problème de gravure avec graveur dvd LG
Messagepar stephmac » 23 Sep 2007 14:01
Bonjour a tous
j'utilise convertxtodvd pour convertir un media .avi , jusqu'ici pas de problème pour la convertion , par contre a la fin je lance le process de gravure de convertxtodvd et le gravure ne s'effectue pas .....voici le log du dernier essai
23/09/2007 13:29:07 information ********** Fin de la session ***********
23/09/2007 13:29:04 information Media removed. Burning layer not ready to write
23/09/2007 13:26:49 Erreur Write error at 0 (16) - Code 00 00 00 [No sense information.]
23/09/2007 13:26:47 information Write started 1859024 sectors to write
23/09/2007 13:26:47 information Writing speed requested x4.0, effective x4.0
23/09/2007 13:25:15 information Format completed
23/09/2007 13:24:48 information Format start
23/09/2007 13:24:48 information Available write speed: 4x, 2.4x
23/09/2007 13:24:48 information Media ID: RICOHJPN-W11-01
23/09/2007 13:24:48 information Media type: DVD+RW
23/09/2007 13:24:48 information Scanned files #9, folder #2 - total size 3806160896 b. (3,54 Gb.)
23/09/2007 13:24:48 information Inserted media type : DVD+RW
23/09/2007 13:24:48 information Write started
23/09/2007 13:24:47 information --------------Encoding end--------------
23/09/2007 13:24:47 information Media name: vacances2007
23/09/2007 13:24:47 information Burned folder: "C:\Documents and Settings\Administrateur.STEPHANE-3196CD\Mes documents\ConvertXtoDVD\vacances2007\"
23/09/2007 13:24:40 information New media inserted. Burning layer is ready to write
23/09/2007 13:24:38 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
23/09/2007 13:24:38 information New Drive selected : 1:1:0 - HL-DT-ST DVDRAM GSA-4167B DL11 [F] (Scsi)
23/09/2007 13:24:38 information Taille totale 3629 Mb., Taille cible DVD5 4400 Mb., Occupation 82,50%
23/09/2007 13:24:38 information Conversion terminée en 01:53:54
23/09/2007 13:24:17 information ------------Conversion du Menu--------------
23/09/2007 13:24:17 information Generated duration 5224,36 sec., expected 5224,44 sec.
23/09/2007 13:21:38 information Chapter #18 start at 85:0.000
23/09/2007 13:15:39 information Chapter #17 start at 79:59.960
23/09/2007 13:09:11 information Chapter #16 start at 74:59.920
23/09/2007 13:03:08 information Chapter #15 start at 69:59.880
23/09/2007 12:56:59 information Chapter #14 start at 64:59.840
23/09/2007 12:50:50 information Chapter #13 start at 59:59.800
23/09/2007 12:44:35 information Chapter #12 start at 54:59.760
23/09/2007 12:38:32 information Chapter #11 start at 49:59.720
23/09/2007 12:31:20 information Chapter #10 start at 45:0.120
23/09/2007 12:24:30 information Chapter #9 start at 40:0.040
23/09/2007 12:17:39 information Chapter #8 start at 35:0.040
23/09/2007 12:11:05 information Chapter #7 start at 30:0.000
23/09/2007 12:03:42 information Chapter #6 start at 24:59.760
23/09/2007 11:56:45 information Chapter #5 start at 19:59.800
23/09/2007 11:50:20 information Chapter #4 start at 14:59.920
23/09/2007 11:43:32 information Chapter #3 start at 9:59.920
23/09/2007 11:36:55 information Chapter #2 start at 4:59.760
23/09/2007 11:30:44 information Stream #1 Sync. delay : 0,00 ms
23/09/2007 11:30:44 information Stream #0 Sync. delay : 0,00 ms
23/09/2007 11:30:44 information Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s, no automatic gain control
23/09/2007 11:30:44 information Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=1-31, 6726 kb/s
23/09/2007 11:30:44 information Video Stream #0 framerate : 25,00 Fps (source 25,00 Fps), no pulldown
23/09/2007 11:30:44 information Image processing: Fast bilinear resampler (576*304)->(720*544)
23/09/2007 11:30:44 information Image processing: Pad (Left:0 - Top:16 - Right:0 - Bottom:16)
23/09/2007 11:30:44 information Image processing: Deinterleave (576*304)
23/09/2007 11:30:44 information No pulldown: Frame duplication/removal will be used.
23/09/2007 11:30:44 information Video source original frame rate: 25,00
23/09/2007 11:30:44 information Output resolution: FULL D1 [720*576]
23/09/2007 11:30:44 information PAL 25 FPS output format set automatically
23/09/2007 11:30:44 information Widescreen (16:9) set automatically
23/09/2007 11:30:44 information Bitrate vidéo 0/6726/8808 Kbps (min/avg/max)
23/09/2007 11:30:44 information Conversion "D:\arrivage\vacances2007.avi"
23/09/2007 11:30:44 information ----------------Titre #1----------------
23/09/2007 11:30:43 information Taille du projet 4,3 Gb. (122 Mb. audio - 4,16 Gb. vidéo)
23/09/2007 11:30:43 information Stream #1 - Audio: mp3, 48000 Hz, stereo, 128 kb/s
23/09/2007 11:30:43 information Stream #0 - Video: mpeg4, yuv420p, 576x304
23/09/2007 11:30:43 information 2 Stream(s) found - est. duration 01:27:04.440
23/09/2007 11:30:43 information Opening file "D:\arrivage\vacances2007.avi"
23/09/2007 11:30:43 information [ ] Ne pas réparer les "trous" dans l'audio
23/09/2007 11:30:43 information [ ] Engine Log
23/09/2007 11:30:43 information Qualité de l'encodeur: 100%
23/09/2007 11:30:43 information --------------Encoding begin--------------
23/09/2007 11:30:43 information --------------Menu settings end--------------
23/09/2007 11:30:43 information [X] Lecture séquentielle
23/09/2007 11:30:43 information [X] Jouer en boucle
23/09/2007 11:30:43 information [X] Démarrer automatiquement la lecture
23/09/2007 11:30:43 information [X] Menu
23/09/2007 11:30:43 information --------------Menu settings begin--------------
23/09/2007 11:30:43 information --------------Default burn settings end--------------
23/09/2007 11:30:43 information Default speed selected: x4
23/09/2007 11:30:43 information Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
23/09/2007 11:30:43 information New Drive selected : 1:1:0 - HL-DT-ST DVDRAM GSA-4167B DL11 [F] (Scsi)
23/09/2007 11:30:43 information [X] Delete files after burn complete
23/09/2007 11:30:43 information [ ] Don't eject after burn complete
23/09/2007 11:30:43 information [ ] Prefer SAO for DVD-R
23/09/2007 11:30:43 information [ ] Include originals
23/09/2007 11:30:43 information [X] Burn result to DVD
23/09/2007 11:30:43 information --------------Default burn settings begin--------------
23/09/2007 11:28:19 information La version est à jour
23/09/2007 11:28:16 information New media inserted. Burning layer is ready to write
23/09/2007 11:28:03 information User default language : 1036 (0x040Ch) - French (Standard)
23/09/2007 11:28:03 information System default language : 1036 (0x040Ch) - French (Standard)
23/09/2007 11:28:03 information Version 2.2.3.258
23/09/2007 11:28:03 information ExeName : "D:\PROGRAMMES\convertxtodvd\ConvertXtoDVD\ConvertXtoDvd.exe"
23/09/2007 11:28:03 information OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
23/09/2007 11:28:03 information ******************** Report session started ********************
23/09/2007 11:22:31 information ********** Fin de la session ***********
23/09/2007 11:22:04 information User default language : 1036 (0x040Ch) - French (Standard)
23/09/2007 11:22:04 information System default language : 1036 (0x040Ch) - French (Standard)
23/09/2007 11:22:04 information Version 2.2.3.258
23/09/2007 11:22:04 information ExeName : "D:\PROGRAMMES\convertxtodvd\ConvertXtoDVD\ConvertXtoDvd.exe"
23/09/2007 11:22:04 information OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
23/09/2007 11:21:56 information ******************** Report session started ********************
23/09/2007 11:22:27 information ********** Fin de la session ***********
23/09/2007 11:22:03 information User default language : 1036 (0x040Ch) - French (Standard)
23/09/2007 11:22:03 information System default language : 1036 (0x040Ch) - French (Standard)
23/09/2007 11:22:03 information Version 2.2.3.258
23/09/2007 11:22:03 information ExeName : "D:\PROGRAMMES\convertxtodvd\ConvertXtoDVD\ConvertXtoDvd.exe"
23/09/2007 11:22:03 information OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
23/09/2007 11:21:56 Erreur Log file can't be saved on disk. Please select a different location - Current ""
stephmac
Messagepar stephmac » 25 Sep 2007 19:52
ça n'inspire pas grand monde !!!!!!!!!!!!
stephmac
Messagepar Stef » 25 Sep 2007 21:04
stephmac a écrit:ça n'inspire pas grand monde !!!!!!!!!!!!
Du calme mon garçon ! Si pas de réponse, peut etre pas de solution trouvée quant à présent...
As-tu déjà gravé sur ton DVD RW Ricoh 4 x ?
Solution 1 : essayer un autre support vierge
Solution 2 (temporaire) : ne pas graver avec ConvertXtoDVD. Graver la conversion avec un autre logiciel de gravure standard.
Messagepar stephmac » 26 Sep 2007 8:54
salut stef,
désolé pour mon impatience , oui j'ai déja éssayé plusieurs types de support et j'ai déja également essayé avec néro..........qu'est ce que ricoh ????
stephmac
Messagepar Vieux motard » 27 Sep 2007 17:35
Ricoh, c'est la marque du fabriquant du DVD+RW que t'as gravé :wink:
Peut importe ce qu'il y a de marqué sur l'étiquette, c'est une fabrication Ricoh.
Vieux motard
Messagepar stephmac » 27 Sep 2007 17:45
salut , ou ais je la tête ??? ricoh-sony....c'est deux la ça ne fonctionne pas
stephmac
Messagepar Scaramanga » 27 Sep 2007 18:02
Code: Tout sélectionner
Ton firmware n'est pas à jour ( version DL11) il me semble que le dernier est DL13.
Messagepar Vieux motard » 27 Sep 2007 18:06
Peut-être de quoi faire fonctionner les derniers Ricoh et Sony :wink:
Vieux motard
Messagepar stephmac » 27 Sep 2007 19:07
Salut Scaramanga , bien vu il s'agit effectivement de la DL13, je mets a jour et te tiens au courant.........merci beaucoup
stephmac
Messagepar stephmac » 27 Sep 2007 19:23
eh bien impossible de mettre a jour !!!!!!!!!
voici le message d'erreur
Updating was failed. Please repeat that. (Error data = 00 00 00 00 00 00 00 00 00 00 00 00
et j'ai beau reessayer , j'ai toujours ce même message !!
stephmac
