problème de gravage
problème de gravage
Messagepar ghislaine26 » 24 Jan 2007 17:44
J'ai un problème, une fois la convertion terminée je ne peux pas graver
pour info hier cela marchait trsè bien.
Le message d'erreur est can't set write parameters mode page. Code 02 04 08 not ready long write in progres
4/01/2007 17:00:06 information ********** fin de la session ***********
24/01/2007 16:56:00 information --------------Encoding end--------------
24/01/2007 16:54:42 information Taille totale 1811 Mb., Taille cible DVD5 4400 Mb., Occupation 41,17%
24/01/2007 16:54:42 information Conversion terminée en 00:31:40
24/01/2007 16:54:34 information ------------Conversion du Menu--------------
24/01/2007 16:54:34 information Generated duration 2526,48 sec., expected 2526,53 sec.
24/01/2007 16:54:34 information Ext. Subtitle file C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor.VF.srt has provided 620 / 620 entries
24/01/2007 16:54:34 Avertissement 64 frames duplicated
24/01/2007 16:53:03 information Chapter #9 start at 40:2.660
24/01/2007 16:49:36 information Chapter #8 start at 35:2.360
24/01/2007 16:46:26 information Chapter #7 start at 30:31.840
24/01/2007 16:42:37 information Chapter #6 start at 25:11.520
24/01/2007 16:39:30 information Chapter #5 start at 21:11.280
24/01/2007 16:35:13 information Chapter #4 start at 15:10.920
24/01/2007 16:32:11 information Chapter #3 start at 11:20.940
24/01/2007 16:28:04 information Chapter #2 start at 6:10.380
24/01/2007 16:23:02 information Stream #2 Sync. delay : 0,00 ms
24/01/2007 16:23:02 information Stream #1 Sync. delay : 0,00 ms
24/01/2007 16:23:02 information Stream #0 Sync. delay : 0,00 ms
24/01/2007 16:23:02 information Output Stream#2 - subtitle (fre)
24/01/2007 16:23:02 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s, Automatic gain control 18,0 dB
24/01/2007 16:23:02 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=1-31, 8308 kb/s
24/01/2007 16:23:02 information Video Stream #0 Pulldown : 23,976 -> 25,00 Fps
24/01/2007 16:23:02 information External Subtitles: Total 620 entries built
24/01/2007 16:23:02 information Ext. Subtitle file C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor.VF.srt loaded - 620 entries found
24/01/2007 16:23:02 information Video source original frame rate: 23,98
24/01/2007 16:23:02 information PAL 25 FPS output format set by user
24/01/2007 16:23:02 information Widescreen (16:9) set by user
24/01/2007 16:23:02 information Bitrate vidéo 0/8308/8308 Kbps (min/avg/max)
24/01/2007 16:23:02 information Conversion "C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor..avi"
24/01/2007 16:23:02 information ----------------Titre #1----------------
24/01/2007 16:23:02 information Taille du projet 4,3 Gb. (57,8 Mb. audio - 4,24 Gb. video)
24/01/2007 16:23:02 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 128 kb/s
24/01/2007 16:23:02 information Stream #0 - Video: mpeg4, yuv420p, 608x336
24/01/2007 16:23:02 information 2 Stream(s) found - est. duration 00:42:06.528
24/01/2007 16:23:02 information Opening file "C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor..avi"
24/01/2007 16:23:02 information [ ] Ne pas réparer les trous dans l'audio
24/01/2007 16:23:02 information [ ] Engine Log
24/01/2007 16:23:02 information Qualité de l'encodeur: 100%
24/01/2007 16:23:02 information --------------Encoding begin--------------
24/01/2007 16:23:02 information --------------Menu settings end--------------
24/01/2007 16:23:02 information [X] Lecture séquentielle
24/01/2007 16:23:02 information [X] Jouer en boucle
24/01/2007 16:23:02 information [X] Démarrer automatiquement la lecture
24/01/2007 16:23:02 information [X] Menu
24/01/2007 16:23:02 information --------------Menu settings begin--------------
24/01/2007 16:23:02 information --------------Default burn settings end--------------
24/01/2007 16:23:02 information No default writer set
24/01/2007 16:23:02 information [X] Delete files after burn complete
24/01/2007 16:23:02 information [ ] Don't eject after burn complete
24/01/2007 16:23:02 information [ ] Prefer SAO for DVD-R
24/01/2007 16:23:02 information [ ] Include originals
24/01/2007 16:23:02 information [X] Burn result to DVD
24/01/2007 16:23:02 information --------------Default burn settings begin--------------
24/01/2007 16:22:30 information La version est à jour
24/01/2007 16:18:43 information User default language : 1036 (0x040Ch) - French (Standard)
24/01/2007 16:18:43 information System default language : 1036 (0x040Ch) - French (Standard)
24/01/2007 16:18:43 information Version 2.1.10.209
24/01/2007 16:18:43 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
24/01/2007 16:18:43 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
24/01/2007 16:18:42 information ******************** Report session started ********************
ghislaine26
Messagepar cougar_ii » 24 Jan 2007 18:13
Je vois dans ton log, que tu veux graver automatiquement après la conversion.
Est-ce bien ce que tu veux faire ?
Si oui, il faut aller dans les configurations, et choisir un graveur par défaut et une vitesse de gravage par défaut (4x par example).
Après ça ConvertXtoDVD va savoir sur quel graveur et a quelle vitesse graver, après la conversion.
cougar_ii
[VSO] Client En Or
Messagepar ghislaine26 » 24 Jan 2007 19:14
c'ece que j'ai fait mais cela ne marche pas quand même :cry:
ghislaine26
Messagepar ghislaine26 » 24 Jan 2007 19:51
Cela ne marche toujours pas je remets le log. Comment expliquer qu'hier cela marchait très bien et aujourd'huis, sans toucher, cela ne marche plus
24/01/2007 19:45:24 information ********** fin de la session ***********
24/01/2007 19:45:14 information Répertoire C:\Documents and Settings\HP_Propriétaire\Mes documents\ConvertXtoDVD\greys.anatomy.312.proper.hdtv.xvid-xor\ supprimé
24/01/2007 19:45:14 information Finalization Time 00:00:47 - Total completion time 00:05:44
24/01/2007 19:44:27 information Write finished in 00:04:56 - Finalization start here. Avg. burn rate 1,72
24/01/2007 19:39:30 information Lead-in burning time (mS) 279
24/01/2007 19:39:30 information Write started 314480 sectors to write
24/01/2007 19:39:30 information Writing speed requested x2.0, effective x2.0
24/01/2007 19:39:30 information Format completed
24/01/2007 19:39:01 information Format start
24/01/2007 19:39:01 information Available write speed: 2x
24/01/2007 19:39:01 information Media ID: MCC 01RW11n9
24/01/2007 19:39:01 information DMA Enabled
24/01/2007 19:39:01 information Scanned files #6, folder #2 - total size 642955264 b. (613 Mb.)
24/01/2007 19:39:01 information Inserted media type : DVD-RW Sequential
24/01/2007 19:39:00 information Write started
24/01/2007 19:38:59 information --------------Encoding end--------------
24/01/2007 19:38:59 information Media name: "Mon DVD"
24/01/2007 19:38:59 information Burned folder: "C:\Documents and Settings\HP_Propriétaire\Mes documents\ConvertXtoDVD\greys.anatomy.312.proper.hdtv.xvid-xor\"
24/01/2007 19:38:44 information New media inserted. Burning layer is ready to write
24/01/2007 19:38:42 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
24/01/2007 19:38:42 information New Drive selected : 0:0:0 - TSSTcorp CD/DVDW TS-H552B HP08 [E] (Ide)
24/01/2007 19:38:42 information Taille totale 613 Mb., Taille cible DVD5 4400 Mb., Occupation 13,94%
24/01/2007 19:38:42 information Conversion terminée en 00:27:08
24/01/2007 19:38:34 information ------------Conversion du Menu--------------
24/01/2007 19:38:34 information Generated duration 2526,48 sec., expected 2526,53 sec.
24/01/2007 19:38:33 information Ext. Subtitle file C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor.VF.srt has provided 620 / 620 entries
24/01/2007 19:38:33 Avertissement 64 frames duplicated
24/01/2007 19:37:29 information Chapter #9 start at 40:17.800
24/01/2007 19:34:17 information Chapter #8 start at 35:17.500
24/01/2007 19:31:19 information Chapter #7 start at 30:26.960
24/01/2007 19:28:15 information Chapter #6 start at 25:36.920
24/01/2007 19:24:49 information Chapter #5 start at 20:21.480
24/01/2007 19:21:57 information Chapter #4 start at 15:41.200
24/01/2007 19:18:38 information Chapter #3 start at 10:36.020
24/01/2007 19:15:46 information Chapter #2 start at 6:10.380
24/01/2007 19:11:34 information Stream #2 Sync. delay : 0,00 ms
24/01/2007 19:11:34 information Stream #1 Sync. delay : 0,00 ms
24/01/2007 19:11:34 information Stream #0 Sync. delay : 0,00 ms
24/01/2007 19:11:34 information Output Stream#2 - subtitle (fre)
24/01/2007 19:11:34 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s, Automatic gain control 18,0 dB
24/01/2007 19:11:34 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=2-31, 8308 kb/s
24/01/2007 19:11:34 information Video Stream #0 Pulldown : 23,976 -> 25,00 Fps
24/01/2007 19:11:34 information External Subtitles: Total 620 entries built
24/01/2007 19:11:34 information Ext. Subtitle file C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor.VF.srt loaded - 620 entries found
24/01/2007 19:11:34 information Video source original frame rate: 23,98
24/01/2007 19:11:34 information PAL 25 FPS output format set by user
24/01/2007 19:11:34 information Widescreen (16:9) set by user
24/01/2007 19:11:34 information Bitrate vidéo 0/8308/8308 Kbps (min/avg/max)
24/01/2007 19:11:34 information Conversion "C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor..avi"
24/01/2007 19:11:34 information ----------------Titre #1----------------
24/01/2007 19:11:34 information Taille du projet 4,3 Gb. (57,8 Mb. audio - 4,24 Gb. video)
24/01/2007 19:11:34 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 128 kb/s
24/01/2007 19:11:34 information Stream #0 - Video: mpeg4, yuv420p, 608x336
24/01/2007 19:11:34 information 2 Stream(s) found - est. duration 00:42:06.528
24/01/2007 19:11:34 information Opening file "C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor..avi"
24/01/2007 19:11:28 information New media inserted. Burning layer is ready to write
24/01/2007 19:11:28 information [ ] Ne pas réparer les trous dans l'audio
24/01/2007 19:11:28 information [ ] Engine Log
24/01/2007 19:11:28 information Qualité de l'encodeur: 50%
24/01/2007 19:11:28 information --------------Encoding begin--------------
24/01/2007 19:11:28 information --------------Menu settings end--------------
24/01/2007 19:11:28 information [X] Lecture séquentielle
24/01/2007 19:11:28 information [X] Jouer en boucle
24/01/2007 19:11:28 information [X] Démarrer automatiquement la lecture
24/01/2007 19:11:28 information [X] Menu
24/01/2007 19:11:28 information --------------Menu settings begin--------------
24/01/2007 19:11:28 information --------------Default burn settings end--------------
24/01/2007 19:11:28 information Default speed selected: x1
24/01/2007 19:11:28 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
24/01/2007 19:11:28 information New Drive selected : 0:0:0 - TSSTcorp CD/DVDW TS-H552B HP08 [E] (Ide)
24/01/2007 19:11:28 information [X] Delete files after burn complete
24/01/2007 19:11:28 information [ ] Don't eject after burn complete
24/01/2007 19:11:28 information [ ] Prefer SAO for DVD-R
24/01/2007 19:11:28 information [ ] Include originals
24/01/2007 19:11:28 information [X] Burn result to DVD
24/01/2007 19:11:28 information --------------Default burn settings begin--------------
24/01/2007 19:10:36 information New media inserted. Burning layer is ready to write
24/01/2007 19:10:35 information [ ] Ne pas réparer les trous dans l'audio
24/01/2007 19:10:35 information [ ] Engine Log
24/01/2007 19:10:35 information Qualité de l'encodeur: 50%
24/01/2007 19:10:35 information --------------Encoding begin--------------
24/01/2007 19:10:35 information --------------Menu settings end--------------
24/01/2007 19:10:35 information [X] Lecture séquentielle
24/01/2007 19:10:35 information [X] Jouer en boucle
24/01/2007 19:10:35 information [X] Démarrer automatiquement la lecture
24/01/2007 19:10:35 information [X] Menu
24/01/2007 19:10:35 information --------------Menu settings begin--------------
24/01/2007 19:10:35 information --------------Default burn settings end--------------
24/01/2007 19:10:35 information Default speed selected: x1
24/01/2007 19:10:35 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
24/01/2007 19:10:35 information New Drive selected : 0:0:0 - TSSTcorp CD/DVDW TS-H552B HP08 [E] (Ide)
24/01/2007 19:10:35 information [X] Delete files after burn complete
24/01/2007 19:10:35 information [ ] Don't eject after burn complete
24/01/2007 19:10:35 information [ ] Prefer SAO for DVD-R
24/01/2007 19:10:35 information [ ] Include originals
24/01/2007 19:10:34 information [X] Burn result to DVD
24/01/2007 19:10:34 information --------------Default burn settings begin--------------
24/01/2007 19:10:15 information --------------Encoding end--------------
24/01/2007 19:10:14 information Conversion échouée en 00:00:08
24/01/2007 19:10:14 information User cancellation requested
24/01/2007 19:10:05 information Stream #2 Sync. delay : 0,00 ms
24/01/2007 19:10:05 information Stream #1 Sync. delay : 0,00 ms
24/01/2007 19:10:05 information Stream #0 Sync. delay : 0,00 ms
24/01/2007 19:10:05 information Output Stream#2 - subtitle (fre)
24/01/2007 19:10:05 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s, Automatic gain control 18,0 dB
24/01/2007 19:10:05 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=2-31, 8308 kb/s
24/01/2007 19:10:05 information Video Stream #0 Pulldown : 23,976 -> 25,00 Fps
24/01/2007 19:10:05 information External Subtitles: Total 620 entries built
24/01/2007 19:10:05 information Ext. Subtitle file C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor.VF.srt loaded - 620 entries found
24/01/2007 19:10:05 information Video source original frame rate: 23,98
24/01/2007 19:10:05 information PAL 25 FPS output format set by user
24/01/2007 19:10:05 information Widescreen (16:9) set by user
24/01/2007 19:10:05 information Bitrate vidéo 0/8308/8308 Kbps (min/avg/max)
24/01/2007 19:10:05 information Conversion "C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor..avi"
24/01/2007 19:10:05 information ----------------Titre #1----------------
24/01/2007 19:10:05 information Taille du projet 4,3 Gb. (57,8 Mb. audio - 4,24 Gb. video)
24/01/2007 19:10:05 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 128 kb/s
24/01/2007 19:10:05 information Stream #0 - Video: mpeg4, yuv420p, 608x336
24/01/2007 19:10:05 information 2 Stream(s) found - est. duration 00:42:06.528
24/01/2007 19:10:05 information Opening file "C:\Documents and Settings\HP_Propriétaire\Bureau\Grey's anatomy dvd\greys.anatomy.312.proper.hdtv.xvid-xor..avi"
24/01/2007 19:10:02 information New media inserted. Burning layer is ready to write
24/01/2007 19:10:00 information [ ] Ne pas réparer les trous dans l'audio
24/01/2007 19:10:00 information [ ] Engine Log
24/01/2007 19:10:00 information Qualité de l'encodeur: 50%
24/01/2007 19:10:00 information --------------Encoding begin--------------
24/01/2007 19:10:00 information --------------Menu settings end--------------
24/01/2007 19:10:00 information [X] Lecture séquentielle
24/01/2007 19:10:00 information [X] Jouer en boucle
24/01/2007 19:10:00 information [X] Démarrer automatiquement la lecture
24/01/2007 19:10:00 information [X] Menu
24/01/2007 19:10:00 information --------------Menu settings begin--------------
24/01/2007 19:10:00 information --------------Default burn settings end--------------
24/01/2007 19:10:00 information Default speed selected: x1
24/01/2007 19:10:00 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
24/01/2007 19:10:00 information New Drive selected : 0:0:0 - TSSTcorp CD/DVDW TS-H552B HP08 [E] (Ide)
24/01/2007 19:10:00 information [X] Delete files after burn complete
24/01/2007 19:10:00 information [ ] Don't eject after burn complete
24/01/2007 19:10:00 information [ ] Prefer SAO for DVD-R
24/01/2007 19:10:00 information [ ] Include originals
24/01/2007 19:10:00 information [X] Burn result to DVD
24/01/2007 19:10:00 information --------------Default burn settings begin--------------
24/01/2007 19:08:04 information New media inserted. Burning layer is ready to write
24/01/2007 18:50:40 information User default language : 1036 (0x040Ch) - French (Standard)
24/01/2007 18:50:40 information System default language : 1036 (0x040Ch) - French (Standard)
24/01/2007 18:50:40 information Version 2.1.10.209
24/01/2007 18:50:40 information ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
24/01/2007 18:50:40 information OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
24/01/2007 18:50:39 information ******************** Report session started ********************
ghislaine26
