par tahlmo » 12 Mar 2008 20:05
[code]
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:32
Nero Version: 6.6.0.8 (Nero Express)
Recorder: <PHILIPS DVD+-RW SDVD8431>Version: LX51 - HA 1 TA 0 - 6.6.0.8
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
CD-ROM: <VY1082Z TWK982D >Version: 1.0 - HA 2 TA 0 - 6.6.0.8
Adapter driver: <acw6pn6d> HA 2
DiskPeripheral : FUJITSU MHV2080BH atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PHILIPS DVD+-RW SDVD8431 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : VY1082Z TWK982D 1.0 acw6pn6d Port 2 ID 0 DMA: Off
CdRomPeripheral : VY1082Z TWK982D 1.0 acw6pn6d Port 2 ID 1 DMA: Off
CdRomPeripheral : VY1082Z TWK982D 1.0 acw6pn6d Port 2 ID 2 DMA: Off
CdRomPeripheral : VY1082Z TWK982D 1.0 acw6pn6d Port 2 ID 3 DMA: Off
PHILIPS DVD+-RW SDVD8431 D: CDRom0
VY1082Z TWK982D E: CDRom1
VY1082Z TWK982D F: CDRom2
VY1082Z TWK982D G: CDRom3
VY1082Z TWK982D H: CDRom4
Physical memory : 511MB (523632kB)
Free physical memory: 87MB (89820kB)
Memory in use : 82 %
11.3.2008
Image CD
09:17:23 #1 Text 0 File Burncd.cpp, Line 2868
09:17:23 #2 Text 0 File Reader.cpp, Line 127
09:17:23 #3 Text 0 File Writer.cpp, Line 122
Writer PHILIPS DVD+-RW SDVD8431 running
09:17:23 #4 Text 0 File Burncd.cpp, Line 3153
09:17:24 #5 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 359847 ( 79:59.72)
Last address to be written: 318319 ( 70:46.19)
09:17:24 #6 Text 0 File DlgWaitCD.cpp, Line 272
09:17:24 #7 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: PHILIPS DVD+-RW SDVD8431;
CDR code: 00 97 34 23; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: C0 00 98, 2: 61 22 17 (LI 97:34.23), 3: 4F 3B 49 (LO 79:59.73)
09:17:24 #8 Text 0 File DlgWaitCD.cpp, Line 438
09:17:24 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 (2 - Mode CD-ROM 1, Joliet)
original disc pos #0 + 318320 (318320) = #318320/70:44.20
relocatable, disc pos for caching/writing not required/not required, patch infos
-> TRM_ULTRARAW96_MODE1, 2448, config 4, wanted index0 0 blocks, length 318320 blocks [PHILIPS DVD+-RW SDVD8431]
09:17:24 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [PHILIPS DVD+-RW SDVD8431] for write in raw writing
1: TRM_ULTRARAW96_MODE1, 2448/0x04, FilePos 0 367200 779614560, ISRC ""
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
318320 | lead-out | 1 | 0x41 | 0x00
09:17:24 #11 Phase 24 File dlgbrnst.cpp, Line 1832
09:17:24 #12 Text 0 File Burncd.cpp, Line 4040
09:17:24 #13 Phase 25 File dlgbrnst.cpp, Line 1832
09:17:24 #14 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 24x (3 600 Ko/s)
09:17:24 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, no disc pos, patch infos, orig at #0): write at #0
09:17:24 #16 Text 0 File Mmc.cpp, Line 16573
StartDAO : CD-Text - Off
09:17:24 #17 Text 0 File Mmc.cpp, Line 21353
09:19:25 #18 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04F00000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x80 0x7A 0x00 0x00 0x1A 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x0C 0x00
09:19:25 #19 CDR -1135 File Writer.cpp, Line 311
Write error
09:19:25 #20 Text 0 File ThreadedTransfer.cpp, Line 228
09:19:25 #21 Text 0 File ThreadedTransfer.cpp, Line 222
09:19:25 #22 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 24x (3 600 Ko/s)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 21:59:44 (Adapter driver for rec)
Free physical memory: 70MB (72312kB)
Memory in use : 86 %
11.3.2008
Image CD
09:21:33 #1 Text 0 File Burncd.cpp, Line 2868
09:21:33 #2 Text 0 File Reader.cpp, Line 127
09:21:33 #3 Text 0 File Writer.cpp, Line 122
09:21:33 #4 Text 0 File Burncd.cpp, Line 3153
09:21:33 #5 Text 0 File DlgWaitCD.cpp, Line 260
09:21:33 #6 Text 0 File DlgWaitCD.cpp, Line 272
09:21:33 #7 Text 0 File DlgWaitCD.cpp, Line 2339
CDRW code: 00 97 25 30; OSJ entry from: INFODISC Technology Co., Ltd.
ATIP Data:
Special Info [hex] 1: B3 00 CE, 2: 61 19 1E (LI 97:25.30), 3: 4F 3B 49 (LO 79:59.73)
Additional Info [hex] 1: 24 1A D8, 2: 26 B2 4A, 3: 00 00 00 (invalid)
09:21:33 #8 Text 0 File DlgWaitCD.cpp, Line 438
09:21:33 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
09:21:33 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
09:21:33 #11 Phase 24 File dlgbrnst.cpp, Line 1832
09:21:33 #12 Text 0 File Burncd.cpp, Line 4040
09:21:33 #13 Phase 25 File dlgbrnst.cpp, Line 1832
09:21:33 #14 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 10x (1 500 Ko/s)
09:21:33 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
09:21:33 #16 Text 0 File Mmc.cpp, Line 16573
09:21:33 #17 Text 0 File Mmc.cpp, Line 21353
09:22:56 #18 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x033F0000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x7B 0x32 0x00 0x00 0x1A 0x00 0x00 0x00
09:22:56 #19 CDR -1135 File Writer.cpp, Line 311
Write error
09:22:56 #20 Text 0 File ThreadedTransfer.cpp, Line 228
09:22:56 #21 Text 0 File ThreadedTransfer.cpp, Line 222
09:22:56 #22 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 10x (1 500 Ko/s)
Free physical memory: 81MB (83524kB)
Memory in use : 84 %
11.3.2008
Image CD
09:23:54 #1 Text 0 File Burncd.cpp, Line 2868
09:23:54 #2 Text 0 File Reader.cpp, Line 127
09:23:54 #3 Text 0 File Writer.cpp, Line 122
09:23:54 #4 Text 0 File Burncd.cpp, Line 3153
09:23:54 #5 Text 0 File DlgWaitCD.cpp, Line 260
09:23:54 #6 Text 0 File DlgWaitCD.cpp, Line 272
09:23:54 #7 Text 0 File DlgWaitCD.cpp, Line 2339
CDRW code: 00 97 34 22; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: E1 00 C6, 2: 61 22 16 (LI 97:34.22), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 02 3A B0, 2: 5C C6 26, 3: 00 00 00 (invalid)
09:23:54 #8 Text 0 File DlgWaitCD.cpp, Line 438
09:23:54 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
09:23:55 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
09:23:55 #11 Phase 24 File dlgbrnst.cpp, Line 1832
09:23:55 #12 Text 0 File Burncd.cpp, Line 4040
09:23:55 #13 Phase 25 File dlgbrnst.cpp, Line 1832
09:23:55 #14 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (600 Ko/s)
09:23:55 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
09:23:55 #16 Text 0 File Mmc.cpp, Line 16573
09:23:55 #17 Text 0 File Mmc.cpp, Line 21353
09:26:36 #18 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03400000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x78 0xF6 0x00 0x00 0x1A 0x00 0x00 0x00
09:26:36 #19 CDR -1135 File Writer.cpp, Line 311
Write error
09:26:36 #20 Text 0 File ThreadedTransfer.cpp, Line 228
09:26:36 #21 Text 0 File ThreadedTransfer.cpp, Line 222
09:26:36 #22 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (600 Ko/s)
Free physical memory: 77MB (79016kB)
11.3.2008
Image CD
09:28:19 #1 Text 0 File Burncd.cpp, Line 2868
09:28:19 #2 Text 0 File Reader.cpp, Line 127
09:28:19 #3 Text 0 File Writer.cpp, Line 122
09:28:19 #4 Text 0 File Burncd.cpp, Line 3153
09:28:19 #5 Text 0 File DlgWaitCD.cpp, Line 260
09:28:19 #6 Text 0 File DlgWaitCD.cpp, Line 272
09:28:19 #7 Text 0 File DlgWaitCD.cpp, Line 2339
CDRW code: 00 97 10 00; CD manufacturer unknown
ATIP Data:
Special Info [hex] 1: A3 00 CE, 2: 61 0A 00 (LI 97:10.00), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 24 1A D8, 2: 26 B2 48, 3: 00 00 00 (invalid)
09:28:19 #8 Text 0 File DlgWaitCD.cpp, Line 438
09:28:19 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
09:28:19 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
09:28:19 #11 Phase 24 File dlgbrnst.cpp, Line 1832
09:28:19 #12 Text 0 File Burncd.cpp, Line 4040
09:28:19 #13 Phase 25 File dlgbrnst.cpp, Line 1832
09:28:19 #14 Phase 36 File dlgbrnst.cpp, Line 1832
09:28:20 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
09:28:20 #16 Text 0 File Mmc.cpp, Line 16573
09:28:20 #17 Text 0 File Mmc.cpp, Line 21353
09:29:46 #18 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x033D0000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x7B 0xE8 0x00 0x00 0x1A 0x00 0x00 0x00
09:29:46 #19 CDR -1135 File Writer.cpp, Line 311
Write error
09:29:47 #20 Text 0 File ThreadedTransfer.cpp, Line 228
09:29:47 #21 Text 0 File ThreadedTransfer.cpp, Line 222
09:29:47 #22 Phase 38 File dlgbrnst.cpp, Line 1832
Free physical memory: 130MB (133676kB)
Memory in use : 74 %
11.3.2008
CD-ROM (ISO)
09:31:04 #1 Text 0 File Isodoc.cpp, Line 6179
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
09:31:04 #2 Text 0 File Burncd.cpp, Line 2868
09:31:04 #3 Text 0 File Reader.cpp, Line 127
09:31:04 #4 Text 0 File Writer.cpp, Line 122
09:31:04 #5 ISO9660GEN -11 File geniso.cpp, Line 3293
09:31:04 #6 Text 0 File Burncd.cpp, Line 3153
09:31:05 #7 Text 0 File DlgWaitCD.cpp, Line 260
Last address to be written: 76533 ( 17:02.33)
09:31:05 #8 Text 0 File DlgWaitCD.cpp, Line 272
09:31:05 #9 Text 0 File DlgWaitCD.cpp, Line 2339
ATIP Data:
09:31:05 #10 Text 0 File DlgWaitCD.cpp, Line 438
09:31:05 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 76534 (76534) = #76534/17:0.34
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 76532 blocks [PHILIPS DVD+-RW SDVD8431]
09:31:05 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [PHILIPS DVD+-RW SDVD8431] for write in TAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 157048832, ISRC ""
76534 | lead-out | 1 | 0x41 | 0x00
09:31:05 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1111
Removed 2 run-out blocks from end of track 1. Length: 76534 -> 76532.
09:31:05 #14 Phase 24 File dlgbrnst.cpp, Line 1832
09:31:05 #15 Text 0 File Burncd.cpp, Line 4040
09:31:05 #16 Phase 25 File dlgbrnst.cpp, Line 1832
09:31:05 #17 Phase 36 File dlgbrnst.cpp, Line 1832
09:31:05 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2609
09:31:05 #19 Text 0 File Mmc.cpp, Line 21353
09:32:05 #20 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x098B0000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x79 0x80 0x00 0x00 0x20 0x00 0x00 0x00
09:32:05 #21 CDR -1135 File Writer.cpp, Line 311
Write error
09:32:06 #22 Text 0 File ThreadedTransfer.cpp, Line 228
09:32:06 #23 Text 0 File ThreadedTransfer.cpp, Line 222
09:32:06 #24 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
PHILIPS DVD+-RW SDVD8431\H1 T0
09:32:06 #25 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
09:32:06 #26 Text 0 File Mmc.cpp, Line 16001
<PHILIPS DVD+-RW SDVD8431> start Close Session
09:32:51 #27 Phase 38 File dlgbrnst.cpp, Line 1832
Adapter driver: <asvz83hq> HA 2
CdRomPeripheral : VY1082Z TWK982D 1.0 asvz83hq Port 2 ID 0 DMA: Off
CdRomPeripheral : VY1082Z TWK982D 1.0 asvz83hq Port 2 ID 1 DMA: Off
CdRomPeripheral : VY1082Z TWK982D 1.0 asvz83hq Port 2 ID 2 DMA: Off
CdRomPeripheral : VY1082Z TWK982D 1.0 asvz83hq Port 2 ID 3 DMA: Off
Free physical memory: 64MB (65956kB)
Memory in use : 87 %
12.3.2008
Image CD
12:54:59 #1 Text 0 File Burncd.cpp, Line 2868
12:54:59 #2 Text 0 File Reader.cpp, Line 127
12:54:59 #3 Text 0 File Writer.cpp, Line 122
12:54:59 #4 Text 0 File Burncd.cpp, Line 3153
12:54:59 #5 Text 0 File DlgWaitCD.cpp, Line 260
12:54:59 #6 Text 0 File DlgWaitCD.cpp, Line 272
12:54:59 #7 Text 0 File DlgWaitCD.cpp, Line 2339
ATIP Data:
12:54:59 #8 Text 0 File DlgWaitCD.cpp, Line 438
12:54:59 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
12:54:59 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
12:55:00 #11 Phase 24 File dlgbrnst.cpp, Line 1832
12:55:00 #12 Text 0 File Burncd.cpp, Line 4040
12:55:00 #13 Phase 25 File dlgbrnst.cpp, Line 1832
12:55:00 #14 Phase 36 File dlgbrnst.cpp, Line 1832
12:55:00 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
12:55:00 #16 Text 0 File Mmc.cpp, Line 16573
12:55:00 #17 Text 0 File Mmc.cpp, Line 21353
12:56:27 #18 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x09BB0000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x7B 0x9A 0x00 0x00 0x1A 0x00 0x00 0x00
12:56:27 #19 CDR -1135 File Writer.cpp, Line 311
Write error
12:56:27 #20 Text 0 File ThreadedTransfer.cpp, Line 228
12:56:27 #21 Text 0 File ThreadedTransfer.cpp, Line 222
12:56:28 #22 Phase 38 File dlgbrnst.cpp, Line 1832
Free physical memory: 79MB (81024kB)
12.3.2008
Image CD
13:08:46 #1 Text 0 File Burncd.cpp, Line 2868
13:08:46 #2 Text 0 File Reader.cpp, Line 127
13:08:46 #3 Text 0 File Writer.cpp, Line 122
13:08:46 #4 Text 0 File Burncd.cpp, Line 3153
13:08:46 #5 Text 0 File DlgWaitCD.cpp, Line 260
13:08:46 #6 Text 0 File DlgWaitCD.cpp, Line 272
13:08:46 #7 Text 0 File DlgWaitCD.cpp, Line 2339
ATIP Data:
13:08:46 #8 Text 0 File DlgWaitCD.cpp, Line 438
13:08:46 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
13:08:46 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
13:08:47 #11 Phase 24 File dlgbrnst.cpp, Line 1832
13:08:47 #12 Text 0 File Burncd.cpp, Line 4040
13:08:47 #13 Phase 25 File dlgbrnst.cpp, Line 1832
13:08:47 #14 Phase 36 File dlgbrnst.cpp, Line 1832
13:08:47 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
13:08:47 #16 Text 0 File Mmc.cpp, Line 16573
13:08:47 #17 Text 0 File Mmc.cpp, Line 21353
13:10:09 #18 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03370000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x78 0x5A 0x00 0x00 0x1A 0x00 0x00 0x00
13:10:09 #19 CDR -1135 File Writer.cpp, Line 311
Write error
13:10:09 #20 Text 0 File ThreadedTransfer.cpp, Line 228
13:10:09 #21 Text 0 File ThreadedTransfer.cpp, Line 222
13:10:09 #22 Phase 38 File dlgbrnst.cpp, Line 1832
Free physical memory: 95MB (97692kB)
Memory in use : 81 %
12.3.2008
CD-ROM (ISO)
13:23:53 #1 Text 0 File Isodoc.cpp, Line 6179
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : TAO
Mode : 1
Joliet : TRUE
13:23:53 #2 Text 0 File Burncd.cpp, Line 2868
13:23:53 #3 Text 0 File Reader.cpp, Line 127
13:23:53 #4 Text 0 File Writer.cpp, Line 122
13:23:53 #5 ISO9660GEN -11 File geniso.cpp, Line 3293
13:23:53 #6 Text 0 File Burncd.cpp, Line 3153
13:23:53 #7 Text 0 File DlgWaitCD.cpp, Line 260
Last address to be written: 318320 ( 70:46.20)
13:23:53 #8 Text 0 File DlgWaitCD.cpp, Line 272
13:23:53 #9 Text 0 File DlgWaitCD.cpp, Line 2339
ATIP Data:
13:23:53 #10 Text 0 File DlgWaitCD.cpp, Line 438
13:23:53 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
original disc pos #0 + 318321 (318321) = #318321/70:44.21
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 318319 blocks [PHILIPS DVD+-RW SDVD8431]
13:23:53 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 652228608, ISRC ""
318321 | lead-out | 1 | 0x41 | 0x00
13:23:53 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1111
Removed 2 run-out blocks from end of track 1. Length: 318321 -> 318319.
13:23:55 #14 Phase 24 File dlgbrnst.cpp, Line 1832
13:23:55 #15 Text 0 File Burncd.cpp, Line 4040
13:23:55 #16 Phase 25 File dlgbrnst.cpp, Line 1832
13:23:55 #17 Phase 36 File dlgbrnst.cpp, Line 1832
13:23:55 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2609
13:23:55 #19 Text 0 File Mmc.cpp, Line 21353
13:25:04 #20 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x098F0000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x7A 0x80 0x00 0x00 0x20 0x00 0x00 0x00
13:25:04 #21 CDR -1135 File Writer.cpp, Line 311
Write error
13:25:04 #22 Text 0 File ThreadedTransfer.cpp, Line 228
13:25:04 #23 Text 0 File ThreadedTransfer.cpp, Line 222
13:25:04 #24 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
13:25:04 #25 TRANSFER -18 File WriterStatus.cpp, Line 200
13:25:04 #26 Text 0 File Mmc.cpp, Line 16001
13:25:45 #27 Phase 38 File dlgbrnst.cpp, Line 1832
Adapter driver: <aimlhme3> HA 2
CdRomPeripheral : VY1082Z TWK982D 1.0 aimlhme3 Port 2 ID 0 DMA: Off
CdRomPeripheral : VY1082Z TWK982D 1.0 aimlhme3 Port 2 ID 1 DMA: Off
CdRomPeripheral : VY1082Z TWK982D 1.0 aimlhme3 Port 2 ID 2 DMA: Off
CdRomPeripheral : VY1082Z TWK982D 1.0 aimlhme3 Port 2 ID 3 DMA: Off
Free physical memory: 85MB (87540kB)
Memory in use : 83 %
12.3.2008
Image CD
14:22:24 #1 Text 0 File Burncd.cpp, Line 2868
14:22:24 #2 Text 0 File Reader.cpp, Line 127
14:22:24 #3 Text 0 File Writer.cpp, Line 122
14:22:24 #4 Text 0 File Burncd.cpp, Line 3153
14:22:24 #5 Text 0 File DlgWaitCD.cpp, Line 260
14:22:24 #6 Text 0 File DlgWaitCD.cpp, Line 272
14:22:24 #7 Text 0 File DlgWaitCD.cpp, Line 2339
ATIP Data:
14:22:24 #8 Text 0 File DlgWaitCD.cpp, Line 438
14:22:24 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
14:22:24 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
14:22:24 #11 Phase 24 File dlgbrnst.cpp, Line 1832
14:22:24 #12 Text 0 File Burncd.cpp, Line 4040
14:22:24 #13 Phase 25 File dlgbrnst.cpp, Line 1832
14:22:24 #14 Phase 36 File dlgbrnst.cpp, Line 1832
14:22:24 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
14:22:24 #16 Text 0 File Mmc.cpp, Line 16573
14:22:24 #17 Text 0 File Mmc.cpp, Line 21353
14:23:51 #18 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04F20000
Sense Code: 0x0C
Sense Qual: 0x00
14:23:51 #19 CDR -1135 File Writer.cpp, Line 311
Write error
14:23:51 #20 Text 0 File ThreadedTransfer.cpp, Line 228
14:23:51 #21 Text 0 File ThreadedTransfer.cpp, Line 222
14:23:51 #22 Phase 38 File dlgbrnst.cpp, Line 1832
Free physical memory: 45MB (46128kB)
Memory in use : 91 %
12.3.2008
Image CD
18:31:24 #1 Text 0 File Burncd.cpp, Line 2868
18:31:24 #2 Text 0 File Reader.cpp, Line 127
18:31:24 #3 Text 0 File Writer.cpp, Line 122
18:31:25 #4 Text 0 File Burncd.cpp, Line 3153
18:31:25 #5 Text 0 File DlgWaitCD.cpp, Line 260
18:31:25 #6 Text 0 File DlgWaitCD.cpp, Line 272
18:31:25 #7 Text 0 File DlgWaitCD.cpp, Line 2339
CDRW code
