Probleme de gravure : a l'aide...
Messagepar denisfavre » 27 Fév 2007 19:11
Hello a tous !
J'ai un probleme de gravure. Voici le message de log ci-dessous.
Quelqu'un pourrait m'aider ?
Denis
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 12/22/1997 20:23:24
ahead WinASPI: File 'F:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 17:35:34
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
Recorder: <Optiarc DVD+-RW ND-3570A>Version: 104B - HA 0 TA 0 - 6.6.0.16
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
CD-ROM: <Optiarc DVD+-RW ND-3570A>Version: 104B - HA 0 TA 0 - 6.6.0.16
CdRomPeripheral : Optiarc DVD+-RW ND-3570A atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD2500JS-75NCB2 atapi Port 1 ID 0 DMA: On
Optiarc DVD+-RW ND-3570A D: CDRom0
Physical memory : 1022MB (1046604kB)
Free physical memory: 469MB (480284kB)
Memory in use : 54 %
27.2.2007
CD-ROM (ISO)
12:28:28 #1 Text 0 File Isodoc.cpp, Line 6356
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
12:28:28 #2 Text 0 File Burncd.cpp, Line 2948
12:28:28 #3 Text 0 File Reader.cpp, Line 127
12:28:28 #4 Text 0 File Writer.cpp, Line 122
Writer Optiarc DVD+-RW ND-3570A running
12:28:28 #5 ISO9660GEN -11 File geniso.cpp, Line 3309
12:28:28 #6 Text 0 File Burncd.cpp, Line 3233
12:28:29 #7 Text 0 File DlgWaitCD.cpp, Line 270
Last address to be written: 259425 ( 57:41.00)
12:28:29 #8 Text 0 File DlgWaitCD.cpp, Line 282
12:28:29 #9 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: Optiarc DVD+-RW ND-3570A;
CDR code: 00 97 17 06; OSJ entry from: Moser Baer India Limited
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 11 06 (LI 97:17.06), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 2B 00 D0 (invalid), 2: 3D B8 00 (invalid), 3: 22 D2 80 (invalid)
12:28:29 #10 Text 0 File DlgWaitCD.cpp, Line 448
12:28:29 #11 Text 0 File ThreadedTransferInterface.cpp, Line 838
0: TRM_DATA_MODE1 ()
original disc pos #0 + 259426 (259426) = #259426/57:39.1
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 259426 blocks [Optiarc DVD+-RW ND-3570A]
12:28:29 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [Optiarc DVD+-RW ND-3570A] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 531611648, ISRC ""
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
259426 | lead-out | 1 | 0x41 | 0x00
12:28:29 #13 Phase 24 File dlgbrnst.cpp, Line 1832
12:28:31 #14 Text 0 File Burncd.cpp, Line 4120
12:28:31 #15 Phase 25 File dlgbrnst.cpp, Line 1832
12:28:31 #16 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (1,200 KB/s)
12:28:31 #17 SCSI -1189 File Cdrdrv.cpp, Line 1180
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03B06000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0x40 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x30 0x02
12:28:31 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2654
12:28:31 #19 Text 0 File Mmc.cpp, Line 16924
StartDAO : CD-Text - Off
12:28:31 #20 Text 0 File Mmc.cpp, Line 21708
12:28:31 #21 Text 0 File Mmc.cpp, Line 17211
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 39 29 01
12:36:23 #22 Text 0 File WriterStatus.cpp, Line 116
<Optiarc DVD+-RW ND-3570A> start writing Lead-Out at LBA 259426 (3F562h), lenght 0 blocks
12:36:23 #23 Text 0 File ThreadedTransfer.cpp, Line 228
12:36:46 #24 Phase 37 File dlgbrnst.cpp, Line 1832
Burn process completed successfully at 8x (1,200 KB/s)
12:36:46 #25 Phase 78 File dlgbrnst.cpp, Line 1832
Data verification started
12:36:47 #26 SCSI -1023 File Cdrdrv.cpp, Line 1180
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x4E 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x2C 0x00
12:36:49 #27 Text 0 File ThreadedTransferInterface.cpp, Line 1119
Removed 2 run-out blocks from end of track 1. Length: 259426 -> 259424.
12:37:52 #28 SCSI -1128 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x04F00200
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x63 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x63 0x0A
0x00 0x00 0x00 0x00 0x11 0x00
12:37:54 #29 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x64 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x64 0x0A
12:37:57 #30 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x65 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x65 0x0A
0x00 0x00 0x00 0x00 0x02 0x00
12:38:00 #31 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x66 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x66 0x0A
12:38:05 #32 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x6A 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x6A 0x0A
12:38:05 #33 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96099 to 96102
12:38:08 #34 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x6B 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x6B 0x0A
12:38:11 #35 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x6C 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x6C 0x0A
12:38:14 #36 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x71 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x71 0x0A
12:38:14 #37 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96106 to 96108
12:38:18 #38 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x72 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x72 0x0A
12:38:21 #39 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x73 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x73 0x0A
12:38:24 #40 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x74 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x74 0x0A
12:38:28 #41 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x75 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x75 0x0A
12:38:31 #42 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x78 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x78 0x0A
12:38:31 #43 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96113 to 96117
12:38:34 #44 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x79 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x79 0x0A
12:38:37 #45 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x7A 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x7A 0x0A
12:38:41 #46 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x7B 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x7B 0x0A
12:38:47 #47 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x7F 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x7F 0x0A
12:38:47 #48 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96120 to 96123
12:38:54 #49 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x80 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x80 0x0A
12:38:58 #50 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x81 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x81 0x0A
12:39:02 #51 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x82 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x82 0x0A
12:39:06 #52 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x83 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x83 0x0A
12:39:10 #53 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x84 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x84 0x0A
12:39:18 #54 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x87 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x87 0x0A
12:39:18 #55 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96127 to 96132
12:39:22 #56 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x88 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x88 0x0A
12:39:27 #57 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x89 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x89 0x0A
12:39:33 #58 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x8E 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x8E 0x0A
12:39:33 #59 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96135 to 96137
12:39:39 #60 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x8F 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x8F 0x0A
12:39:43 #61 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x90 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x90 0x0A
12:39:49 #62 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x91 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x91 0x0A
12:39:54 #63 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x92 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x92 0x0A
12:39:58 #64 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x95 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x95 0x0A
12:39:58 #65 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96142 to 96146
12:40:02 #66 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x96 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x96 0x0A
12:40:08 #67 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x97 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x97 0x0A
12:40:14 #68 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x98 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x98 0x0A
12:40:18 #69 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x9C 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x9C 0x0A
12:40:18 #70 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96149 to 96152
12:40:22 #71 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x9D 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x9D 0x0A
12:40:27 #72 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x9E 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x9E 0x0A
12:40:31 #73 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0x9F 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0x9F 0x0A
12:40:39 #74 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xA0 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xA0 0x0A
12:40:46 #75 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xA4 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xA4 0x0A
12:40:46 #76 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96156 to 96160
12:40:50 #77 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xA5 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xA5 0x0A
12:40:54 #78 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xA6 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xA6 0x0A
12:40:57 #79 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xAA 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xAA 0x0A
12:40:57 #80 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96164 to 96166
12:41:00 #81 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xAB 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xAB 0x0A
12:41:03 #82 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xAC 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xAC 0x0A
12:41:07 #83 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xAD 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xAD 0x0A
12:41:13 #84 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xAE 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xAE 0x0A
12:41:18 #85 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xAF 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xAF 0x0A
12:41:20 #86 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xB2 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xB2 0x0A
12:41:20 #87 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96170 to 96175
12:41:22 #88 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xB3 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xB3 0x0A
12:41:25 #89 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xB4 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xB4 0x0A
12:41:29 #90 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xB5 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xB5 0x0A
12:41:31 #91 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xB9 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xB9 0x0A
12:41:31 #92 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96178 to 96181
12:41:34 #93 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xBA 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xBA 0x0A
12:41:36 #94 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xBB 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xBB 0x0A
12:41:39 #95 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xBC 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xBC 0x0A
12:41:42 #96 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xBD 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xBD 0x0A
12:41:49 #97 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xC1 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xC1 0x0A
12:41:49 #98 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96185 to 96189
12:41:51 #99 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xC2 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xC2 0x0A
12:41:55 #100 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xC3 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xC3 0x0A
12:41:58 #101 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xC7 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xC7 0x0A
12:41:58 #102 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96193 to 96195
12:42:00 #103 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xC8 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xC8 0x0A
12:42:04 #104 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xC9 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xC9 0x0A
12:42:07 #105 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xCA 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xCA 0x0A
12:42:10 #106 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xCB 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xCB 0x0A
12:42:13 #107 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xCC 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xCC 0x0A
12:42:17 #108 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xCF 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xCF 0x0A
12:42:17 #109 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96199 to 96204
12:42:20 #110 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xD0 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xD0 0x0A
12:42:23 #111 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xD1 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xD1 0x0A
12:42:27 #112 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xD2 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xD2 0x0A
12:42:29 #113 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xD5 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xD5 0x0A
12:42:29 #114 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96207 to 96210
12:42:32 #115 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xD6 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xD6 0x0A
12:42:36 #116 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xD7 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xD7 0x0A
12:42:39 #117 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xD8 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xD8 0x0A
12:42:42 #118 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xD9 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xD9 0x0A
12:42:45 #119 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xDA 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xDA 0x0A
12:42:50 #120 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xDD 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xDD 0x0A
12:42:50 #121 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96213 to 96218
12:42:53 #122 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xDE 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xDE 0x0A
12:42:56 #123 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xDF 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xDF 0x0A
12:43:02 #124 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xE0 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xE0 0x0A
12:43:05 #125 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xE4 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xE4 0x0A
12:43:05 #126 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96221 to 96224
12:43:08 #127 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xE5 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xE5 0x0A
12:43:10 #128 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xE6 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xE6 0x0A
12:43:13 #129 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xE7 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xE7 0x0A
12:43:16 #130 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xE8 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xE8 0x0A
12:43:20 #131 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xE9 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xE9 0x0A
12:43:23 #132 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xEC 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xEC 0x0A
12:43:23 #133 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96228 to 96233
12:43:27 #134 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xED 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xED 0x0A
12:43:30 #135 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xEE 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xEE 0x0A
12:43:36 #136 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xF3 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xF3 0x0A
12:43:36 #137 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96236 to 96238
12:43:40 #138 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xF4 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xF4 0x0A
12:43:45 #139 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xF5 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xF5 0x0A
12:43:48 #140 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xF6 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xF6 0x0A
12:43:51 #141 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xF7 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xF7 0x0A
12:43:53 #142 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xFA 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xFA 0x0A
12:43:53 #143 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96243 to 96247
12:43:56 #144 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xFB 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xFB 0x0A
12:43:59 #145 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xFC 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xFC 0x0A
12:44:02 #146 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x77 0xFD 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x77 0xFD 0x0A
12:44:07 #147 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x01 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x01 0x0A
12:44:07 #148 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96250 to 96253
12:44:09 #149 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x02 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x02 0x0A
12:44:12 #150 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x03 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x03 0x0A
12:44:14 #151 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x04 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x04 0x0A
12:44:17 #152 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x05 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x05 0x0A
12:44:19 #153 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x09 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x09 0x0A
12:44:19 #154 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96257 to 96261
12:44:21 #155 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x0A 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x0A 0x0A
12:44:24 #156 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x0B 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x0B 0x0A
12:44:28 #157 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x0F 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x0F 0x0A
12:44:28 #158 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96265 to 96267
12:44:30 #159 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x10 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x10 0x0A
12:44:33 #160 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x11 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x11 0x0A
12:44:37 #161 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x12 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x12 0x0A
12:44:41 #162 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x13 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x13 0x0A
12:44:44 #163 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x14 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x14 0x0A
12:44:47 #164 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x17 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x17 0x0A
12:44:47 #165 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96271 to 96276
12:44:50 #166 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x18 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x18 0x0A
12:44:54 #167 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x19 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x19 0x0A
12:44:58 #168 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x1A 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x1A 0x0A
12:45:02 #169 SCSI -1128 File Cdrdrv.cpp, Line 1434
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x1E 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x1E 0x0A
12:45:02 #170 SectorVerify 20 File Cdrdrv.cpp, Line 9938
Read errors from sector 96279 to 96282
12:45:06 #171 SCSI -1093 File Cdrdrv.cpp, Line 1434
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x01 0x78 0x1F 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x78 0x1F 0x0A
12:45:13 #172 SCSI -1093 File Cdrdrv.cpp, Line 1434
denisfavre
Messagepar Scaramanga » 27 Fév 2007 19:35
hello,
Code: Tout sélectionner
Mettre à jour > 6.6.1.4
As tu déjà réussi a graver ce type de média ?
Optiarc est une "joint venture" avec Sony et Nec....
http://www.gravure-news.com/visunews.php?n=2553
http://www.sonynec-optiarc.com/index_en.html
Mehuuu, sont ou les firmwares?
Messagepar denisfavre » 28 Fév 2007 17:57
Il semblerait que l'erreur viennent du type de CD utilise.
En utilisant une autre marque de CD, cela fonctionne.
Est ce possible ?
denisfavre
