Pioneer BDR-101A : gravure BLU-RAY
Messagepar franz99 » 13 Mar 2006 7:37
Plusieurs fabricants ont annoncé la disponibilité des médias vierges Blu-Ray: BD-R et BD-RE (réinscriptibles)
pour ce 2ème trimestre 2006.
Parmi ceux-ci TDK dont je vous propose de lire
et surtout de commenter
le communiqué de presse original publié par TDK sur leur site officiel
le 5 janvier 2006:
http://www.tdk.com/tecpress/20060103_bdship_ces.html
En voici la partie la plus intéressante concernant
la manière dont les données sont inscrites et protégées:
For the Blu-ray Disc, which utilizes ultra-high density recording to achieve its large capacities, scratches or dirt on the disc surface can cause data errors. To ensure reliable performance, the Blu-ray Disc was first introduced to the Japanese market in a protective cartridge. The BD-R and BD-RE Blu-ray Discs that TDK is now launching utilize DURABIS 2, the company’s exclusive hard coating technology. DURABIS 2 gives the recording surface extremely high resistance to scratches, fingerprint smudges and other dirt, thus eliminating the need for a protective cartridge.
TDK’s proprietary high-precision Spin Coating manufacturing process is utilized to form each Blu-ray Disc’s cover layer, which resides atop the recording layer. Because Spin Coating creates a cover layer with nano-uniform smoothness, exceptionally stable recording and playback characteristics are realized.
The write-once type BD-R discs incorporate inorganic recording material, which is entirely different from the organic dye used in previous write-once discs.
Because the recording layer is not affected by light, the discs are exceptionally suitable for long-term archiving.
The rewritable type BD-RE discs utilize a high-sensitivity phase-change recording material that displays stability and a low error rate, even after 10,000 overwrites
Fig. 6 Recording process with write-once type BD-R media
1. When the recording laser makes contact, its heat melts the Si and Cu alloy, which become mixed.
Lors du contact du faisceau laser la chaleur fait fondre les 2 couches de silicium et d’alliage de cuivre qui se mélangent
2. When the mixture cools, the hardened Si and Cu alloy become a composite, in which the recording mark is formed
Lorsque le mélange refroidit, le silicium et l’alliage de cuivre durcis forment un composite dans lequel la marque de gravure est ainsi formée
Comparaison avec la dye utilisée pour le HD DVD:
http://www.cdrinfo.com/Sections/News/De ... wsId=16533
The new dye used for the discs is the result of a joint development project by Hayashibara Biochemical Laboratories, a key manufacturer of dyes for DVD-Recordable discs, Mitsubishi Kagaku Media/Verbatim and Toshiba Corporation. Development of the new dye by Hayashibara, Mitsubishi Kagaku Media/Verbatim and Toshiba is a breakthrough for HD DVD-R. Standard DVD-Recordable discs use a photosensitive organic dye as the data storage medium in their recording layer.
In the transition to HD DVD, manufacturers had to meet the challenge of developing a dye for HD DVD-R discs that could be used with the narrow wavelength of a blue laser and offered sufficient readout stability.
The organic dye is highly sensitive to blue laser light, has the uncompromised readout stability essential for practical use, and the solubility in organic solvent required for easy production of the dye recording layer by a spin-coating process.
As the HD DVD-R disc is based on the same disc structure as DVD discs, back-to-back bonding of two 0.6 millimeter-thick substrates, already installed DVD-Recordable manufacturing lines can utilize the new dye in efficient production of HD DVD-R
Modifié en dernier par franz99 le 13 Déc 2008 10:06, modifié 1 fois.
Messagepar franz99 » 04 Avr 2006 9:39
Un article (en français) sur ce graveur Pioneer BDR-101 vient d'être publié
dans le dernier n° de la revue « L' ACHETEUR micro »
Messagepar franz99 » 06 Juil 2006 10:26
1ère petite review (preview) de 7 pages du Pioneer BDR-101A sur un grand site (CDRinfo):
« Pioneer BDR-101A Blu-Ray Drive Preview »
http://www.cdrinfo.com/Sections/Reviews ... leId=17415
Il faudra s'habituer à repérer ce qui est important dans la review d'un graveur Blu-Ray par rapport aux graveurs DVD "classiques"
Modifié en dernier par franz99 le 06 Aoû 2006 8:13, modifié 4 fois.
Messagepar franz99 » 06 Juil 2006 10:35
CDRinfo explique comment sera appréciée la qualité de gravure de ces nouveaux médias BD-R & BD-RE:
http://www.cdrinfo.com/Sections/Reviews ... 5&PageId=2
As can be seen, the measurement issues for the next generation formats go substantially beyond simply working with smaller features. The coding concepts, the relationships between measurements and playability, and the links between measured effects and their manufacturing-process causes, are all unique.
So, for BD, we have Random Symbol Error Rate (R-SER) , Burst Error Max, and Max total length of burst errors.
CDRInfo will present
the first digital error measurements on the recorded BD-R and BD-RE media
in the final version of this review.
Modifié en dernier par franz99 le 24 Juil 2006 8:00, modifié 12 fois.
Messagepar franz99 » 06 Juil 2006 11:08
Et de poser la question essentielle pour l'avenir:
quels BD-R & BD-RE se conserveront le mieux dans le temps et
pourquoi ?
http://www.cdrinfo.com/Sections/Reviews ... 5&PageId=1
The recordable layer of a Recordable Blu-ray Disc, employs either organic or inorganic materials.
For a single-layer Recordable Blu-ray Disc, the thickness from the disc surface to the recording layer is 100 µm.
For example,
Fuji Photo Film Co. Ltd. has successfully demonstrated BD-R that can be readily put into commercial production using organic materials.
Furthermore, TDK has realized BD-R discs using inorganic materials (a Cu alloy layer and a Si layer). In addition to the type of inorganic materials used by TDK, it is also possible to use write-once phase change materials.
Modifié en dernier par franz99 le 24 Juil 2006 7:53, modifié 1 fois.
Messagepar franz99 » 11 Juil 2006 8:08
Les premiers tests de médias Blu-Ray viennent d'être publiés pat c't magazine:
et ont été résumés par MediumRare sur CDRLabs
ici:
http://www.cdrlabs.com/phpBB/viewtopic.php?t=21949
MediumRare a écrit:The German computer magazine c't has 3 articles on HD-discs in the newest issue No. 15/2006, now on the newsstands in Europe. If you can get it, it's well worth looking at!!
The third article is the most interesting (at least for me :D). They tested 2 BluRay burners with the presently available media types. I'll try to summarize the results in a similar style to the DVD tests.
Media
There are presently 5 brands (and 4 manufacturers) available or in preproduction. All come as both write-once (BD-R) and rewritable (BD-RE). The Fuji media is made by Matushita (Panasonic), Verbatim (Mitsubishi) are preproduction samples.
c't burned samples of all media with both drives (except the Verbatim: Pioneer only). The Pioneer-burned disks were measured by Audiodev, subjected to a cliamtic stabilty test with 100 hours at 80° C and 85% rel. humidity and tested again at selected radial positions. Because of the tight schedule, the Panasonic discs were also tested at selected positions only.
The results (index and grade) are summarized in the following table. All discs were burned at 2x CLV (9 MiB/s). In contrast to DVD's, c't did not specify a "mechanical index" for the unburned discs. I hope they add this information in subsequent tests.
Code: Tout sélectionner
disc       manuf.          ID               Pioneer     Panasonic    Pioneer
        climatic
BD-RE25    Sony          SONY (001)         87 / ++      85 / ++      73 / +
BD-RE25    TDK           TDKBLDWBA (000)    70 / +       61 / +       72 / +
BD-RE25    Panasonic     MEI (001)         -61 / --      67 / +     -103 / --
           + Fuji
BD-RE25    Verbatim      VERBATIM0 (000)   -94 / nr        na       -266 / nr
           sample
BD-R25     Sony          SONY (001)         21 / -       67 / +       78 / ++
BD-R25     TDK           TDKBLDRBA (000)    -7 / --      84 / ++      64 / +
BD-R25     Panasonic     MEI (001)        -103 / --      58 / +     -199 / --
           + Fuji
BD-R25     Verbatim      VERBATIMa (000)   -69 / nr        na        -34 / nr
           sample
Remarks:
- In all, the quality and compatibility is very good for this early stage in the product cycle.
- The best results were attained by the Sony and TDK BD-RE.
- Most discs exceeded the jitter margin but did not show pronounced extrema in the curves.
- Bowing generally remained within spec, even after the climate test
- A tendency to increasing RSER10K with radius indicates problems with the uniformity of the applied lower layer.
- Pioneer had problenms with some discs. Firmware update will probably help.
- The Verbatim media are preproduction samples and were not graded. The poor climatic showing of the BD-RE is due to increased jitter and needs work prior to volume production
- The Panasonic drive did better than Pioneer and is able to read and write CD's as well thanks to the dual lenses in the PUH.
Modifié en dernier par franz99 le 11 Juil 2006 8:27, modifié 1 fois.
Messagepar franz99 » 11 Juil 2006 8:19
L'interprétation des chiffres et cotations de ces tests publiés par c't Mag est analogue à ce qu'elle était pour les DVD vierge:
c't sent their test discs to Audiodev in Sweden who analyzed them with the new CATS B600 BDR Pro analyzer. As usual, c't combined the various measurements into a quality index (the details are not specified).
As with DVD's, an index of 100 is perfect, >= 75 is very good (++), >= 50 is good (+), >= 25 satifactory (0) and >=0 is adequate (-). A negative index (--) means that uncorrectable errors occured or other signal aspects were greatly out of spec.
L'article et le résumé de MediumRare contient aussi différentes informations sur les caractéristiques physiques des BD-R et BD-RE
et notamment ceci concernant les "dyes" utilisées pour la couche sensible destinée à conserver les informations:
The information layer consists of phase-change material (e.g. GeSb) for rewritables and (at present) various inorganic material types for write-once media.
Organic pigments are in development- these will be cheaper to produce but more susceptible to temperature and humidity.
Modifié en dernier par franz99 le 05 Aoû 2006 8:28, modifié 1 fois.
Messagepar franz99 » 03 Aoû 2006 8:32
Le graveur Blu-Ray du Pioneer BDR-101A
vendu à 794 € en Allemagne:
http://www.arlt.com/shop/warenkorb.php? ... c61561227e
Messagepar franz99 » 04 Aoû 2006 18:35
Une autre petite review du Pioneer BDR-101A
vient d'être publiée sur cdfreaks:
http://www.cdfreaks.com/article/285/1
Un extrait de la page de conclusion:
http://www.cdfreaks.com/article/285/8
To sum it all up: The Pioneer BDR-101A is at the forefront of technology.
As a Blu-Ray recorder and reader, it performs extremely well.
As a DVD reader and writer it could be improved.
Traduction:
En tant que graveur et lecteur Blu-Ray la performance est très bonne
En tant que graveur et lecteur DVD il pourrait être amélioré
Modifié en dernier par franz99 le 11 Aoû 2006 9:02, modifié 1 fois.
Messagepar franz99 » 11 Aoû 2006 9:01
Une nouvelle review du Pioneer BDR-101A
par Ian sur CDRLabs:
http://www.cdrlabs.com/reviews/index.php?reviewid=289
Messagepar inconnu8 » 21 Aoû 2006 8:01
franz99 a écrit:Le graveur Blu-Ray du Pioneer BDR-101A
quand il sera en france, il sera probablement à 1000 € minimum
car tu as 20,6% de TVA a rajouté
plus la TAXE pour les droits d'auteurs afin de respecter la loie DADVSI. :lol:
inconnu8
Messagepar franz99 » 15 Sep 2006 17:37
Ce qui sera nécessaire pour voir un film en HD sur un PC:
« What you will need to watch blue laser movies on a PC »
http://www.cdfreaks.com/news/13963
