probleme gravure DVD et CD
Messagepar terminabob » 20 Avr 2007 10:56
bonjour j´ai en effet un probleme avec mon graveur DVD CD, je grave avec nero mais il detecte une erreur pendante toute les gravures, je vous met le journal d´erreur:
NT-SPTI used
Nero Version: 7.8.5.0
Internal Version: 7, 8, 5, 0
Recorder: <SONY DVD RW DW-Q120A> Version: PYS1 - HA 1 TA 2 - 7.8.5.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
CD-ROM: <QG5857Z KGC423F >Version: 1.0 - HA 1 TA 1 - 7.8.5.0
Adapter driver: <SCSI> HA 1
DiskPeripheral : SATA HDT722525D JRAID Port 4 ID 0 DMA: Off
CdRomPeripheral : SONY DVD RW DW-Q120A PYS1 JRAID Port 4 ID 1 DMA: Off
CdRomPeripheral : QG5857Z KGC423F 1.0 av4bmijd Port 5 ID 0 DMA: Off
SONY DVD RW DW-Q120A E: CDRom2
QG5857Z KGC423F F: CDRom1
Physical memory : 1022MB (1046952kB)
Free physical memory: 448MB (459496kB)
Memory in use : 56 %
20.4.2007
Graver une image DVD
11:31 Indians Ultimate Orkas #1 Text 0 File SCSIPTICommands.cpp, Line 411
11:31 Indians Ultimate Orkas #2 Text 0 File Burncd.cpp, Line 3499
11:31 Indians Ultimate Orkas #3 Text 0 File DlgWaitCD.cpp, Line 307
Last address to be written: 2076980 (461:33.05, 4056MB)
11:31 Indians Ultimate Orkas #4 Text 0 File DlgWaitCD.cpp, Line 319
11:31 Indians Ultimate Orkas #5 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: SONY DVD RW DW-Q120A, Media type: DVD+RW
Disc Manufacturer ID: MCC, Media Type ID: A01, Product revision number: 0
11:31 Indians Ultimate Orkas #6 Text 0 File DlgWaitCD.cpp, Line 493
11:31 Indians Ultimate Orkas #7 Text 0 File ThreadedTransferInterface.cpp, Line 793
0: TRM_DATA_MODE1 (2 - Mode CD-ROM 1, Joliet)
original disc pos #0 + 2076981 (2076981) = #2076981/461:33.6
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2076981 blocks [E: SONY DVD RW DW-Q120A]
11:31 Indians Ultimate Orkas #8 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: SONY DVD RW DW-Q120A] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4253657088, ISRC ""
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__
____NWA_|_RecDep__________
0 | 1 | 1 | 0x41 | 2076981 | 2076981 | 0x00
2076981 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
11:32 Indians Ultimate Orkas #9 Text 0 File SCSIPTICommands.cpp, Line 231
Error on LockVolume: Accès refusé.
11:32 Indians Ultimate Orkas #10 Text 0 File SCSIPTICommands.cpp, Line 277
SPTI - Error on DismountVolue: Accès refusé.
11:32 Indians Ultimate Orkas #11 Text 0 File SCSIPTICommands.cpp, Line 231
11:32 Indians Ultimate Orkas #12 Text 0 File Burncd.cpp, Line 4278
11:32 Indians Ultimate Orkas #13 Phase 24 File dlgbrnst.cpp, Line 1762
11:32 Indians Ultimate Orkas #14 Text 0 File Burncd.cpp, Line 4397
11:32 Indians Ultimate Orkas #15 Phase 25 File dlgbrnst.cpp, Line 1762
11:32 Indians Ultimate Orkas #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 2.4x (3 324 Ko/s)
11:32 Indians Ultimate Orkas #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
11:32 Indians Ultimate Orkas #18 Text 0 File Cdrdrv.cpp, Line 9859
Book Type: DVD-ROM (0), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Media Specific [16..63]:
00 00 00 4D 43 43 00 00 - 00 00 00 41 30 31 00 39 ...MCC.....A01.9
23 02 84 78 68 02 1D 02 - 92 78 68 02 1B 02 8A 78 #..xh....xh....x
68 02 1C 22 13 00 E0 10 - 00 00 00 00 00 00 00 00 h.."............
11:32 Indians Ultimate Orkas #19 Text 0 File DVDR.cpp, Line 6977
Drive: SONY DVD RW DW-Q120A
Book Type request [LO], rev 3: DVD-ROM
Changing the Book Type was finished successfully, return code 0, Mode 2 return code 0
11:32 Indians Ultimate Orkas #20 CDR -1207 File DVDR.cpp, Line 6356
11:32 Indians Ultimate Orkas #21 Text 0 File DVDPlusRW.cpp, Line 674
11:32 Indians Ultimate Orkas #22 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
11:33 Indians Ultimate Orkas #23 SPTI -1502 File SCSIPassThrough.cpp, Line 179
CdRom2: SCSIStatus(x02) WinError(0) NeroError(-1502)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 00 00 01 BA 40 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 00 08 03
Buffer x0e16f5c0: Len x10000
0xB9 64 B5 30 3E 3F D4 62 EA 0E 2B 33 7F EF 61 61
0x7C C2 8A 4A 64 8E 3D 78 2A 8C 0F AC 17 F1 D7 FF
0x12 94 D5 E6 43 46 0B ED 81 F5 4B 2B 92 61 DB 4C
11:33 Indians Ultimate Orkas #24 CDR -1502 File Writer.cpp, Line 303
DMA-driver error, CRC error
11:33 Indians Ultimate Orkas #25 Text 0 File DVDPlusRW.cpp, Line 934
EndDAO: Last written address 113216
11:33 Indians Ultimate Orkas #26 Text 0 File DVDR.cpp, Line 6977
Book Type request [LO], rev 3: DVD+RW
11:33 Indians Ultimate Orkas #27 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 2.4x (3 324 Ko/s)
11:33 Indians Ultimate Orkas #28 Text 0 File SCSIPTICommands.cpp, Line 277
11:33 Indians Ultimate Orkas #29 Text 0 File Cdrdrv.cpp, Line 11214
11:33 Indians Ultimate Orkas #30 Text 0 File SCSIPTICommands.cpp, Line 411
Voila j´avais déja ce probleme auparavant mais j´ai formater et j´ai toujours ce probleme. MErci d´avance , au revoir
terminabob
Messagepar aldébaran » 20 Avr 2007 22:55
Change d'OS ;)
aldébaran
Messagepar Scaramanga » 21 Avr 2007 6:11
Code: Tout sélectionner
Active le mode de transfert DMA :
Messagepar terminabob » 21 Avr 2007 16:58
http://img405.imageshack.us/my.php?imag ... 216lj7.jpg
voila ce qui me met, lorsque je regarde les proprieté des peripherique IDE
terminabob
Messagepar Scaramanga » 21 Avr 2007 17:23
Supprime le port ide incrimioné comme indiqué danss la procédure linkée plus haut.
