Comment activer 8Mo de cache sur le graveurDVD IISONICII8412
Messagepar grosmollet » 07 Oct 2004 14:54
Comment activer 8Mo de cache sur le graveur DVD Burner IISONIC Dual 12X Ref : II8412 et qu il le reconnais bien.
Ou trouver un firmware compatible ?
Il corresponde a quel model ? Dans les autre marque?
Le system détecte un graveur generic DVD RW 12X Max
@pluche
grosmollet
Messagepar Numéro 6 » 07 Oct 2004 15:45
Demandé si gentiement ...
Je crois que je vais faire des recherches.
Not a number
Messagepar grosmollet » 07 Oct 2004 22:05
super
et un grand merci pour ton aide
MERCI
@pluche
grosmollet
Messagepar mike » 07 Oct 2004 22:23
Bonjour ,
Specifications
BURN-Proof prevents Buffer Under Run
HD -BURN Record twice the capacity of CD-R media
12X Max 12X Max. DVD+R Write, 8X Max. DVD–R Write, 4X Max. DVD+RW Rewrite, 4X Max. DVD-RW Rewrite, and 12X Max. DVD-ROM Reading
48X Max 48X Max. CD-R Write, 24X Max. CD-RW Rewrite and 48X Max. CD-ROM Reading
Buffer 2 MB internal buffer
Internal 5.25-inch Half-height, CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD+R and DVD+RW drive
Compatible with Windows 95/98/ME/XP/NT4.0/2000
Enhanced IDE (E-IDE) / ATAPI interfaceB Total Harmonic Distortion (1kHz) ?-65 dB / Motorized easy touch tray loading
MTBF >30,000 POH(duty 20%)
Support discs diameter: 8 / 12cm
Power Requirements DC 5V±5% / 12V±10%, Max2.0A
Firmware upgradeable Yes
Writing Speed Media DVD+R DVD-R DVD+RW DVD-RW CD-R CD-RW HD-BURN Writing 12X 8X 4X 4X 48X 24X 24X
Read Speed Media DVD+R/RW DVD-R/RW DVD-ROM CD-R/RW CD-ROM CD-DA HD-BURN Reading 12X 12X 12X 48X/40X 48X 48X 78X
Writing Type DVD+R: Incremental Write (Multi Session Support) DVD-R: Disc at Once, Incremental Recording (Multi-Border Support) DVD+RW: Random Write DVD-RW: Rigid Restricted Overwriting, Incremental Write CD-R/RW: Disc at Once, Session at Once, Track at Once, Packet Writing (Multi Session Support)
Random Seek DVD:130ms CD:100ms
Voltage Spec Voltage DC +5V DC +12V Tolerance 5% 10%
Dimensions 148.5*194.2*42.5mm (W*D*H)
Environmental Specifications: Temperature: Operating: 5. to 45. Storage: -30. to 60.
Weight <1Kg less
Mais aucun firmware de trouver
le site
