par jack-hunter » 13 Fév 2006 21:05
excuse moi le fichier log:
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero Version: 7.0.5.4
Internal Version: 7, 0, 5, 4
Recorder: <HL-DT-ST DVDRAM GSA-4167B>Version: DL13 - HA 1 TA 0 - 7.0.5.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
CD-ROM: <HL-DT-ST DVDRAM GSA-4167B>Version: DL13 - HA 1 TA 0 - 7.0.5.4
DiskPeripheral : ST380022A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4167B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : BTC BCE4816IM atapi Port 1 ID 1 DMA: On
HL-DT-ST DVDRAM GSA-4167B D: CDRom0
BTC BCE4816IM E: CDRom1
Free physical memory: 85MB (87248kB)
Memory in use : 83 %
13.2.2006
Compilation ISO
11:29:58 #1 Text 0 File Isodoc.cpp, Line 6414
Simulate : TRUE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
11:29:59 #2 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 262144KB of Memory
11:29:59 #3 Text 0 File Reader.cpp, Line 124
11:29:59 #4 Text 0 File Writer.cpp, Line 113
Writer D: HL-DT-ST DVDRAM GSA-4167B running
11:29:59 #5 ISO9660GEN -11 File Geniso.cpp, Line 3312
11:29:59 #6 Text 0 File Burncd.cpp, Line 3341
11:29:59 #7 Text 0 File DlgWaitCD.cpp, Line 288
Last address to be written: 78079 ( 17:21.04, 152MB)
11:29:59 #8 Text 0 File DlgWaitCD.cpp, Line 300
11:29:59 #9 Text 0 File DlgWaitCD.cpp, Line 2699
Recorder: HL-DT-ST DVDRAM GSA-4167B, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
11:29:59 #10 Text 0 File DlgWaitCD.cpp, Line 472
11:29:59 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
0: TRM_DATA_MODE1 ()
original disc pos #0 + 78080 (78080) = #78080/17:21.5
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 78080 blocks [D: HL-DT-ST DVDRAM GSA-4167B]
11:29:59 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [D: HL-DT-ST DVDRAM GSA-4167B] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 159907840, ISRC ""
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
78080 | lead-out | 1 | 0x41 | 0x00
11:29:59 #13 Text 0 File SCSIPassThrough.cpp, Line 39
11:29:59 #14 Text 0 File SCSIPassThrough.cpp, Line 84
11:29:59 #15 Phase 24 File dlgbrnst.cpp, Line 1730
11:29:59 #16 Text 0 File Burncd.cpp, Line 4175
11:29:59 #17 Phase 25 File dlgbrnst.cpp, Line 1730
11:29:59 #18 Phase 28 File dlgbrnst.cpp, Line 1730
Speed measurement started
11:29:59 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685
11:30:08 #20 Text 0 File WriterStatus.cpp, Line 116
<D: HL-DT-ST DVDRAM GSA-4167B> start writing Lead-Out at LBA 78080 (13100h), length 0 blocks
11:30:08 #21 Text 0 File ThreadedTransfer.cpp, Line 228
11:30:08 #22 Phase 29 File dlgbrnst.cpp, Line 1679
Speed measurement completed: 120,7x (166 658 Ko/s)
11:30:08 #23 Phase 32 File dlgbrnst.cpp, Line 1730
Simulation started at 16x (22 160 Ko/s)
11:30:08 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2685
11:30:08 #25 Text 0 File DVDR.cpp, Line 2699
11:30:08 #26 Text 0 File DVDR.cpp, Line 2855
11:30:09 #27 Text 0 File Cdrdrv.cpp, Line 8663
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ..þ...ÿ.........
11:30:33 #28 Text 0 File WriterStatus.cpp, Line 116
11:30:34 #29 Text 0 File ThreadedTransfer.cpp, Line 228
11:30:34 #30 Text 0 File DVDR.cpp, Line 3095
EndDAO: Last written address was 78079
11:30:36 #31 Phase 133 File dlgbrnst.cpp, Line 1730
Writing short lead-out
11:30:40 #32 Phase 33 File dlgbrnst.cpp, Line 1730
Simulation completed successfully at 16x (22 160 Ko/s)
11:30:41 #33 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 16x (22 160 Ko/s)
11:30:41 #34 Text 0 File ThreadedTransferInterface.cpp, Line 2685
11:30:41 #35 Text 0 File DVDR.cpp, Line 2699
11:30:41 #36 Text 0 File DVDR.cpp, Line 2855
11:30:41 #37 Text 0 File Cdrdrv.cpp, Line 8663
11:32:34 #38 SPTI -1135 File SCSIPassThrough.cpp, Line 290
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5C 00 00 00 00 00 00 00 0C 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 10 32 4D 03 0C 0C
Buffer x034ce400: Len xc
11:32:34 #39 SPTI -1064 File SCSIPassThrough.cpp, Line 290
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1064)
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 00 00 00 00 20 00 00 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 10 2A 00 00 0C 21 02
Buffer x05700000: Len x10000
0x18 20 4C 6A E8 B2 64 03 04 09 4D 41 14 2C 80 60
0x81 25 9E E2 81 90 0C 10 23 39 4F E3 99 BE 45 6F
0x55 AE 75 E8 23 36 2F 36 C3 9F 83 46 24 72 A6 45
11:32:34 #40 CDR -1064 File Writer.cpp, Line 302
Invalid block address
11:32:34 #41 Text 0 File ThreadedTransfer.cpp, Line 228
11:32:34 #42 Text 0 File DVDR.cpp, Line 3095
EndDAO: Last written address was 31
11:32:36 #43 Phase 133 File dlgbrnst.cpp, Line 1730
11:32:36 #44 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 16x (22 160 Ko/s)
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 05/12/2005 06:12:26 (Prassi/Veritas driver for win 2K)
File 'Drivers\IdeBusDr.sys': Ver=2.3.0.2160, 10/01/2002, size=13891 bytes, created 15/10/2002 00:00:00 (Adapter driver for rec)
File 'Drivers\IdeChnDr.sys': Ver=2.3.0.2160, 10/01/2002, size=101431 bytes, created 15/10/2002 00:00:00 (Adapter driver for rec)
