par KERT » 25 Mar 2006 23:02
Voici le log avec la version 6.3.1.15 :
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 20:18:06
Version de Nero : 6.3.1.15
Graveur : <SONY DVD RW DW-D56A> Version: PFS3 - HA 0 TA 0 - 6.3.1.15
Pilote d'adaptateur :<atapi> HA 0
Drive buffer : 2048kB
CD-ROM : <ZM1534Y NQE352B >Version: 1.0 - HA 4 TA 0 - 6.3.1.15
Pilote d'adaptateur :<dtscsi> HA 4
CdRomPeripheral : SONY DVD RW DW-D56A atapi Port 0 ID 0 DMA: On
DiskPeripheral : HTS541010G9SA00 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : ZM1534Y NQE352B 1.0 dtscsi Port 4 ID 0 DMA: Off
SONY DVD RW DW-D56A F: CDRom0
ZM1534Y NQE352B G: CDRom1
Physical memory : 1023MB (1047856kB)
Free physical memory: 481MB (492940kB)
Memory in use : 52 %
25.3.2006
Compilation ISO
19:51:46 #1 Text 0 File Isodoc.cpp, Line 6065
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
19:51:46 #2 Text 0 File Reader.cpp, Line 118
19:51:46 #3 Text 0 File Writer.cpp, Line 124
Writer SONY DVD RW DW-D56A running
19:51:46 #4 ISO9660GEN -11 File geniso.cpp, Line 3899
19:51:46 #5 Text 0 File Burncd.cpp, Line 3167
19:51:53 #6 Text 0 File DlgWaitCD.cpp, Line 245
Last address to be written: 2204047 (489:47.22, 4304MB)
19:51:53 #7 Text 0 File DlgWaitCD.cpp, Line 257
19:51:53 #8 Text 0 File DlgWaitCD.cpp, Line 2137
Recorder: SONY DVD RW DW-D56A, Media type: DVD+RW
Disc Manufacturer ID: INFODISC, Media Type ID: A10, Product revision number: 1
19:51:53 #9 Text 0 File DlgWaitCD.cpp, Line 418
19:51:53 #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
original disc pos #0 + 2204048 (2204048) = #2204048/489:47.23
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2204048 blocks [SONY DVD RW DW-D56A ]
19:51:53 #11 Text 0 File ThreadedTransferInterface.cpp, Line 983
Prepare recorder [SONY DVD RW DW-D56A ] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4513890304, ISRC ""
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2204048 | lead-out | 1 | 0x00 | 0x41
19:51:54 #12 Phase 24 File dlgbrnst.cpp, Line 1845
19:51:54 #13 Text 0 File Burncd.cpp, Line 4177
19:51:54 #14 Phase 25 File dlgbrnst.cpp, Line 1845
Cache des fichiers terminé
19:51:54 #15 Phase 28 File dlgbrnst.cpp, Line 1845
Début mesure de vitesse
19:51:54 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2343
19:54:33 #17 Text 0 File WriterStatus.cpp, Line 115
<SONY DVD RW DW-D56A > start writing Lead-Out at LBA 2204048 (21A190h), lenght 0 blocks
19:54:33 #18 Text 0 File ThreadedTransfer.cpp, Line 229
19:54:33 #19 Text 0 File dlgbrnst.cpp, Line 1703
19:54:33 #20 Phase 29 File dlgbrnst.cpp, Line 1796
Mesure de vitesse terminée : 20,3x (28 054 Ko/s)
19:54:33 #21 Phase 36 File dlgbrnst.cpp, Line 1845
Début de gravure à 2,4x (3 324 Ko/s)
19:54:33 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2343
19:54:33 #23 Text 0 File Cdrdrv.cpp, Line 8120
Book Type: DVD+RW (9), Part Version: 2
End Physical Sector Number of Data Area: 257DFF h
Media type ID: A10
Media Specific [16..63]:
00 00 01 49 4E 46 4F 44 - 49 53 43 41 31 30 01 39 ...INFODISCA10.9
23 00 9C 7C 5C 02 28 00 - 96 7E 70 02 28 00 9C 7B #..|\.(..~p.(..{
68 02 28 04 04 20 E0 00 - F0 00 00 00 00 00 00 00 h.(.............
19:54:33 #24 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 22:59,235 (1379235ms) -> OK
19:54:33 #25 Text 0 File DVDPlusRW.cpp, Line 607
20:02:55 #26 SCSI -1135 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03720000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x0C 0x02 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x0C 0x00
20:02:55 #27 CDR -1135 File Writer.cpp, Line 304
Erreur écriture
20:02:55 #28 Text 0 File ThreadedTransfer.cpp, Line 229
20:02:55 #29 Text 0 File ThreadedTransfer.cpp, Line 223
20:02:55 #30 Text 0 File dlgbrnst.cpp, Line 1703
20:02:55 #31 Text 0 File dlgbrnst.cpp, Line 1703
20:02:55 #32 Phase 38 File dlgbrnst.cpp, Line 1845
La gravure a échoué à 2,4x (3 324 Ko/s)
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 28/10/2005 11:00:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.10a, size=46080 bytes, created 28/10/2005 11:00:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 22:59:44 (Adapter driver for rec)
File 'Drivers\dtscsi.sys': Ver=?.?.?.?, size=223128 bytes, created 12/03/2006 23:01:33 (Adapter driver for src)
