problème gravage musique
Messagepar marcramsay » 03 Aoû 2005 0:59
Je ne suis pas capable de graver de la musique soit en mp3 ou en vrai cd audio, mais je suis capable de graver un cd de copie de sauvegarde. J'utilise nero alors voici le log
indows XP 5.1
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 2004-07-22 17:33:44
Version de Nero : 6.3.1.26 (Nero Express)
Graveur : <HL-DT-ST DVDRAM GSA-4163B>Version: A104 - HA 0 TA 1 - 6.3.1.26
Pilote d'adaptateur :<nvidesm> HA 0
Drive buffer : 2048kB
CD-ROM : <HL-DT-ST DVD-ROM GDR8163B>Version: 0L23 - HA 1 TA 0 - 6.3.1.26
Pilote d'adaptateur :<> HA 1
DiskPeripheral : WDC WD2500JB-00GVA0 08.0 nvidesm Port 0 ID 0 DMA: Off
CdRomPeripheral : HL-DT-STDVD-ROM GDR8163B0L23 nvidesm Port 0 ID 0 DMA: Off
CdRomPeripheral : HL-DT-STDVDRAM GSA-4163BA104 nvidesm Port 0 ID 1 DMA: Off
HL-DT-ST DVDRAM GSA-4163 E: CDRom1
HL-DT-ST DVD-ROM GDR8163 D: CDRom0
Physical memory : 511MB (523764kB)
Free physical memory: 110MB (112956kB)
Memory in use : 78 %
1.8.2005
CD Audio
17:03:39 #1 CDADOC -1 File Cdadoc.cpp, Line 1508
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache small files: No,
Audio Multisession: No
List of audio tracks:
Track 01: Length: 02:32.63, Pause frames: 150, Filters: 0, Name: '10 - Tino Rossi - C'est Trop Beau.mp3'.
Track 02: Length: 02:08.54, Pause frames: 150, Filters: 0, Name: '13_-_Donald_Lautrec_-_Tu_Dis_Des_Bêtises.mp3'.
Track 03: Length: 02:51.74, Pause frames: 150, Filters: 0, Name: '15 Kiss Me Quick.mp3'.
Track 04: Length: 02:46.16, Pause frames: 150, Filters: 0, Name: '16 Love_Me_Tender-2002-qm.mp3'.
Track 05: Length: 03:33.47, Pause frames: 150, Filters: 0, Name: '21 - Helmut Lotti - la cucaracha.mp3'.
Track 06: Length: 03:11.02, Pause frames: 150, Filters: 0, Name: 'Achy breaky danse. Track01.mp3'.
Track 07: Length: 02:47.51, Pause frames: 150, Filters: 0, Name: 'Achy breaky heart. Track07.mp3'.
Track 08: Length: 03:31.63, Pause frames: 150, Filters: 0, Name: 'Adamo - Parlami D'Amore .mp3'.
Track 09: Length: 02:44.31, Pause frames: 150, Filters: 0, Name: 'Aiko aiko. Track13.mp3'.
Total size: 26:26.26
17:03:39 #2 Phase 90 File dlgbrnst.cpp, Line 1855
Protection contre les ruptures activée
17:03:40 #3 Text 0 File Reader.cpp, Line 126
17:03:40 #4 Text 0 File AudioCompilationImpl.cpp, Line 817
DRM: Beginning burn process.
17:03:40 #5 Text 0 File Writer.cpp, Line 124
Writer HL-DT-ST DVDRAM GSA-4163B running
17:03:40 #6 Text 0 File Burncd.cpp, Line 3152
Turn on Disque entier, using CD-R/RW media
17:03:40 #7 Text 0 File DlgWaitCD.cpp, Line 247
Last address to be written: 118825 ( 26:26.25)
17:03:40 #8 Text 0 File DlgWaitCD.cpp, Line 259
17:03:40 #9 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: HL-DT-ST DVDRAM GSA-4163B;
CDR code: 00 97 17 06; OSJ entry from: Moser Baer India Limited
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 11 06 (LI 97:17.06), 3: 4F 3B 4A (LO 79:59.74)
17:03:40 #10 Text 0 File DlgWaitCD.cpp, Line 420
17:03:40 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
0: TRM_AUDIO_NOPRE (10 - Tino Rossi - C'est Trop Beau.mp3)
original disc pos #0 + 11463 (11463) = #11463/2:32.63
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11463 blocks [HL-DT-ST DVDRAM GSA-4163B]
1: TRM_AUDIO_NOPRE (13_-_Donald_Lautrec_-_Tu_Dis_Des_Bêtises.mp3)
original disc pos #0 + 9654 (9654) = #9654/2:8.54
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 9654 blocks [HL-DT-ST DVDRAM GSA-4163B]
2: TRM_AUDIO_NOPRE (15 Kiss Me Quick.mp3)
original disc pos #0 + 12899 (12899) = #12899/2:51.74
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12899 blocks [HL-DT-ST DVDRAM GSA-4163B]
3: TRM_AUDIO_NOPRE (16 Love_Me_Tender-2002-qm.mp3)
original disc pos #0 + 12466 (12466) = #12466/2:46.16
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12466 blocks [HL-DT-ST DVDRAM GSA-4163B]
4: TRM_AUDIO_NOPRE (21 - Helmut Lotti - la cucaracha.mp3)
original disc pos #0 + 16022 (16022) = #16022/3:33.47
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16022 blocks [HL-DT-ST DVDRAM GSA-4163B]
5: TRM_AUDIO_NOPRE (Achy breaky danse. Track01.mp3)
original disc pos #0 + 14327 (14327) = #14327/3:11.2
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14327 blocks [HL-DT-ST DVDRAM GSA-4163B]
6: TRM_AUDIO_NOPRE (Achy breaky heart. Track07.mp3)
original disc pos #0 + 12576 (12576) = #12576/2:47.51
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12576 blocks [HL-DT-ST DVDRAM GSA-4163B]
7: TRM_AUDIO_NOPRE (Adamo - Parlami D'Amore .mp3)
original disc pos #0 + 15888 (15888) = #15888/3:31.63
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15888 blocks [HL-DT-ST DVDRAM GSA-4163B]
8: TRM_AUDIO_NOPRE (Aiko aiko. Track13.mp3)
original disc pos #0 + 12331 (12331) = #12331/2:44.31
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12331 blocks [HL-DT-ST DVDRAM GSA-4163B]
17:03:40 #12 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO
Tracks 1 to 9:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 27313776, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 27313776 27666576 50372784, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 50372784 50725584 81064032, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 81064032 81416832 110736864, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 110736864 111089664 148773408, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 148773408 149126208 182823312, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 182823312 183176112 212754864, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 212754864 213107664 250476240, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 250476240 250829040 279831552, ISRC ""
-150 | lead-in | 0 | 0x00 | 0x01
-150 | 1 | 0 | 0x00 | 0x21
0 | 1 | 1 | 0x00 | 0x21
11463 | 2 | 0 | 0x00 | 0x21
11613 | 2 | 1 | 0x00 | 0x21
21267 | 3 | 0 | 0x00 | 0x21
21417 | 3 | 1 | 0x00 | 0x21
34316 | 4 | 0 | 0x00 | 0x21
34466 | 4 | 1 | 0x00 | 0x21
46932 | 5 | 0 | 0x00 | 0x21
47082 | 5 | 1 | 0x00 | 0x21
63104 | 6 | 0 | 0x00 | 0x21
63254 | 6 | 1 | 0x00 | 0x21
77581 | 7 | 0 | 0x00 | 0x21
77731 | 7 | 1 | 0x00 | 0x21
90307 | 8 | 0 | 0x00 | 0x21
90457 | 8 | 1 | 0x00 | 0x21
106345 | 9 | 0 | 0x00 | 0x21
106495 | 9 | 1 | 0x00 | 0x21
118826 | lead-out | 1 | 0x00 | 0x01
17:03:40 #13 Phase 36 File dlgbrnst.cpp, Line 1855
Début de gravure à 40x (6 000 Ko/s)
17:03:40 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2344
17:03:40 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #11613
17:03:40 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #21417
17:03:40 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #34466
17:03:40 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #47082
17:03:40 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #63254
17:03:40 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #77731
17:03:40 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #90457
17:03:40 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #106495
17:03:40 #23 Text 0 File Mmc.cpp, Line 16076
StartDAO : CD-Text - On
17:03:40 #24 Text 0 File Mmc.cpp, Line 20698
Set BUFE: supported -> ON
17:03:40 #25 Text 0 File Mmc.cpp, Line 16365
CueData, Len=160
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 02 22 3f
21 02 01 00 00 02 24 3f
21 03 00 00 00 04 2d 2a
21 03 01 00 00 04 2f 2a
21 04 00 00 00 07 27 29
21 04 01 00 00 07 29 29
21 05 00 00 00 0a 1b 39
21 05 01 00 00 0a 1d 39
21 06 00 00 00 0e 03 1d
21 06 01 00 00 0e 05 1d
21 07 00 00 00 11 10 1f
21 07 01 00 00 11 12 1f
21 08 00 00 00 14 06 07
21 08 01 00 00 14 08 07
21 09 00 00 00 17 27 46
21 09 01 00 00 17 29 46
01 aa 01 01 00 1a 1a 1a
17:03:50 #26 SCSI -500 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0AEA0000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0xFF 0xFF 0xCF 0xAF 0x00 0x02 0xAA 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
17:03:50 #27 CDR -500 File Writer.cpp, Line 304
Commande SCSI interrompue
HL-DT-ST DVDRAM GSA-4163B\H0 T1
17:03:58 #28 Text 0 File ThreadedTransfer.cpp, Line 229
17:03:59 #29 Text 0 File ThreadedTransfer.cpp, Line 223
17:04:21 #30 SCSI -1040 File Cdrdrv.cpp, Line 1191
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x10
Sense Qual: 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x10
0x34 0x1D 0x00 0x80 0x10 0x00
17:04:21 #31 CDR -1040 File WriterStatus.cpp, Line 164
Taille de bloc illégal pour la commande
17:04:21 #32 TRANSFER -24 File WriterStatus.cpp, Line 164
Impossible d'effectuer la fonction Disc At Once
17:04:21 #33 Text 0 File dlgbrnst.cpp, Line 1713
17:04:21 #34 Phase 38 File dlgbrnst.cpp, Line 1855
La gravure a échoué à 40x (6 000 Ko/s)
17:04:21 #35 Text 0 File AudioCompilationImpl.cpp, Line 828
17:04:21 #36 Text 0 File AudioCompilationImpl.cpp, Line 857
File 'Drivers\InCDfs.SYS': Ver=4, 2, 12, 1, size=91136 bytes, created 2004-09-07 16:27:22 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 2, 12, 1, size=28544 bytes, created 2004-09-07 16:27:38 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 2, 12, 1, size=5760 bytes, created 2004-09-07 16:29:08 (InCD4 driver for win NT/2K/XP)
File 'Drivers\nvidesm.sys': Ver=5.10.2600.0307 built by: WinDDK, size=20224 bytes, created 2002-11-13 03:10:00 (Adapter driver for rec)
marcramsay
Re: problème gravage musique
Messagepar aMadEUs » 03 Aoû 2005 1:27
marcramsay a écrit:=== Scsi-Device-Map ===
Pour commencer, active le mode DMA
marcramsay a écrit:Version de Nero : 6.3.1.26 (Nero Express)
et mets à jour ta version de Nero : Nero 6.6.0.15a - le patch français
marcramsay a écrit:17:03:40 #13 Phase 36 File dlgbrnst.cpp, Line 1855
puis, réduis la vitesse de gravure. Haute vitesse de gravure n'a jamais été synonyme de qualité, surtout dans le cas d'un CD Audio qui, je le rappelle, ne bénéficie pas de corrections d'erreurs de haut niveau. Pour l'audio, je ne dépasse jamais 8x.
aMadEUs
Messagepar Stef » 03 Aoû 2005 13:15
En complement de Amadeus, notre tutoriel maison sur la gravure audio avec Nero :
http://www.gravure-news.com/html/tuto/24/page01.php :wink:
Messagepar marcramsay » 03 Aoû 2005 14:40
Dans le gestionnaire de phériphérique, j'ai juste nvidia nforce ide Controller et si je vais dans propriété. je n'ai pas le canal ide principal ainsi que le paramètres avancés, comment-je fais?
merci!
marcramsay
Messagepar Stef » 03 Aoû 2005 14:53
Tu double-cliques dessus et tu dois avoir plusieurs onglets, dont primary channel et secondary channel.
Exemple d'une configuration à base de chipset nforce2 version 2.6
Si tu desactives Let Bios select transfer mode, tu pourras choisir ton mode de transfer. :wink:
Messagepar marcramsay » 03 Aoû 2005 22:44
Je n'ai pas ces options là, j'ai seulement général,pilotes,détails et ressources.
marcramsay
