probleme de gravure, tampon trop grand
Messagepar grave » 02 Juil 2006 22:11
j'ai un pro avec nero 7 ultra edition, quand j'esaye de graver un dvd , au bout de quelques secondes ça me marque tampon trop grand
ceux qui fait que la gravure echoue
si pouvez m"aider à resoudre le probleme si dessous voici le fichier log nero
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 13:06:00
NT-SPTI used
Nero Version: 7.2.0.3
Internal Version: 7, 2, 0, 3
Recorder: <HL-DT-ST DVDRAM GSA-4167B>Version: DL11 - HA 1 TA 0 - 7.2.0.3
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
CD-ROM: <HL-DT-ST DVDRAM GSA-4167B>Version: DL11 - HA 1 TA 0 - 7.2.0.3
DiskPeripheral : Maxtor 6K040L0 NAR6 viadsk Port 0 ID 0 DMA: Off
DiskPeripheral : Maxtor 6Y080L0 YAR4 viadsk Port 0 ID 1 DMA: Off
CdRomPeripheral : HL-DT-STDVDRAM GSA-4167BDL11 viadsk Port 1 ID 0 DMA: Off
HL-DT-ST DVDRAM GSA-4167B F: CDRom0
Physical memory : 703MB (720108kB)
Free physical memory: 460MB (471420kB)
Memory in use : 34 %
2.7.2006
Compilation ISO
14:47:29 #1 Text 0 File Isodoc.cpp, Line 6424
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
14:47:29 #2 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 262144KB of Memory
14:47:29 #3 Text 0 File Reader.cpp, Line 124
14:47:29 #4 Text 0 File Writer.cpp, Line 113
Writer F: HL-DT-ST DVDRAM GSA-4167B running
14:47:29 #5 ISO9660GEN -11 File Geniso.cpp, Line 3312
14:47:30 #6 Text 0 File Burncd.cpp, Line 3365
14:48:14 #7 Text 0 File DlgWaitCD.cpp, Line 289
Last possible write address on media: 2297887 (510:38.37, 4488MB)
Last address to be written: 1745791 (387:57.16, 3409MB)
14:48:14 #8 Text 0 File DlgWaitCD.cpp, Line 301
Write in overburning mode: NO (enabled: CD DVD)
14:48:15 #9 Text 0 File DlgWaitCD.cpp, Line 2715
Recorder: HL-DT-ST DVDRAM GSA-4167B, Media type: DVD-RW
Disc Manufacturer: MCC 01 - RW11n9
Disc Application Code: 64, Disc Physical Code: 214
14:48:15 #10 Text 0 File DlgWaitCD.cpp, Line 473
Insert the disc to write to.
(Medium in drive: Inconnu. Medium required by compilation: DVD R/RW, DVD R DL, DVD-RAM.)
This disc is not empty.
(Medium in drive: DVD-RW. Medium required by compilation: DVD R/RW, DVD R DL, DVD-RAM.)
VMS. Disc was erased successfully.
Accessing disc...
14:48:15 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
0: TRM_DATA_MODE1 ()
original disc pos #0 + 1745792 (1745792) = #1745792/387:57.17
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1745792 blocks [F: HL-DT-ST DVDRAM GSA-4167B]
14:48:15 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [F: HL-DT-ST DVDRAM GSA-4167B] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3575382016, ISRC ""
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1745792 | lead-out | 1 | 0x41 | 0x00
14:48:15 #13 Text 0 File SCSIPassThrough.cpp, Line 39
14:48:15 #14 Text 0 File SCSIPassThrough.cpp, Line 84
14:48:15 #15 Phase 24 File dlgbrnst.cpp, Line 1730
14:48:15 #16 Text 0 File Burncd.cpp, Line 4199
14:48:15 #17 Phase 25 File dlgbrnst.cpp, Line 1730
14:48:15 #18 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 2x (2 770 Ko/s)
14:49:24 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2707
14:49:24 #20 Text 0 File DVDR.cpp, Line 2786
Recording mode: Restricted Overwrite Mode
14:49:24 #21 Text 0 File DVDR.cpp, Line 2942
14:49:24 #22 Text 0 File Cdrdrv.cpp, Line 8914
Book Type: DVD-RW (3), Part Version: 1.1x (2)
End Physical Sector Number of Data Area: 30000 h
Media Specific [16..63]:
14:49:34 #23 SPTI -31 File SCSIPassThrough.cpp, Line 290
F: CdRom0: SCSIStatus(x00) WinError(87) NeroError(-31)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x06c80000: Len x10000
14:49:35 #24 SPTI -31 File SCSIPassThrough.cpp, Line 290
Sense Code: 0x00
Sense Qual: 0x00
Buffer x058ef000: Len x10000
14:49:35 #25 Text 0 File MMC.cpp, Line 19628
Writer-Buffer for F: HL-DT-ST DVDRAM GSA-4167B reduced to 32768Bytes
14:49:35 #26 SPTI -31 File SCSIPassThrough.cpp, Line 290
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 10 00 00 00
Buffer x058d5200: Len x8000
14:49:35 #27 CDR -31 File Writer.cpp, Line 302
Buffer too large
14:49:35 #28 Text 0 File ThreadedTransfer.cpp, Line 228
14:49:36 #29 Text 0 File ThreadedTransfer.cpp, Line 222
14:49:36 #30 Text 0 File DVDR.cpp, Line 3182
EndDAO: Last written address was -1
14:49:36 #31 Phase 133 File dlgbrnst.cpp, Line 1730
Writing short lead-out
14:51:30 #32 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 2x (2 770 Ko/s)
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19/05/2006 23:16:24
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 13:06:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 16/05/2006 22:23:54 (Prassi/Veritas driver for win 2K)
grave
Messagepar Scaramanga » 03 Juil 2006 3:57
Le mode DMA ne semble pas activé pour tes périphériques IDE :
Code: Tout sélectionner
A moins qu'un utilitaire de chipset masque ce mode (Intel).
Activer le mode DMA pour tes périphériques IDE
Messagepar grave » 04 Juil 2006 0:43
je fais comme tu dis mais j'ai pas cette option avancée qui me permet d'activer le dma
grave
Messagepar Scaramanga » 04 Juil 2006 4:36
Scaramanga a écrit:A moins qu'un utilitaire de chipset masque ce mode (Intel).
