par belair » 13 Nov 2008 22:24
au contraire je suis certain que ce n'est pas le graveur.
Ce qui vous semble "bordelique" c'est que j'essaie effectivement tous les logiciels de gravure. Certains ne permettent pas le réglage de la vitesse.
En cherchant un peu j'ai lu que l'on devait installer le driver jmicron, ce que j'ai fait sans succès.
voici le dernier log de infra recoder
InfraRecorder version 0.46.0.0 (x86)
Started: jeudi, novembre 13 2008 17:46:23.
Versions: MSW = 5.1, IE = 6.0, CC = 6.0.
CConsolePipe::Launch
CConsolePipe::CreateProcess
Command line = "C:\Program Files\InfraRecorder\cdrkit\wodim.exe" -devices.
Opened device 'D' using SPTI.
Started: jeudi, novembre 13 2008 21:40:05.
Error: SCSI command failed, returned: 0x02.
CDB: 0x5A,0x00,0x2A,0x00,0x00,0x00,0x00,0x00,0xC0,0x00
Sense: 0xF0,0x06,0x00,0x00,0x00,0x00,0x00,0x0B
0x00,0x00,0x00,0x00,0x90,0x81,0x0B,0x89
0x48,0xB1,0xD9,0x88,0x04,0x00,0x00,0x84
CCore2::EraseDisc
Method = 2, Force = 0, Eject = 0, Simulate = 1.
CCore2Blank::Blank
Handled events: 0x00
CCore::BurnTracks
[3,1,0] HL-DT-ST DVDRAM GH20NS15
Eject = 0, Simulate = 0, BUP = 1, Pad tracks = 1, Fixate = 1, Method = 0, Overburn = 1, Swab = 0, Ignore size = 0, Immed = 1, Audio master = 1, Forcespeed = 0, VariRec (enabled) = 0, VariRec (value) = 0, Mode = 0.
Command line = "C:\Program Files\InfraRecorder\cdrkit\wodim.exe" -v dev=D: gracetime=5 fs=50m -sao driveropts=burnfree -pad -overburn -immed -audio "/cygdrive/C/DOCUME~1/ADMINI~1/LOCALS~1/Temp/05 Ayo - Get Out of my Way.wav" "/cygdrive/C/DOCUME~1/ADMINI~1/LOCALS~1/Temp/13 Ayo - Thank you.wav" "/cygdrive/C/DOCUME~1/ADMINI~1/LOCALS~1/Temp/08 Ayo - Piece of Joy.wav" "/cygdrive/C/DOCUME~1/ADMINI~1/LOCALS~1/Temp/07 Ayo - Change.wav" "/cygdrive/C/DOCUME~1/ADMINI~1/LOCALS~1/Temp/03 Ayo - Slow Slow (Run Run).wav
> scsidev: 'D:'
> devname: 'D'
> scsibus: -1 target: -1 lun: -1
> Wodim version: 1.1.8
> SCSI buffer size: 64512
> Beginning DMA speed test. Set CDR_NODMATEST environment variable if device
> communication breaks or freezes immediately after that.
> TOC Type: 0 = CD-DA
> Driveropts: 'burnfree'
> Device type : Removable CD-ROM
> Version : 0
> Response Format: 2
> Capabilities :
> Vendor_info : 'HL-DT-ST'
> Identification : 'DVDRAM GH20NS15 '
> Revision : 'IL00'
> Device seems to be: Generic mmc2 DVD-R/DVD-RW.
> Current: 0x000A (CD-RW)
> Profile: 0x0012 (DVD-RAM)
> Profile: 0x0011 (DVD-R sequential recording)
> Profile: 0x0015 (DVD-R/DL sequential recording)
> Profile: 0x0016 (DVD-R/DL layer jump recording)
> Profile: 0x0013 (DVD-RW restricted overwrite)
> Profile: 0x0017 (Reserved/Unknown)
> Profile: 0x0014 (DVD-RW sequential recording)
> Profile: 0x001A (DVD+RW)
> Profile: 0x001B (DVD+R)
> Profile: 0x002B (DVD+R/DL)
> Profile: 0x0010 (DVD-ROM)
> Profile: 0x0009 (CD-R)
> Profile: 0x000A (CD-RW) (current)
> Profile: 0x0008 (CD-ROM)
> Profile: 0x0002 (Removable disk)
> Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
> Driver flags : MMC-3 SWABAUDIO BURNFREE
> Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
> Drive buf size : 1053696 = 1029 KB
> Drive DMA Speed: 4315 kB/s 24x CD 3x DVD
> FIFO size : 52428800 = 51200 KB
> Track 01: audio 28 MB (02:46.53) no preemp pad
> Track 02: audio 41 MB (04:06.28) no preemp pad
> Track 03: audio 36 MB (03:38.46) no preemp pad
> Track 04: audio 32 MB (03:10.85) no preemp pad
> Track 05: audio 35 MB (03:29.29) no preemp pad
> Track 06: audio 36 MB (03:36.34) no preemp pad
> Track 07: audio 35 MB (03:32.53) no preemp pad
> Track 08: audio 36 MB (03:35.11) no preemp pad
> Track 09: audio 55 MB (05:29.14) no preemp pad
> Track 10: audio 42 MB (04:15.47) no preemp pad
> Track 11: audio 37 MB (03:45.43) no preemp pad
> Track 12: audio 33 MB (03:21.27) no preemp pad
> Track 13: audio 35 MB (03:28.45) no preemp pad
> Total size: 487 MB (48:15.25) = 217144 sectors
> Lout start: 487 MB (48:17/19) = 217144 sectors
> Current Secsize: 2048
> ATIP info from disk:
> Indicated writing power: 3
> Reference speed: 6
> Is not unrestricted
> Is erasable
> Disk sub type: High speed Rewritable (CAV) media (1)
> ATIP start of lead in: -11625 (97:27/00)
> ATIP start of lead out: 359849 (79:59/74)
> 1T speed low: 4 1T speed high: 10
> 2T speed low: 4 2T speed high: 0 (reserved val 6)
> power mult factor: 1 5
> recommended erase/write power: 5
> A1 values: 24 1A D8
> A2 values: 26 B2 4A
> Disk type: Phase change
> Manuf. index: 0
> Manufacturer: Illegal Manufacturer code
> Blocks total: 359849 Blocks current: 359849 Blocks remaining: 142705
> Speed set to 1764 KB/s
> Starting to write CD/DVD at speed 10.0 in real SAO mode for single session.
> Last chance to quit, starting real write in 5 seconds
> Operation starts.
> Waiting for reader process to fill input buffer ... input buffer ready.
> Performing OPC...
> Sending CUE sheet...
> Errno: 5 (Input/Output error), write_g1 scsi sendcmd: no error
> CDB: 2A 00 FF FF FF 6A 00 00 1B 00
> status: 0x2 (CHECK CONDITION)
> Sense Bytes: F0 02 00 00 00 00 00 0B 00 00 00 00 01 C8 04 8A 00 00
> Sense Key: 0x0 No Additional Sense, Segment 2
> Sense Code: 0x01 Qual 0xC8 (no index/sector signal) [No matching qualifier] Fru 0x4
> Sense flags: Blk 0 (valid)
> cmd finished after 2.543s timeout 200s
> Writing pregap for track 1 at -150
> write track pad data: error after 0 bytes
> BFree: 1029 K BSize: 1029 K
> Starting new track at sector: 0
CCore::ProcessEnded
Started: jeudi, novembre 13 2008 22:18:33.
si je ne trouve pas de solution je vais essayer de repasser sur un graveur ide
