information Stream #1 - Audio: vorbis, 44100 Hz, stereo
2007-02-18 12:32:08 information Stream #0 - Video: Real Video 10, 640x352, 1/25
2007-02-18 12:32:08 information 2 Stream(s) found - est. duration 03:13:59.278
2007-02-18 12:32:08 information Opening file "D:\Apocalypse Now .mkv"
2007-02-18 12:32:07 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:32:07 information [X] Engine Log
2007-02-18 12:32:07 information Qualité de l'encodeur: 50%
2007-02-18 12:32:07 information --------------Encoding begin--------------
2007-02-18 12:32:07 information --------------Menu settings end--------------
2007-02-18 12:32:07 information [ ] Menu
2007-02-18 12:32:07 information --------------Menu settings begin--------------
2007-02-18 12:32:07 information --------------Default burn settings end--------------
2007-02-18 12:32:07 information Default speed selected: Max
2007-02-18 12:32:07 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:32:07 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:32:07 information [ ] Delete files after burn complete
2007-02-18 12:32:07 information [ ] Don't eject after burn complete
2007-02-18 12:32:07 information [X] Prefer SAO for DVD-R
2007-02-18 12:32:07 information [ ] Include originals
2007-02-18 12:32:07 information [ ] Burn result to DVD
2007-02-18 12:32:07 information --------------Default burn settings begin--------------
2007-02-18 12:31:58 information La version est à jour
2007-02-18 12:31:44 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:31:44 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:31:44 information Version 2.1.12.214
2007-02-18 12:31:44 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDVD.exe"
2007-02-18 12:31:44 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:31:43 information ******************** Report session started ********************
2007-02-18 12:29:47 information ********** Fin de la session ***********
2007-02-18 12:29:46 information --------------Encoding end--------------
2007-02-18 12:29:45 information Echec de la conversion en 00:00:00
2007-02-18 12:29:45 Erreur Error while opening decoder for stream #0.0
2007-02-18 12:29:45 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 12:29:45 information Video source original frame rate: 25,00
2007-02-18 12:29:45 information NTSC 29.97 FPS output format set by user
2007-02-18 12:29:45 information Widescreen (16:9) set automatically
2007-02-18 12:29:45 information Bitrate vidéo 0/2904/8808 Kbps (min/avg/max)
2007-02-18 12:29:45 information Conversion "D:\Apocalypse Now .mkv"
2007-02-18 12:29:45 information ----------------Titre #1----------------
2007-02-18 12:29:45 information Taille du projet 4,3 Gb. (271 Mb. audio - 4,03 Gb. video)
2007-02-18 12:29:44 information Stream #1 - Audio: vorbis, 44100 Hz, stereo
2007-02-18 12:29:44 information Stream #0 - Video: Real Video 10, 640x352, 1/25
2007-02-18 12:29:44 information 2 Stream(s) found - est. duration 03:13:59.278
2007-02-18 12:29:44 information Opening file "D:\Apocalypse Now .mkv"
2007-02-18 12:29:43 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 12:29:43 information [X] Engine Log
2007-02-18 12:29:43 information Qualité de l'encodeur: 50%
2007-02-18 12:29:43 information --------------Encoding begin--------------
2007-02-18 12:29:43 information --------------Menu settings end--------------
2007-02-18 12:29:43 information [ ] Menu
2007-02-18 12:29:43 information --------------Menu settings begin--------------
2007-02-18 12:29:43 information --------------Default burn settings end--------------
2007-02-18 12:29:43 information Default speed selected: Max
2007-02-18 12:29:43 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 12:29:43 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 12:29:43 information [ ] Delete files after burn complete
2007-02-18 12:29:43 information [ ] Don't eject after burn complete
2007-02-18 12:29:43 information [X] Prefer SAO for DVD-R
2007-02-18 12:29:43 information [ ] Include originals
2007-02-18 12:29:43 information [ ] Burn result to DVD
2007-02-18 12:29:43 information --------------Default burn settings begin--------------
2007-02-18 12:29:23 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:29:23 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 12:29:23 information Version 2.1.14.223
2007-02-18 12:29:23 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDvd.exe"
2007-02-18 12:29:23 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 12:29:22 information ******************** Report session started ********************
2007-02-18 10:00:59 information ********** Fin de la session ***********
2007-02-18 10:00:56 information --------------Encoding end--------------
2007-02-18 10:00:50 information Echec de la conversion en 00:00:00
2007-02-18 10:00:50 Erreur Error while opening decoder for stream #0.0
2007-02-18 10:00:50 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 10:00:50 information Padded source image : Left 0, Top 56, Right 0, Bottom 56
2007-02-18 10:00:50 information Video source original frame rate: 25,00
2007-02-18 10:00:50 information NTSC 29.97 FPS output format set by user
2007-02-18 10:00:50 information Widescreen (16:9) set automatically
2007-02-18 10:00:50 information Bitrate vidéo 0/3502/8808 Kbps (min/avg/max)
2007-02-18 10:00:50 information Conversion "D:\Scarface .mkv"
2007-02-18 10:00:50 information ----------------Titre #1----------------
2007-02-18 10:00:50 information Taille du projet 4,3 Gb. (228 Mb. audio - 4,07 Gb. video)
2007-02-18 10:00:50 information Stream #1 - Audio: vorbis, 48000 Hz, stereo
2007-02-18 10:00:50 information Stream #0 - Video: Real Video 10, 704x304, 1/25
2007-02-18 10:00:50 information 2 Stream(s) found - est. duration 02:42:54.384
2007-02-18 10:00:50 information Opening file "D:\Scarface .mkv"
2007-02-18 10:00:50 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 10:00:50 information [X] Engine Log
2007-02-18 10:00:50 information Qualité de l'encodeur: 50%
2007-02-18 10:00:50 information --------------Encoding begin--------------
2007-02-18 10:00:50 information --------------Menu settings end--------------
2007-02-18 10:00:50 information [ ] Menu
2007-02-18 10:00:50 information --------------Menu settings begin--------------
2007-02-18 10:00:50 information --------------Default burn settings end--------------
2007-02-18 10:00:50 information Default speed selected: Max
2007-02-18 10:00:50 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 10:00:50 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 10:00:50 information [ ] Delete files after burn complete
2007-02-18 10:00:50 information [ ] Don't eject after burn complete
2007-02-18 10:00:50 information [X] Prefer SAO for DVD-R
2007-02-18 10:00:50 information [ ] Include originals
2007-02-18 10:00:50 information [ ] Burn result to DVD
2007-02-18 10:00:50 information --------------Default burn settings begin--------------
2007-02-18 10:00:21 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 10:00:21 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 10:00:21 information Version 2.1.14.223
2007-02-18 10:00:21 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDvd.exe"
2007-02-18 10:00:21 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 10:00:20 information ******************** Report session started ********************
2007-02-18 09:59:43 information ********** Fin de la session ***********
2007-02-18 09:53:33 information --------------Encoding end--------------
2007-02-18 09:53:26 information Echec de la conversion en 00:00:00
2007-02-18 09:53:26 Erreur Error while opening decoder for stream #0.0
2007-02-18 09:53:26 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 09:53:26 information Video source original frame rate: 25,00
2007-02-18 09:53:26 information NTSC 29.97 FPS output format set by user
2007-02-18 09:53:26 information Widescreen (16:9) set automatically
2007-02-18 09:53:26 information Bitrate vidéo 0/3712/8808 Kbps (min/avg/max)
2007-02-18 09:53:26 information Conversion "D:\films normaux\the.Substitute.3.avi"
2007-02-18 09:53:26 information ----------------Titre #1----------------
2007-02-18 09:53:26 information Taille du projet 4,3 Gb. (329 Mb. audio - 3,98 Gb. video)
2007-02-18 09:53:26 information Stream #1 - Audio: ac3, 48000 Hz, 5:1, 448 kb/s
2007-02-18 09:53:26 information Stream #0 - Video: mpeg4, 640x352, 2733/65534
2007-02-18 09:53:26 information 2 Stream(s) found - est. duration 01:03:54.835
2007-02-18 09:53:26 information Opening file "D:\films normaux\c.r.a.z.y.2005.dvdrip.xvid.fragment.cd1.[sharethefiles.com].avi"
2007-02-18 09:53:25 information Stream #1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
2007-02-18 09:53:25 information Stream #0 - Video: mpeg4, 704x392, 1/25
2007-02-18 09:53:25 information 2 Stream(s) found - est. duration 01:26:08.040
2007-02-18 09:53:25 information Opening file "D:\films normaux\the.Substitute.3.avi"
2007-02-18 09:53:24 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 09:53:24 information [X] Engine Log
2007-02-18 09:53:24 information Qualité de l'encodeur: 50%
2007-02-18 09:53:24 information --------------Encoding begin--------------
2007-02-18 09:53:24 information --------------Menu settings end--------------
2007-02-18 09:53:24 information [ ] Menu
2007-02-18 09:53:24 information --------------Menu settings begin--------------
2007-02-18 09:53:24 information --------------Default burn settings end--------------
2007-02-18 09:53:24 information Default speed selected: Max
2007-02-18 09:53:24 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 09:53:24 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 09:53:24 information [ ] Delete files after burn complete
2007-02-18 09:53:24 information [ ] Don't eject after burn complete
2007-02-18 09:53:24 information [X] Prefer SAO for DVD-R
2007-02-18 09:53:24 information [ ] Include originals
2007-02-18 09:53:24 information [ ] Burn result to DVD
2007-02-18 09:53:24 information --------------Default burn settings begin--------------
2007-02-18 09:53:07 information --------------Encoding end--------------
2007-02-18 09:53:03 information Echec de la conversion en 00:00:00
2007-02-18 09:53:03 Erreur Error while opening decoder for stream #0.0
2007-02-18 09:53:03 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 09:53:03 information Video source original frame rate: 25,00
2007-02-18 09:53:03 information NTSC 29.97 FPS output format set by user
2007-02-18 09:53:03 information Widescreen (16:9) set automatically
2007-02-18 09:53:03 information Bitrate vidéo 0/6826/8808 Kbps (min/avg/max)
2007-02-18 09:53:03 information Conversion "D:\films normaux\the.Substitute.3.avi"
2007-02-18 09:53:03 information ----------------Titre #1----------------
2007-02-18 09:53:03 information Taille du projet 4,3 Gb. (120 Mb. audio - 4,18 Gb. video)
2007-02-18 09:53:03 information Stream #1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
2007-02-18 09:53:03 information Stream #0 - Video: mpeg4, 704x392, 1/25
2007-02-18 09:53:03 information 2 Stream(s) found - est. duration 01:26:08.040
2007-02-18 09:53:03 information Opening file "D:\films normaux\the.Substitute.3.avi"
2007-02-18 09:53:02 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 09:53:02 information [X] Engine Log
2007-02-18 09:53:02 information Qualité de l'encodeur: 50%
2007-02-18 09:53:02 information --------------Encoding begin--------------
2007-02-18 09:53:02 information --------------Menu settings end--------------
2007-02-18 09:53:02 information [ ] Menu
2007-02-18 09:53:02 information --------------Menu settings begin--------------
2007-02-18 09:53:02 information --------------Default burn settings end--------------
2007-02-18 09:53:02 information Default speed selected: Max
2007-02-18 09:53:02 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 09:53:02 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 09:53:02 information [ ] Delete files after burn complete
2007-02-18 09:53:02 information [ ] Don't eject after burn complete
2007-02-18 09:53:02 information [X] Prefer SAO for DVD-R
2007-02-18 09:53:02 information [ ] Include originals
2007-02-18 09:53:02 information [ ] Burn result to DVD
2007-02-18 09:53:02 information --------------Default burn settings begin--------------
2007-02-18 09:52:11 information --------------Encoding end--------------
2007-02-18 09:52:04 information Echec de la conversion en 00:00:00
2007-02-18 09:52:04 Erreur Error while opening decoder for stream #0.0
2007-02-18 09:52:04 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 09:52:04 information Video source original frame rate: 25,00
2007-02-18 09:52:04 information NTSC 29.97 FPS output format set by user
2007-02-18 09:52:04 information Widescreen (16:9) set automatically
2007-02-18 09:52:04 information Bitrate vidéo 0/6826/8808 Kbps (min/avg/max)
2007-02-18 09:52:04 information Conversion "D:\films normaux\the.Substitute.3.avi"
2007-02-18 09:52:04 information ----------------Titre #1----------------
2007-02-18 09:52:04 information Taille du projet 4,3 Gb. (120 Mb. audio - 4,18 Gb. video)
2007-02-18 09:52:04 information Stream #1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
2007-02-18 09:52:04 information Stream #0 - Video: mpeg4, 704x392, 1/25
2007-02-18 09:52:04 information 2 Stream(s) found - est. duration 01:26:08.040
2007-02-18 09:52:04 information Opening file "D:\films normaux\the.Substitute.3.avi"
2007-02-18 09:52:04 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 09:52:04 information [X] Engine Log
2007-02-18 09:52:04 information Qualité de l'encodeur: 50%
2007-02-18 09:52:04 information --------------Encoding begin--------------
2007-02-18 09:52:04 information --------------Menu settings end--------------
2007-02-18 09:52:04 information [ ] Menu
2007-02-18 09:52:04 information --------------Menu settings begin--------------
2007-02-18 09:52:04 information --------------Default burn settings end--------------
2007-02-18 09:52:04 information Default speed selected: Max
2007-02-18 09:52:04 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 09:52:04 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 09:52:04 information [ ] Delete files after burn complete
2007-02-18 09:52:04 information [ ] Don't eject after burn complete
2007-02-18 09:52:04 information [X] Prefer SAO for DVD-R
2007-02-18 09:52:04 information [ ] Include originals
2007-02-18 09:52:04 information [ ] Burn result to DVD
2007-02-18 09:52:04 information --------------Default burn settings begin--------------
2007-02-18 09:51:37 information --------------Encoding end--------------
2007-02-18 09:51:36 information Echec de la conversion en 00:00:00
2007-02-18 09:51:36 Erreur Error while opening decoder for stream #0.0
2007-02-18 09:51:36 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 09:51:35 information Video source original frame rate: 25,00
2007-02-18 09:51:35 information NTSC 29.97 FPS output format set by user
2007-02-18 09:51:35 information Widescreen (16:9) set automatically
2007-02-18 09:51:35 information Bitrate vidéo 0/2904/8808 Kbps (min/avg/max)
2007-02-18 09:51:35 information Conversion "D:\Apocalypse Now .mkv"
2007-02-18 09:51:35 information ----------------Titre #1----------------
2007-02-18 09:51:35 information Taille du projet 4,3 Gb. (271 Mb. audio - 4,03 Gb. video)
2007-02-18 09:51:35 information Stream #1 - Audio: vorbis, 44100 Hz, stereo
2007-02-18 09:51:35 information Stream #0 - Video: Real Video 10, 640x352, 1/25
2007-02-18 09:51:35 information 2 Stream(s) found - est. duration 03:13:59.278
2007-02-18 09:51:35 information Opening file "D:\Apocalypse Now .mkv"
2007-02-18 09:51:33 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 09:51:33 information [X] Engine Log
2007-02-18 09:51:33 information Qualité de l'encodeur: 50%
2007-02-18 09:51:33 information --------------Encoding begin--------------
2007-02-18 09:51:33 information --------------Menu settings end--------------
2007-02-18 09:51:33 information [ ] Menu
2007-02-18 09:51:33 information --------------Menu settings begin--------------
2007-02-18 09:51:33 information --------------Default burn settings end--------------
2007-02-18 09:51:33 information Default speed selected: Max
2007-02-18 09:51:33 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 09:51:33 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F] (Ide)
2007-02-18 09:51:33 information [ ] Delete files after burn complete
2007-02-18 09:51:33 information [ ] Don't eject after burn complete
2007-02-18 09:51:33 information [X] Prefer SAO for DVD-R
2007-02-18 09:51:33 information [ ] Include originals
2007-02-18 09:51:33 information [ ] Burn result to DVD
2007-02-18 09:51:33 information --------------Default burn settings begin--------------
2007-02-18 09:51:22 information User default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 09:51:22 information System default language : 3084 (0x0C0Ch) - French (Canadian)
2007-02-18 09:51:22 information Version 2.1.14.223
2007-02-18 09:51:22 information ExeName : "H:\ConvertXtoDVD\ConvertXtoDvd.exe"
2007-02-18 09:51:22 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
2007-02-18 09:51:21 information ******************** Report session started ********************
2007-02-18 09:45:58 information ********** Fin de la session ***********
2007-02-18 09:45:56 information --------------Encoding end--------------
2007-02-18 09:45:55 information Echec de la conversion en 00:00:00
2007-02-18 09:45:55 Erreur Error while opening decoder for stream #0.0
2007-02-18 09:45:55 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 09:45:55 information Padded source image : Left 0, Top 56, Right 0, Bottom 56
2007-02-18 09:45:55 information Video source original frame rate: 25,00
2007-02-18 09:45:55 information NTSC 29.97 FPS output format set by user
2007-02-18 09:45:55 information Widescreen (16:9) set automatically
2007-02-18 09:45:55 information Bitrate vidéo 0/4721/8808 Kbps (min/avg/max)
2007-02-18 09:45:55 information Conversion "D:\les.brigades.du.tigre.mkv"
2007-02-18 09:45:55 information ----------------Titre #1----------------
2007-02-18 09:45:55 information Taille du projet 4,3 Gb. (172 Mb. audio - 4,13 Gb. video)
2007-02-18 09:45:55 information Stream #1 - Audio: vorbis, 48000 Hz, stereo
2007-02-18 09:45:55 information Stream #0 - Video: Real Video 10, 704x304, 1/25
2007-02-18 09:45:55 information 2 Stream(s) found - est. duration 02:02:47.088
2007-02-18 09:45:55 information Opening file "D:\les.brigades.du.tigre.mkv"
2007-02-18 09:45:55 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 09:45:55 information [X] Engine Log
2007-02-18 09:45:55 information Qualité de l'encodeur: 50%
2007-02-18 09:45:55 information --------------Encoding begin--------------
2007-02-18 09:45:55 information --------------Menu settings end--------------
2007-02-18 09:45:55 information [ ] Menu
2007-02-18 09:45:55 information --------------Menu settings begin--------------
2007-02-18 09:45:55 information --------------Default burn settings end--------------
2007-02-18 09:45:55 information Default speed selected: Max
2007-02-18 09:45:55 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 09:45:55 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F]
2007-02-18 09:45:55 information [ ] Delete files after burn complete
2007-02-18 09:45:55 information [ ] Don't eject after burn complete
2007-02-18 09:45:55 information [X] Prefer SAO for DVD-R
2007-02-18 09:45:55 information [ ] Include originals
2007-02-18 09:45:55 information [ ] Burn result to DVD
2007-02-18 09:45:55 information --------------Default burn settings begin--------------
2007-02-18 09:45:35 information --------------Encoding end--------------
2007-02-18 09:45:29 information Echec de la conversion en 00:00:00
2007-02-18 09:45:29 Erreur Error while opening decoder for stream #0.0
2007-02-18 09:45:29 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 09:45:29 information Video source original frame rate: 25,00
2007-02-18 09:45:29 information NTSC 29.97 FPS output format set by user
2007-02-18 09:45:29 information Widescreen (16:9) set automatically
2007-02-18 09:45:29 information Bitrate vidéo 0/5454/8808 Kbps (min/avg/max)
2007-02-18 09:45:29 information Conversion "D:\Bonnie and Clyde.mkv"
2007-02-18 09:45:29 information ----------------Titre #1----------------
2007-02-18 09:45:29 information Taille du projet 4,3 Gb. (149 Mb. audio - 4,15 Gb. video)
2007-02-18 09:45:29 information Stream #1 - Audio: aac, 48000 Hz, mono
2007-02-18 09:45:29 information Stream #0 - Video: Real Video 10, 704x384, 1/25
2007-02-18 09:45:29 information 2 Stream(s) found - est. duration 01:46:56.600
2007-02-18 09:45:29 information Opening file "D:\Bonnie and Clyde.mkv"
2007-02-18 09:45:29 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 09:45:29 information [X] Engine Log
2007-02-18 09:45:29 information Qualité de l'encodeur: 50%
2007-02-18 09:45:29 information --------------Encoding begin--------------
2007-02-18 09:45:29 information --------------Menu settings end--------------
2007-02-18 09:45:29 information [ ] Menu
2007-02-18 09:45:29 information --------------Menu settings begin--------------
2007-02-18 09:45:29 information --------------Default burn settings end--------------
2007-02-18 09:45:29 information Default speed selected: Max
2007-02-18 09:45:29 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2007-02-18 09:45:29 information New Drive selected : 1:0:0 - PIONEER DVD-RW DVR-110D 1.37 [F]
2007-02-18 09:45:29 information [ ] Delete files after burn complete
2007-02-18 09:45:29 information [ ] Don't eject after burn complete
2007-02-18 09:45:29 information [X] Prefer SAO for DVD-R
2007-02-18 09:45:29 information [ ] Include originals
2007-02-18 09:45:29 information [ ] Burn result to DVD
2007-02-18 09:45:29 information --------------Default burn settings begin--------------
2007-02-18 09:37:09 information --------------Encoding end--------------
2007-02-18 09:37:08 information Echec de la conversion en 00:00:00
2007-02-18 09:37:08 Erreur Error while opening decoder for stream #0.0
2007-02-18 09:37:08 information Video Stream #0 Pulldown : 25,000 -> 29,97 Fps
2007-02-18 09:37:07 information Video source original frame rate: 25,00
2007-02-18 09:37:07 information NTSC 29.97 FPS output format set by user
2007-02-18 09:37:07 information Widescreen (16:9) set automatically
2007-02-18 09:37:07 information Bitrate vidéo 0/2904/8808 Kbps (min/avg/max)
2007-02-18 09:37:07 information Conversion "D:\Apocalypse Now .mkv"
2007-02-18 09:37:07 information ----------------Titre #1----------------
2007-02-18 09:37:07 information Taille du projet 4,3 Gb. (271 Mb. audio - 4,03 Gb. video)
2007-02-18 09:37:07 information Stream #1 - Audio: vorbis, 44100 Hz, stereo
2007-02-18 09:37:07 information Stream #0 - Video: Real Video 10, 640x352, 1/25
2007-02-18 09:37:07 information 2 Stream(s) found - est. duration 03:13:59.278
2007-02-18 09:37:07 information Opening file "D:\Apocalypse Now .mkv"
2007-02-18 09:37:06 information [ ] Ne pas réparer les "trous" dans l'audio
2007-02-18 09:37:06 information [X] Engine Log
2007-02-18 09:37:06 information Qualité de l'encodeur: 50%
2007-02-18 09:37:06 information --------------Encoding begin--------------
2007-02-18 09:37:06 information --------------Menu settings end--------------
2007-02-18 09:37:06 information [ ] Menu
2007-02-18 09:37:06 information --------------Menu settings begin--------------
2007-02-18 09:37:06 information --------------Default burn settings end--------------
2007-02-18 09:37:06 information Default speed selected: Max
2007-02-18 09:37:06 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD
quebecor
Messagepar Laddyc » 19 Fév 2007 6:46
bonjour
avez vous installer directx ?
les codecs real sont ils installés ?
Messagepar Laddyc » 19 Fév 2007 10:18
Couleur78 a ecrit
J'ai testé la dernière version 2.1.14.223
Pour les fichiers MKV avec
  • Vidéo: Real Video 10 ne fonctionne toujours pas :twisted:
  • Vidéo: h264 fonctionne correctement
Pour les fichiers AVI tout est OK
le éieux serait de revenir à la vesion 2.1.5 qui supportait les fichiers mkv
Messagepar bowling » 19 Fév 2007 23:23
Où peut on récupérer la version qui marchait ?
Personne ne m'a encore répondu à cette question, même pas l'assistance de VSO
J'ai le même log que l'auteur de la contribution.
Je n'ai plus les anciennes versions ! Comment faire car j'ai quand même acheté un produit qui ne fonctionne pas (mais qui fonctionnait avant que je fasse l'erreur de le mettre à jour !!!!
Merci de la réponse
René
bowling
Messagepar Laddyc » 20 Fév 2007 7:59
un petit mail à claire [at]vso-software.fr
en cherchant ds les sujets tu devrais retrouver la bonne version qui fonctionnait av les MKv
Messagepar quebecor » 22 Fév 2007 23:03
bon, ben, ca marche.
j'ai trouve la derniere version sur le net.
ca passe bien et directx est installe sans doute car je n'ai plus l'erreur decrite plus haut.
meme mon mkv recalcitrant passe du 1er coup.
reste a voir le resultat fini.
merci quand meme du mal que vous etes donne.
a bientot.
quebecor
Messagepar cougar_ii » 23 Fév 2007 1:13
quebecor a écrit:bon, ben, ca marche.
Humm j'aurais aimer mieux lire:
J'ai téléchargé la dernière version sur le site internet de VSO Software, que je l'ai trouvé sur le NET :doh:
cougar_ii
[VSO] Client En Or
Messagepar quebecor » 04 Mar 2007 19:56
J'ai téléchargé la dernière version sur le site internet de VSO Software, que je l'ai trouvé sur le NET :doh:[/quote]
et voila pour faire plaisir a mr cougar.
mais le probleme, que j'ai pas reussi a regler a ce jour, c'est que je ne peux pas encoder de mkv en rv9.
pour ceux en x264, tout marche ben.
pouvez vous me dire s'il y a une solution a ca.
merci d'avance car je suis oblige de re-encoder en x264 et ca prend plus de temps.
merci et a bientot.
quebecor
Messagepar Laddyc » 05 Mar 2007 7:29
Laddyc a écrit:un petit mail à claire [at]vso-software.fr
