megalomando a écrit:OPTODISCK001 Gold DVD-R is horrible, the beautiful Purple change to the dye is amazing. Why I can see the writing from the top bleeding through.
OPTODISCR004 has gone bad in a year
PRODISC R03 had failed within the year
So far only one TYG02 has shown to be bad
OPTODISC,OR was recorded 8 months and now is unreadable.
I can't believe all these backups are ruined.
I just went through 125 DVD-R backups and I have over 20 that have failed and are unreadable.
I've tried them in a different computer & drive & the same errors are there.
All these were stored in individual Zip Lock Baggies and kept in a box away from light.
I'm really concerned and don't know what to get for long term.
The TYG02 have a good following here, I'm going to get several hundred and back up my backups while they're still readable.
Losing so many in such a short time is not comforting
wilhelm a écrit:In order to have a disc that lasts a long time, there are several critical criteria that must be met:
1) a good quality recording.
This is dependent on the compatibility of the drive and medium and on the quality of both. Mentioning MID codes is insufficient information if the code is not included in the drive's firmware memory.
2) a stable dye, reflector, and bonding agent.
Although some have dissed Prodisc's media or Fuji media,
they use Fuji's Oxonol dye.
There is a growing body of evidence to suggest this dye is more environmentally stable than azo-cyanine dyes.
Gold is not a good reflector for DVDs. It is fine for CD-Rs, but the reflectivity is lacking as far as DVD specs go.
3) proper storage.
This includes handling as well as absence of light and heat/humidity. Humidity is particularly harmful for DVDs because of the sandwich construction.
Environmental tests suggest that a well recorded DVD will last 40 years before the increase in errors overcomes error correction capabilities. CD-Rs will last 120 years under the identical conditions.
Traduit par google a écrit: Afin d'avoir un disque qui dure un à long terme, il y a plusieurs critères critiques qui doivent être rencontrés :
1) un enregistrement de bonne qualité.
Ce dépend de la compatibilité de la commande et du milieu et de la qualité de tous les deux. La mention de MI codes est l'information insuffisante si le code n'est pas inclus dans la mémoire des progiciels d'entraînement.
2) un colorant, un réflecteur, et un agent stables de liaison.
Bien que certains aient dissed les médias de Prodisc ou les médias de Fuji,
ils emploient le colorant d'Oxonol de Fuji.
Il y a un corps croissant de l'évidence à suggérer que ce colorant soit plus ambiant écurie que les colorants azo-cyanine.
L'or n'est pas un bon réflecteur pour DVDs. Il est très bien pour le Cd-Rs, mais la réflectivité manque dans la mesure où Spéc. de DVD disparaissent.
) stockage 3 approprié.
Ceci inclut la manipulation aussi bien que l'absence de la lumière et de la chaleur/d'humidité. L'humidité est particulièrement nocive pour DVDs en raison de la construction stratifiée.
Les essais environnementaux suggèrent qu'un DVD bien enregistré dure 40 ans avant que l'augmentation des erreurs surmonte des possibilités de correction d'erreurs. Le Cd-Rs durera 120 ans dans les conditions identiques.
google a écrit: . . . ce colorant soit plus ambiant écurie que les colorants azo-cyanine
franz99 a écrit:Vous en avez en réserve d'autres blagues du même genre ?
Vieux motard a écrit:franz99 a écrit:Vous en avez en réserve d'autres blagues du même genre ?
En s'y mettant à plusieurs, on doit pouvoir en avoir plein d'autres![]()
Donc, si je comprends bien, les Riteck de Fuji sont meilleurs que les Tayo Yuden et les Verbatim de fabrication Mitsubishi Chemical...
... les Riteck de Fuji sont meilleurs que les Tayo Yuden et les Verbatim dont le colorant est de fabrication Mitsubishi Chemical...
--> dans ce cas c'est écrit sur l'emballage !
dakhaas a écrit:Some disc's using oxonol dye which are easilly found on the market.
FUJIFILM02 (made by Prodisc, Fuji Germany and FUJI japan if I'm right)
FUJIFILM03 (made by MBIL, Ritek,Prodisc,Fuji Germany(rare))
Ritek
RitekM02 (Both)
ritekF16
RitekF1
Prodisc
ProdiscF01
ProdiscF02
ProdiscR05
CMC/FUJIFILM (germany)
Philipsc16
MBIL
MBI03RG40
Assuming that :
1. The burns are good (good burner, reasonable burning speed like @12X max for @16X rated media)
2. The discs are in good condition before the burn (no excessive dust, no scratches, no defects)
3. The discs are stored in good conditions (humidity <65%, temp < 30°C, no daylight, no horizontal storage, no free standing in paper or plastic sleeves, no paper labels)
4. The disc are handled carefully
5. The batch of blanks is not a problematic one
6. The discs are genuine (no fake mediacode)
... the following MIDS are then fully reliable *in terms of stability*
according to my personal experience and what I gather on this board and others:
TDK TTG02 (out of market) /
MCC02 RG20 (disappearing) /
MCC03 RG20 / MCC 003 (disappearing) /
MCC 004 /
YUDEN000T02 (disappearing) /
TYG01 (out of market) /
TYG03 /
CMC MAG AE1 (disappearing) /
CMC MAG E01 (disappearing) /
CMC MAG AM3 /
DAXON AZ3 /
RITEK M02 (out of market) /
RITEK F1 /
SONY D21 /
YUDEN000T03 /
RICOHJPNR01 (out of market) /
RICOHJPNR02 (disappearing) /
RICOHJPNR03
Then, you have to understand that except for some proven unstable MIDs like Ritek G04 and G05,
the 6 points above are MORE important, in terms of longevity, than the disc model used
Sample# / Disc Type / MID Code / Stamper Code / Serial Number
A1 / Taiyo Yuden 16x DVD+R / YUDEN000T03 / TH001333 0101 / 5E525A506606PH
B1 / Taiyo Yuden 16x DVD-R / TYG03 / GH000073 0116 / 1D524A105624GH
C2 / Taiyo Yuden 8x DVD+R / YUDEN000T02 / TG001159 0918 / FH522A103189PG
D1 / Taiyo Yuden 8x DVD-R / TYG02 / GG000110 0813 / LE526A101198GG
E2 / Delkin Gold Scratch Armour 4x DVD-R / MCC03RG20 / ZD4076-DVR-J47C1 / 6097D7107372 4 G
F1 / Sony 16x DVD+R / SONYD21 / DRP5GG0001 H / SMM10412L10825000030247 45W4
G1 / Sony 16x DVD-R / SONY16D1 / DRM5GG0001 2E / SMM10506F13585000010302 45V6
i1 / Verbatim 16x DVD+R / MCC004 / ZD2632-DVR-T47D / PAPA22II28032680 4
J1 / Verbatim 16x DVD-R / MCC03RG20 / ZD3177-DVR-J47C1 / MAP633JG25065865 3
K1 / Nexxtech 16x DVD+R / CMCMAGM01 / CPDR47G-CDMWP01-024 0110 / PDP 688JC05045658 6
L1 / Nexxtech 16x DVD-R / MCC03RG20 / ZD3177-DVR-J47C1 / MAP642JC18055978 6
M1 / Acro Circle 16x DVD+R / OPTODISCR16 / OTC+R86057N0 R16 0202 +R 1~16X / BR05012606-PP011D4502
N1 / Acro Circle 16x DVD-R / OPTODISCR016 / OTC-R86136WP / LR27-16E0412160356
O1 / Moser Baer 16x DVD-R / MBI03RG40 / MBI-F-16X 0003 / 5356 547 -R E E 13030
P1 / BenQ 16x DVD+R / DAXONAZ3 / AMC16DPR47DH3101 / MF01021042357 3 A4P120
Q1 / RiData 16x DVD-R / RITEKF1 / DR5F6O-00065 / H4-08F60504305140A22
R1 / RiData 8x DVD-R / RITEKG05 / DR5A03-00442 / J4-07A03509222307E14
S1 / TDK 16x DVD+R / TDK003 / DVD+R 4824B2 / C05B271142dA435
T1 / Maxell 16x DVD-R / PRODISCF02 / PF02-2607-5135 / 5334F0226-00875E19
U1 / Philips 16x DVD+R / INFOMER30 / DVD+R3 05071301 / 01EL2702 34224
V1 / Emtec Gold 4x DVD+R / MPOMEDIA080 / DVD+R 4.7G 11R4 106470 / 2 3 0412021144- 5312447
W1 / TDK 16x DVD-R / TTH02 / DVD-R 5420B2 1004 / MOP6A9J126175789 D2
X1 / MAM-A Gold 16x DVD-R / MBI01RG40 / 200150 DVDMINUSR 16X / 6205D5111787 1 G
Y1 / Maxell BQ 8x DVD-R / MXLRG03 / N/A / M5HJ095B
Z1 / Maxell 16x DVD+R / RICOHJPNR03-004 /
D0127C20519R 50127-C2 / K5C02885E601RF5122705A03695/
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 3 invités
