par malcolm89 » 16 Fév 2007 14:29
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 06/05/2002 11:01:14
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero Version: 6.6.0.12
Internal Version: 6, 6, 0, 12c
(Nero Express)
Recorder: <PLEXTOR DVDR PX-716AL> Version: 1.02 - HA 3 TA 1 - 6.6.0.12
Adapter driver: <atapi> HA 3
Drive buffer : 8192kB
CD-ROM: <PLEXTOR CD-R PREMIUM >Version: 1.06 - HA 3 TA 0 - 6.6.0.12
DiskPeripheral : WDC WD205BA atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST380011A atapi Port 0 ID 1 DMA: On
DiskPeripheral : Maxtor 6Y200M0 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : PLEXTOR CD-R PREMIUM atapi Port 3 ID 0 DMA: On
CdRomPeripheral : PLEXTOR DVDR PX-716AL atapi Port 3 ID 1 DMA: On
PLEXTOR CD-R PREMIUM G: CDRom3
PLEXTOR DVDR PX-716AL H: CDRom5
Physical memory : 1022MB (1047280kB)
Free physical memory: 492MB (504300kB)
Memory in use : 51 %
16.2.2007
Graver une image DVD
14:23:55 #1 Text 0 File Reader.cpp, Line 127
14:23:55 #2 Text 0 File Writer.cpp, Line 122
Writer PLEXTOR DVDR PX-716AL running
14:23:55 #3 Text 0 File Burncd.cpp, Line 3153
14:23:55 #4 Text 0 File DlgWaitCD.cpp, Line 260
Last address to be written: 1050981 (233:33.06, 2052MB)
14:23:55 #5 Text 0 File DlgWaitCD.cpp, Line 272
14:23:55 #6 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: PLEXTOR DVDR PX-716AL, Media type: DVD+R
Disc Manufacturer ID: MBIPG101, Media Type ID: R03, Product revision number: 0
14:23:55 #7 Text 0 File DlgWaitCD.cpp, Line 438
14:23:55 #8 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 (2 - Mode CD-ROM 1, ISO 9660)
original disc pos #0 + 1050982 (1050982) = #1050982/233:33.7
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1050982 blocks [PLEXTOR DVDR PX-716AL]
14:23:55 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [PLEXTOR DVDR PX-716AL] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2152411136, ISRC ""
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1050982 | lead-out | 1 | 0x41 | 0x00
14:23:55 #10 Phase 24 File dlgbrnst.cpp, Line 1832
14:23:55 #11 Text 0 File Burncd.cpp, Line 4037
14:23:55 #12 Phase 25 File dlgbrnst.cpp, Line 1832
14:23:55 #13 Phase 36 File dlgbrnst.cpp, Line 1832
14:23:55 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2609
14:23:55 #15 Text 0 File Cdrdrv.cpp, Line 8438
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 258
Book Type: DVD+R (10), Part Version: 1
Media type ID: R03
Media Specific [16..63]:
00 00 01 4D 42 49 50 47 - 31 30 31 52 30 33 00 38 ...MBIPG101R03.8
23 54 37 13 02 4A 71 02 - 90 66 16 16 0B 0B 0A 0A #T7..Jq..f......
01 1C 1E 0B 0C 12 12 01 - 00 00 00 00 00 00 00 00 ................
14:23:55 #16 Text 0 File DVDR.cpp, Line 5130
Drive: PLEXTOR DVDR PX-716AL
Book Type request [PX]: DVD-ROM
14:23:55 #17 CDR -1207 File DVDR.cpp, Line 4777
14:23:55 #18 Text 0 File DVDPlusRW.cpp, Line 648
14:23:57 #19 Text 0 File Cdrdrv.cpp, Line 1288
14:23:57.562 - PLEXTOR DVDR PX-716AL\H3 T1 : Queue again later
14:24:20 #20 SCSI -1039 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 3, TA 1, LUN 0, buffer 0x03C14A00
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x5C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x09 0x01
14:24:20 #21 SCSI -1066 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 3, TA 1, LUN 0, buffer 0x0C2A0000
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x24 0x00
14:24:20 #22 CDR -1039 File Writer.cpp, Line 311
Focus or tracking error
14:24:20 #23 Text 0 File ThreadedTransfer.cpp, Line 228
14:24:20 #24 Text 0 File ThreadedTransfer.cpp, Line 222
14:24:20 #25 SCSI -1176 File Cdrdrv.cpp, Line 1182
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x04
14:24:20 #26 Phase 127 File dlgbrnst.cpp, Line 1832
14:24:20 #27 Phase 129 File dlgbrnst.cpp, Line 1832
14:24:20 #28 Text 0 File DVDR.cpp, Line 5130
Book Type request [PX]: DVD+R
14:24:20 #29 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5 540 Ko/s)
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 06/05/2002 11:01:08
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 05/12/2005 06:12:26 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 22:59:44 (Adapter driver for rec)
Si sa peu vous aider pour mon probleme
