probleme de gravure
probleme de gravure
Messagepar canelle29 » 05 Sep 2008 22:45
probleme de gravure avec dvd shrink+nero6
graveur NEC DVD RW ND63500 AG
message d'erreur ci joint
1A20-xxxxxxxxxxxxxxxxxx
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 12:06:00
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 18:18:04
Nero API version: 6.3.0.2
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <_NEC DVD_RW ND-3500AG> Version: 2.1B - HA 1 TA 0 - 6.3.0.2
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
DiskPeripheral : Maxtor 6Y120P0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-3500AG atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SAMSUNG DVD-ROM SD-616E atapi Port 1 ID 1 DMA: On
CdRomPeripheral : ELBY CLONEDRIVE 1.1 VClone Port 3 ID 0 DMA: Off
_NEC DVD_RW ND-3500AG D: CDRom0
SAMSUNG DVD-ROM SD-616E E: CDRom1
ELBY CLONEDRIVE G: CDRom2
CmdQueuing : 1
CmdNotification: 2
EraseSpeed : 0
Physical memory : 510MB (523056kB)
Free physical memory: 124MB (127708kB)
Memory in use : 75 %
5.9.2008
NeroAPI
10:36:39 #1 Phase 112 File APIProgress.cpp, Line 253
10:36:39 #2 Phase 114 File APIProgress.cpp, Line 253
10:36:39 #3 Phase 111 File APIProgress.cpp, Line 253
DVD-Video files sorted
10:36:40 #4 Text 0 File Reader.cpp, Line 118
10:36:40 #5 Text 0 File Writer.cpp, Line 124
Writer _NEC DVD_RW ND-3500AG running
10:36:40 #6 ISO9660GEN -11 File geniso.cpp, Line 3882
10:36:40 #7 ISO9660GEN -11 File geniso.cpp, Line 3882
10:36:40 #8 Text 0 File Burncd.cpp, Line 3101
10:43:36 #9 Text 0 File DlgWaitCD.cpp, Line 240
Last address to be written: 2184500 (485:26.50, 4266MB)
10:43:36 #10 Text 0 File DlgWaitCD.cpp, Line 245
10:43:36 #11 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: _NEC DVD_RW ND-3500AG, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
10:43:36 #12 Text 0 File DlgWaitCD.cpp, Line 406
(Medium in drive: unknown. Medium required by compilation: DVD+R/RW; DVD-R/RW; DVD+R9 Dual Layer.)
10:43:36 #13 Text 0 File ThreadedTransferInterface.cpp, Line 779
original disc pos #0 + 2184501 (2184501) = #2184501/485:26.51
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2184501 blocks [_NEC DVD_RW ND-3500AG]
10:43:36 #14 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [_NEC DVD_RW ND-3500AG] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4473858048, ISRC ""
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2184501 | lead-out | 1 | 0x00 | 0x41
10:43:36 #15 CDR -1202 File DriveLocker.cpp, Line 683
Drive is in use of IMAPI
_NEC DVD_RW ND-3500AG\H1 T0
10:43:36 #16 Phase 24 File APIProgress.cpp, Line 253
10:43:36 #17 Text 0 File Burncd.cpp, Line 4073
10:43:36 #18 Phase 25 File APIProgress.cpp, Line 253
10:43:36 #19 Phase 36 File APIProgress.cpp, Line 253
Burn process started at 4x (5 540 KB/s)
10:43:36 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2264
10:43:36 #21 Text 0 File DVDR.cpp, Line 1512
10:43:36 #22 Text 0 File Mmc.cpp, Line 19451
Set BUFE: JustLink -> ON
10:43:36 #23 Text 0 File DVDR.cpp, Line 1643
10:43:36 #24 Text 0 File Cdrdrv.cpp, Line 7941
Media Specific:
60 00 10 20 30 40 50 00 - 00 00 21 00 00 00 00 00 `...0@P...!.....
02 FE 10 00 02 FF A0 00 - 00 00 00 00 00 00 00 00 ................
10:43:39 #25 Text 0 File Cdrdrv.cpp, Line 1277
10:43:39.062 - _NEC DVD_RW ND-3500AG\H1 T0 : Queue again later
10:46:39 #26 SCSI -1093 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x00FF0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x04 0x35 0x40 0x00 0x00 0x20 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x02 0x00
10:46:39 #27 CDR -1093 File Writer.cpp, Line 301
No seek complete
10:46:39 #28 Text 0 File ThreadedTransfer.cpp, Line 229
10:46:39 #29 Text 0 File ThreadedTransfer.cpp, Line 223
10:46:39 #30 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was 275775
10:46:39 #31 Phase 38 File APIProgress.cpp, Line 253
Burn process failed at 4x (5 540 KB/s)
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00
MERCI D'AVANCE
canelle29
Re: probleme de gravure
Messagepar Burnitall » 05 Sep 2008 23:46
canelle29 a écrit: Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Problème avec ton DVD-R, tentes avec un autre format ou une autre marque.
Messagepar Stef » 06 Sep 2008 16:23
Bonjour et bienvenue Canelle29 :wink:
J'ai édité ton log, /!\ au début ton numéro de série est affiché. :wink:
Messagepar popzz » 06 Sep 2008 20:44
canelle29 a écrit:probleme de gravure avec dvd shrink+nero6
Media Specific:
Sense Code: 0x02
Sense Qual: 0x00
Bonsoir
Semblerait que le média soit en effet inconnu du graveur
pourtant ce graveur sait graver a coup sur le média code MCC 03RG20 mais est-ce que le média code relevé par nero MCC 03 - RG20 c'est la même chose? Je suppose aussi que ce sont bien des verbatim dvd-r 16x?
A suivre...
popzz
problème résolu
Messagepar canelle29 » 08 Sep 2008 8:25
plus de problème, instal nero 7 a la place de nero 6 plus de problème de gravure?????
:doh: :lol: :clap2:
ps.merçi stef
canelle29
Messagepar Burnitall » 08 Sep 2008 20:25
La reconnaissance d'un media dépendant plus du graveur et de son firmware je crains que tu ne retrouve le problème tôt ou tard..
Mais bon, tant mieux si nero 7 a résolu le problème. Juste par curiosité, tu as utilisé le m^me media ?
Messagepar canelle29 » 09 Sep 2008 16:42
pour répondre a burnitall meme media verbatim dvd-r 16x
utilisé avant pas de probleme , pendant probleme? :doh: , et apres plus de probleme , la meme tour de dvdr a chaque fois?
POUR VU QUE CA DUR. :praise: :P
canelle29
Messagepar Burnitall » 09 Sep 2008 18:08
Merci du retour et good luck ! :wink:
