power calibration error
Messagepar cramisa » 06 Déc 2002 14:23
Salut, j'ai toujours un pb de gravage non résolu;
J'ai XP et Nero Burning, si je lance un gravage de CD audio, (j'ai essayé quatre marques de CD différentes), j'ai le message suivant:
XXXXXXXXXXXXXXXXXXXXXXXX
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 25/06/2002 17:34:54
Nero Version: 5.5.9.17
Recorder: <IDE-CD R/RW 8x4x32> Version: 2.0 - HA 1 TA 0 - 5.5.9.17
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
CD-ROM: <Memorex DVD-MAXX 1648 AJ>Version: GWH2 - HA 2 TA 1 - 5.5.9.17
Adapter driver: <hpt3xx> HA 2
DiskPeripheral : ST360021A atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST360021A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : IDE-CD R/RW 8x4x32 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : Memorex DVD-MAXX 1648 AJGWH2 hpt3xx Port 2 ID 1 DMA: ?
OtherPeripheral : HPT RCM DEVICE hpt3xx Port 2 ID 0 DMA: ?
CmdQueuing : 1
CmdNotification: 2
EraseSpeed : 0
Physical memory : 767MB (785904kB)
Free physical memory: 406MB (415848kB)
Memory in use : 47 %
Wizard: Off
30.11.2002
CD Audio
11:55:41 #1 CDADOC -1 File Cdadoc.cpp, Line 1620
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: Off,
Cache small files: No,
Audio Multisession: No
List of audio tracks:
Track 01: Length: 03:16.70, Pause frames: 150, Filters: 0, Name: 'cd1-01 - Mon amant de Saint-Jean.wav'.
Track 02: Length: 03:40.35, Pause frames: 150, Filters: 0, Name: 'cd1-02 - Menilmontant.wav'.
Track 03: Length: 03:08.66, Pause frames: 150, Filters: 0, Name: 'cd1-03 - Ah, si vous connaissiez ma poule.wav'.
Track 04: Length: 02:45.32, Pause frames: 150, Filters: 0, Name: 'cd1-04- Paris, je t'aime d'amour.wav'.
Track 05: Length: 03:46.36, Pause frames: 150, Filters: 0, Name: 'cd1-05- Que reste t'il de nos amours.wav'.
Track 06: Length: 02:52.38, Pause frames: 150, Filters: 0, Name: 'cd1-06-Vous qui passez sans me voir.wav'.
Track 07: Length: 04:36.14, Pause frames: 150, Filters: 0, Name: 'cd1-07-Comme de bien entendu.wav'.
Track 08: Length: 03:53.04, Pause frames: 150, Filters: 0, Name: 'cd1-08- Où sont tous mes amants.wav'.
Track 09: Length: 03:45.11, Pause frames: 150, Filters: 0, Name: 'cd1-09 - j'suis dans la dêche.wav'.
Track 10: Length: 03:25.49, Pause frames: 150, Filters: 0, Name: 'cd1-10- quand on s'promène au bord de.wav'.
Track 11: Length: 02:56.63, Pause frames: 150, Filters: 0, Name: 'cd1-11- Le Temps des cerises.wav'.
Track 12: Length: 03:12.00, Pause frames: 150, Filters: 0, Name: 'cd1-12 - Qu'est ce qu'on attend pour être heureux.wav'.
Total size: 41:43.43
11:55:41 #2 Text 0 File Reader.cpp, Line 115
11:55:41 #3 Text 0 File Writer.cpp, Line 126
Writer IDE-CD R/RW 8x4x32 running
11:55:41 #4 Text 0 File Burncd.cpp, Line 3597
11:55:41 #5 Text 0 File ThreadedTransferInterface.cpp, Line 659
Setup items (original item values)
0: TRM_AUDIO_NOPRE (cd1-01 - Mon amant de Saint-Jean.wav)
original CD pos #0 + 14770 (14770) = #14770/3:16.70
relocatable, CD pos for caching/writing not required/not required, no patch infos
1: TRM_AUDIO_NOPRE (cd1-02 - Menilmontant.wav)
original CD pos #0 + 16535 (16535) = #16535/3:40.35
2: TRM_AUDIO_NOPRE (cd1-03 - Ah, si vous connaissiez ma poule.wav)
original CD pos #0 + 14166 (14166) = #14166/3:8.66
3: TRM_AUDIO_NOPRE (cd1-04- Paris, je t'aime d'amour.wav)
original CD pos #0 + 12407 (12407) = #12407/2:45.32
4: TRM_AUDIO_NOPRE (cd1-05- Que reste t'il de nos amours.wav)
original CD pos #0 + 16986 (16986) = #16986/3:46.36
5: TRM_AUDIO_NOPRE (cd1-06-Vous qui passez sans me voir.wav)
original CD pos #0 + 12938 (12938) = #12938/2:52.38
6: TRM_AUDIO_NOPRE (cd1-07-Comme de bien entendu.wav)
original CD pos #0 + 20714 (20714) = #20714/4:36.14
7: TRM_AUDIO_NOPRE (cd1-08- Où sont tous mes amants.wav)
original CD pos #0 + 17479 (17479) = #17479/3:53.4
8: TRM_AUDIO_NOPRE (cd1-09 - j'suis dans la dêche.wav)
original CD pos #0 + 16886 (16886) = #16886/3:45.11
9: TRM_AUDIO_NOPRE (cd1-10- quand on s'promène au bord de.wav)
original CD pos #0 + 15424 (15424) = #15424/3:25.49
10: TRM_AUDIO_NOPRE (cd1-11- Le Temps des cerises.wav)
original CD pos #0 + 13263 (13263) = #13263/2:56.63
11: TRM_AUDIO_NOPRE (cd1-12 - Qu'est ce qu'on attend pour être heureux.wav)
original CD pos #0 + 14400 (14400) = #14400/3:12.0
11:55:41 #6 Text 0 File DlgWaitCD.cpp, Line 203
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 187617 (41:43.42)
11:55:41 #7 Text 0 File DlgWaitCD.cpp, Line 208
11:55:41 #8 Text 0 File DlgWaitCD.cpp, Line 1420
Recorder: IDE-CD R/RW 8x4x32;
CDRW code: 00 97 27 00; OSJ entry from: DIGITAL STORAGE TECHNOLOGY CO.,LTD
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 00 (LI 97:27.00), 3: 4F 3B 4A (LO 79:59.74)
11:55:41 #9 Text 0 File ThreadedTransferInterface.cpp, Line 811
Prepare recorder IDE-CD R/RW 8x4x32 for write in raw writing
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 12:
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 0 355200 35330560
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 35330560 35685760 74840640
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 74840640 75195840 108740928
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 108740928 109096128 138475904
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 138475904 138831104 179053952
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 179053952 179409152 210046336
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 210046336 210401536 259452288
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 259452288 259807488 301197760
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 301197760 301552960 341539008
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 341539008 341894208 378418240
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 378418240 378773440 410180224
TRM_AUDIO_ULTRARAW_NOPRE, 2368/0x0, ISRC "", FilePos 410180224 410535424 444634624
11:55:41 #10 Text 0 File ThreadedTransferInterface.cpp, Line 659
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 14770 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 16535 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 14166 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 12407 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 16986 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 12938 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 20714 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 17479 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 16886 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 15424 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 13263 blocks [IDE-CD R/RW 8x4x32 ]
-> TRM_AUDIO_ULTRARAW_NOPRE, 2368, config 0, wanted index0 0 blocks, length 14400 blocks [IDE-CD R/RW 8x4x32 ]
11:55:41 #11 Phase 32 File dlgbrnst.cpp, Line 1574
Simulation started at 8x (1 200 Ko/s)
11:55:41 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
11:55:41 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 1 (relocatable, no CD pos, no patch infos, orig at #0): write at #14920
11:55:41 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 2 (relocatable, no CD pos, no patch infos, orig at #0): write at #31605
11:55:41 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 3 (relocatable, no CD pos, no patch infos, orig at #0): write at #45921
11:55:41 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 4 (relocatable, no CD pos, no patch infos, orig at #0): write at #58478
11:55:41 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 5 (relocatable, no CD pos, no patch infos, orig at #0): write at #75614
11:55:41 #18 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 6 (relocatable, no CD pos, no patch infos, orig at #0): write at #88702
11:55:41 #19 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 7 (relocatable, no CD pos, no patch infos, orig at #0): write at #109566
11:55:41 #20 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 8 (relocatable, no CD pos, no patch infos, orig at #0): write at #127195
11:55:41 #21 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 9 (relocatable, no CD pos, no patch infos, orig at #0): write at #144231
11:55:41 #22 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 10 (relocatable, no CD pos, no patch infos, orig at #0): write at #159805
11:55:41 #23 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 11 (relocatable, no CD pos, no patch infos, orig at #0): write at #173218
11:55:41 #24 Text 0 File Mmc.cpp, Line 12135
StartDAO : CD-Text - Off
12:01:33 #25 Text 0 File ThreadedTransfer.cpp, Line 219
12:01:33 #26 Phase 33 File dlgbrnst.cpp, Line 1574
Simulation completed successfully at 8x (1 200 Ko/s)
12:01:33 #27 Phase 36 File dlgbrnst.cpp, Line 1574
Burn process started at 8x (1 200 Ko/s)
12:01:33 #28 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #29 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #30 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #31 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #32 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #33 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #34 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #35 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #36 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #37 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #38 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #39 Text 0 File ThreadedTransferInterface.cpp, Line 1953
12:01:33 #40 Text 0 File Mmc.cpp, Line 12135
12:02:48 #41 SCSI -1106 File Cdrdrv.cpp, Line 1388
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03790000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0xFF 0xFF 0xD5 0x8B 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x13
0x00 0x00 0x00 0x00 0x73 0x03
12:02:48 #42 MMC -1106 File Writer.cpp, Line 334
Power calibration error
12:02:48 #43 Text 0 File ThreadedTransfer.cpp, Line 219
12:02:49 #44 Text 0 File ThreadedTransfer.cpp, Line 213
12:02:49 #45 Phase 38 File dlgbrnst.cpp, Line 1574
Burn process failed at 8x (1 200 Ko/s)
12:02:49 #46 Text 0 File Scsicmd.cpp, Line 402
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 01:27:50 (Adapter driver for rec)
File 'Drivers\hpt3xx.sys': Ver=Revision v1.0.5 (XPClient.010817-1148), size=38144 bytes, created 28/08/2001 11:00:00 (Adapter driver for src)
lors de mon dernier message, personne n'a pu me donner une bonne réponse, j'espère que là j'en aurais une .
Merci. :bravo:
modéré par syntax error
cramisa
Messagepar syntax error » 06 Déc 2002 19:30
1 - éviter les majuscules
2 - ne pas diffuser ton numéro de license Nero par le biais de ce forum
3 - à même problème, même réponse donc je te renouvelle ma réponse à ta question précédente concernant ta "power calibration error" http://forum.gravure-news.com/viewtopic.php?t=293
ton graveur emploie un processus de calibrage qui ajuste la puissance du laser d'enregistrement à son niveau optimum pour chaque disque.
chaque cd-r et rw possède une valeur de référence.
Il y a également un secteur spécial sur chaque cd-r et rw pour tester et régler le laser du graveur jusqu'au niveau exigé pour brûler le disque.
si ce processus de calibrage échoue, une "power calibration error" se produit...
syntax error
Messagepar PIER » 10 Déc 2002 0:06
Un conseil change le titre de ton message.
Messagepar gowap » 10 Déc 2002 0:10
PIER a écrit:Un conseil change le titre de ton message.
A mon avis, c'est le fruit de la modération par Syntax...
Messagepar syntax error » 10 Déc 2002 8:53
confirmé... je crée un titre explicite
syntax error
