par lab » 17 Juin 2007 17:37
Merci de ton aide
ci joint lelog de nero
sara
1A23-6026-2148-xxxxxxxxxxxxxxxxxxx
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:34
Nero Version: 6.6.0.8 (Nero Express)
Recorder: <TSSTcorp CD/DVDW TS-H552U>Version: US06 - HA 1 TA 0 - 6.6.0.8
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
CD-ROM: < JLMS DVD-ROM LTD-166S>Version: DIS2 - HA 1 TA 1 - 6.6.0.8
DiskPeripheral : ST380020A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp CD/DVDW TS-H552U atapi Port 1 ID 0 DMA: On
CdRomPeripheral : JLMS DVD-ROM LTD-166S atapi Port 1 ID 1 DMA: On
CdRomPeripheral : VOBID InstantDrive CD 14 VOBID Port 2 ID 0 DMA: Off
TSSTcorp CD/DVDW TS-H552 D: CDRom0
JLMS DVD-ROM LTD-166S E: CDRom1
VOBID InstantDrive CD F: CDRom2
Free physical memory: 222MB (228156kB)
Memory in use : 56 %
17.6.2007
ISO compilation
18:32:18 #1 Text 0 File Isodoc.cpp, Line 6172
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
18:32:18 #2 Text 0 File Reader.cpp, Line 127
18:32:18 #3 Text 0 File Writer.cpp, Line 122
Writer TSSTcorp CD/DVDW TS-H552U running
18:32:18 #4 ISO9660GEN -11 File geniso.cpp, Line 3293
18:32:18 #5 Text 0 File Burncd.cpp, Line 3153
18:32:18 #6 Text 0 File DlgWaitCD.cpp, Line 259
Last address to be written: 1798639 (399:41.64, 3512MB)
18:32:18 #7 Text 0 File DlgWaitCD.cpp, Line 271
18:32:18 #8 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: TSSTcorp CD/DVDW TS-H552U, Media type: DVD-RW
Disc Manufacturer: RITEKW - 01
Disc Application Code: 64, Disc Physical Code: 214
18:32:18 #9 Text 0 File DlgWaitCD.cpp, Line 433
18:32:18 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 1798640 (1798640) = #1798640/399:41.65
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1798640 blocks [TSSTcorp CD/DVDW TS-H552U]
18:32:18 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [TSSTcorp CD/DVDW TS-H552U] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3683614720, ISRC ""
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1798640 | lead-out | 1 | 0x41 | 0x00
18:32:19 #12 Phase 24 File dlgbrnst.cpp, Line 1832
18:32:19 #13 Text 0 File Burncd.cpp, Line 4040
18:32:19 #14 Phase 25 File dlgbrnst.cpp, Line 1832
18:32:19 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 2x (2 770 KB/s)
18:32:19 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2609
18:32:19 #17 Text 0 File DVDMinusRW.cpp, Line 269
Perform 'Quick Format' (type 15h) to set disc in 'Restricted Overwrite Mode'.
18:32:19 #18 Phase 136 File dlgbrnst.cpp, Line 1832
Quick Format DVD-RW
18:32:46 #19 Phase 65 File dlgbrnst.cpp, Line 1832
18:32:46 #20 Text 0 File DVDR.cpp, Line 2194
Recording mode: Restricted Overwrite Mode
18:32:46 #21 Text 0 File Mmc.cpp, Line 21235
Set BUFE: Super Link -> ON
18:32:46 #22 Text 0 File DVDR.cpp, Line 2340
18:32:46 #23 Text 0 File Cdrdrv.cpp, Line 8430
Book Type: DVD-RW (3), Part Version: 2
End Physical Sector Number of Data Area: 30000 h
Media Specific [16..63]:
18:32:49 #24 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x05300000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x64
Sense Qual: 0x00
0x00 0x00 0x00 0x00 0x64 0x00
18:32:49 #25 CDR -1047 File Writer.cpp, Line 311
Illegal mode for this track
18:32:49 #26 Text 0 File ThreadedTransfer.cpp, Line 228
18:32:49 #27 Text 0 File ThreadedTransfer.cpp, Line 222
18:32:49 #28 Text 0 File DVDR.cpp, Line 2603
EndDAO: Last written address was -1
18:32:49 #29 Phase 133 File dlgbrnst.cpp, Line 1832
Writing short lead-out
18:34:09 #30 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 2x (2 770 KB/s)
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 23/04/2007 02:15:25
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 23/04/2007 02:15:25 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.10 (xpclnt_qfe.010827-1803), size=86656 bytes, created 29/08/2001 12:56:42 (Adapter driver for rec)
