probleme de lenteur gravue
Messagepar enyce » 16 Jan 2006 14:58
j'ai un probleme avec mon graveur 40x, il a 2 mois et depuis 3 jours un cd audio se grave en 20/30 minutes alors qu'avant il fallait 2 min 30.
je sais plus koi faire apres avoir pris les maj de nero, nettoyer mon ordi, defragmenter,...
le log est:
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero Version: 7.0.1.4
Internal Version: 7, 0, 1, 4
Recorder: <HL-DT-ST DVDRRW GCA-4164B>Version: E.D0 - HA 1 TA 0 - 7.0.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
CD-ROM: <WS5282M SUK338K >Version: 1.0 - HA 1 TA 1 - 7.0.1.4
Adapter driver: <SCSI> HA 1
DiskPeripheral : HDT722516DLA380 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRRW GCA-4164B atapi Port 2 ID 0 DMA: Off
CdRomPeripheral : WS5282M SUK338K 1.0 dtscsi Port 4 ID 0 DMA: Off
CdRomPeripheral : WS5282M SUK338K 1.0 dtscsi Port 4 ID 1 DMA: Off
CdRomPeripheral : WS5282M SUK338K 1.0 dtscsi Port 4 ID 2 DMA: Off
CdRomPeripheral : WS5282M SUK338K 1.0 dtscsi Port 4 ID 3 DMA: Off
HL-DT-ST DVDRRW GCA-4164B E: CDRom0
WS5282M SUK338K K: CDRom1
WS5282M SUK338K L: CDRom2
WS5282M SUK338K M: CDRom3
WS5282M SUK338K N: CDRom4
Physical memory : 958MB (981488kB)
Free physical memory: 494MB (506652kB)
Memory in use : 48
16.1.2006
CD-ROM (ISO)
11:58:17 #1 Text 0 File Isodoc.cpp, Line 6411
Simulate : TRUE
Write : FALSE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 2 / XA
Character set : ISO 9660
Joliet : TRUE
11:58:17 #2 Text 0 File Burncd.cpp, Line 3048
11:58:17 #3 Text 0 File ThreadedTransfer.cpp, Line 525
11:58:17 #4 Text 0 File Reader.cpp, Line 124
11:58:17 #5 Text 0 File Writer.cpp, Line 113
Writer E: HL-DT-ST DVDRRW GCA-4164B running
11:58:17 #6 ISO9660GEN -11 File Geniso.cpp, Line 3312
11:58:17 #7 Text 0 File Burncd.cpp, Line 3342
11:58:17 #8 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 143844 ( 31:59.69)
11:58:17 #9 Text 0 File DlgWaitCD.cpp, Line 291
11:58:17 #10 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: HL-DT-ST DVDRRW GCA-4164B
11:58:17 #11 Text 0 File DlgWaitCD.cpp, Line 458
11:58:17 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
0: TRM_DATA_MODE2_2336 ()
original disc pos #0 + 143845 (143845) = #143845/31:57.70
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 143845 blocks [E: HL-DT-ST DVDRRW GCA-4164B]
11:58:17 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [E: HL-DT-ST DVDRRW GCA-4164B] for write in CUE-sheet-DAO
TOCType: 0x20; Session Closed, disc not fixated
1: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 0 352800 338676240, ISRC ""
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
143845 | lead-out | 1 | 0x41 | 0x00
11:58:17 #14 Text 0 File SCSIPassThrough.cpp, Line 36
11:58:17 #15 Phase 24 File dlgbrnst.cpp, Line 1725
11:58:17 #16 Text 0 File Burncd.cpp, Line 4176
11:58:17 #17 Phase 25 File dlgbrnst.cpp, Line 1725
11:58:17 #18 Phase 32 File dlgbrnst.cpp, Line 1725
Simulation started at 40x (6 000 Ko/s)
11:58:17 #19 SPTI -1189 File SCSIPassThrough.cpp, Line 323
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1189)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 30 02
Buffer x05966800: Len x4000
11:58:17 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685
11:58:18 #21 Text 0 File MMC.cpp, Line 16934
StartDAO : CD-Text - Off
11:58:18 #22 Text 0 File MMC.cpp, Line 17165
CueData, Len=32
41 00 00 34 00 00 00 00
41 01 00 21 00 00 00 00
41 01 01 21 00 00 02 00
41 aa 01 34 00 1f 3b 46
11:59:03 #23 Phase 40 File dlgbrnst.cpp, Line 1412
Aborted by user
11:59:05 #24 SPTI -1119 File SCSIPassThrough.cpp, Line 323
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1119)
Sense Code: 0x09
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 0E 00 00 00 00 09
Buffer x03507600: Len x20
11:59:05 #25 CDR -1119 File WriterStatus.cpp, Line 167
Track following error
11:59:05 #26 TRANSFER -24 File WriterStatus.cpp, Line 167
11:59:05 #27 Phase 35 File dlgbrnst.cpp, Line 1725
Simulation aborted
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 25/04/2005 02:03:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 05/08/2004 12:00:00 (Adapter driver for src)
merci pour votre aide sachant que j'y connais rien, explique comme à un enfant lol merci encore
enyce
Messagepar ditche » 16 Jan 2006 17:37
