par daouid » 25 Fév 2008 18:56
Resalut
voici ce que tu m'as demandé:
[code]David RT
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero Version: 6.6.0.18
Internal Version: 6, 6, 0, 18e
(Nero Express)
Recorder: <PIONEER DVD RW DVR-109> Version: 1.57 - HA 0 TA 0 - 6.6.0.18
Adapter driver: <atapi> HA 0
Drive buffer : 2000kB
CD-ROM: <PIONEER DVD RW DVR-109 >Version: 1.57 - HA 0 TA 0 - 6.6.0.18
CdRomPeripheral : PIONEER DVD RW DVR-109 atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST3200822AS atapi Port 1 ID 0 DMA: On
DiskPeripheral : ST3200822AS atapi Port 2 ID 0 DMA: On
PIONEER DVD RW DVR-109 G: CDRom0
Physical memory : 2047MB (2096620kB)
Free physical memory: 1506MB (1542948kB)
Memory in use : 26
26.1.2008
Compilation UDF/ISO
20:05:33 #1 Phase 112 File dlgbrnst.cpp, Line 1832
20:05:33 #2 Phase 114 File dlgbrnst.cpp, Line 1832
20:05:33 #3 Text 0 File Isodoc.cpp, Line 6359
UDF document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
Character set : ISO 9660
Joliet :FALSE
20:05:33 #4 Phase 111 File dlgbrnst.cpp, Line 1832
DVD-Video files sorted
20:05:33 #5 Text 0 File Reader.cpp, Line 127
20:05:33 #6 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD RW DVR-109 running
20:05:33 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
20:05:34 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
20:05:34 #9 Text 0 File Burncd.cpp, Line 3233
20:05:40 #10 Text 0 File DlgWaitCD.cpp, Line 270
Last address to be written: 2286111 (508:01.36, 4465MB)
20:05:40 #11 Text 0 File DlgWaitCD.cpp, Line 282
20:05:40 #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: PIONEER DVD RW DVR-109, Media type: DVD+RW
Disc Manufacturer ID: MKM, Media Type ID: A02, Product revision number: 0
20:05:40 #13 Text 0 File DlgWaitCD.cpp, Line 448
(Medium in drive: DVD+RW. Medium required by compilation: DVD+R/RW; DVD-R/RW; DVD-R DL; DVD+R DL.)
This disc is not empty.
Accessing disc...
20:05:40 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
0: TRM_DATA_MODE1 ()
original disc pos #0 + 2286112 (2286112) = #2286112/508:1.37
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286112 blocks [PIONEER DVD RW DVR-109]
20:05:40 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [PIONEER DVD RW DVR-109] for write in CUE-sheet-DAO
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681957376, ISRC ""
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286112 | lead-out | 1 | 0x41 | 0x00
20:05:41 #16 Phase 24 File dlgbrnst.cpp, Line 1832
20:05:41 #17 Text 0 File Burncd.cpp, Line 4122
20:05:41 #18 Phase 25 File dlgbrnst.cpp, Line 1832
20:05:41 #19 Phase 36 File dlgbrnst.cpp, Line 1832
20:05:41 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2661
20:05:41 #21 Text 0 File Cdrdrv.cpp, Line 8892
Book Type: DVD+RW (9), Part Version: 1.1x (2)
End Physical Sector Number of Data Area: 23D1EF h
Disc Manufacturer ID: MKM.....
Media type ID: A02
Media Specific [16..63]:
00 00 01 4D 4B 4D 00 00 - 00 00 00 41 30 32 00 39 ...MKM.....A02.9
23 00 94 79 64 02 20 00 - 9C 7A 6C 02 20 00 9A 7B #..yd....zl....{
68 02 20 12 12 10 E0 00 - F0 00 00 00 00 00 00 00 h...............
20:05:41 #22 Text 0 File DVDPlusRW.cpp, Line 659
20:05:43 #23 Text 0 File Cdrdrv.cpp, Line 1288
20:05:43.845 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:05:52 #24 Text 0 File Cdrdrv.cpp, Line 1288
20:05:52.876 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:06:08 #25 Text 0 File Cdrdrv.cpp, Line 1288
20:06:08.611 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:19:56 #26 Text 0 File WriterStatus.cpp, Line 116
<PIONEER DVD RW DVR-109 > start writing Lead-Out at LBA 2286112 (22E220h), lenght 0 blocks
20:19:57 #27 Text 0 File ThreadedTransfer.cpp, Line 228
20:19:59 #28 Text 0 File DVDPlusRW.cpp, Line 883
Media-Format will be stopped after burning
20:19:59 #29 Phase 127 File dlgbrnst.cpp, Line 1832
20:20:25 #30 Phase 37 File dlgbrnst.cpp, Line 1832
Burn process completed successfully at 4x (5 540 Ko/s)
File 'Drivers\PXHELP20.SYS': Ver=2.03.01a, size=20368 bytes, created 28/07/2005 17:55:01 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 22:59:44 (Adapter driver for rec)
David RT
1a22-030k-0350-1550-5697-0951
Free physical memory: 1551MB (1588556kB)
Memory in use : 24
26.1.2008
Compilation UDF/ISO
20:45:50 #1 Phase 112 File dlgbrnst.cpp, Line 1832
20:45:50 #2 Phase 114 File dlgbrnst.cpp, Line 1832
20:45:50 #3 Text 0 File Isodoc.cpp, Line 6359
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet :FALSE
20:45:51 #4 Phase 111 File dlgbrnst.cpp, Line 1832
20:45:51 #5 Text 0 File Reader.cpp, Line 127
20:45:51 #6 Text 0 File Writer.cpp, Line 122
20:45:51 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
20:45:51 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
20:45:51 #9 Text 0 File Burncd.cpp, Line 3233
20:45:56 #10 Text 0 File DlgWaitCD.cpp, Line 270
20:45:56 #11 Text 0 File DlgWaitCD.cpp, Line 282
20:45:56 #12 Text 0 File DlgWaitCD.cpp, Line 2483
20:45:56 #13 Text 0 File DlgWaitCD.cpp, Line 448
Accessing disc...
20:45:57 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
20:45:57 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
20:45:57 #16 Phase 24 File dlgbrnst.cpp, Line 1832
20:45:57 #17 Text 0 File Burncd.cpp, Line 4122
20:45:57 #18 Phase 25 File dlgbrnst.cpp, Line 1832
20:45:57 #19 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 2,4x (3 324 Ko/s)
20:45:58 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2661
20:45:58 #21 Text 0 File Cdrdrv.cpp, Line 8892
End Physical Sector Number of Data Area: 25E21F h
Media type ID: A02
20:45:58 #22 Text 0 File DVDPlusRW.cpp, Line 659
20:45:59 #23 Text 0 File Cdrdrv.cpp, Line 1288
20:45:59.986 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:46:08 #24 Text 0 File Cdrdrv.cpp, Line 1288
20:46:08.579 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
21:09:35 #25 Text 0 File WriterStatus.cpp, Line 116
21:09:35 #26 Text 0 File ThreadedTransfer.cpp, Line 228
21:09:37 #27 Text 0 File DVDPlusRW.cpp, Line 883
21:09:37 #28 Phase 127 File dlgbrnst.cpp, Line 1832
21:10:14 #29 Phase 37 File dlgbrnst.cpp, Line 1832
Burn process completed successfully at 2,4x (3 324 Ko/s)
David RT
Free physical memory: 1471MB (1506492kB)
Memory in use : 28
4.2.2008
Compilation UDF/ISO
21:28:54 #1 Phase 112 File dlgbrnst.cpp, Line 1832
21:28:54 #2 Phase 114 File dlgbrnst.cpp, Line 1832
21:28:54 #3 Text 0 File Isodoc.cpp, Line 6359
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet :FALSE
21:28:54 #4 Phase 111 File dlgbrnst.cpp, Line 1832
21:28:54 #5 Text 0 File Reader.cpp, Line 127
21:28:54 #6 Text 0 File Writer.cpp, Line 122
21:28:54 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
21:28:54 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
21:28:54 #9 Text 0 File Burncd.cpp, Line 3233
21:29:00 #10 Text 0 File DlgWaitCD.cpp, Line 270
21:29:00 #11 Text 0 File DlgWaitCD.cpp, Line 282
21:29:00 #12 Text 0 File DlgWaitCD.cpp, Line 2483
21:29:00 #13 Text 0 File DlgWaitCD.cpp, Line 448
Accessing disc...
21:29:00 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
21:29:00 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
21:29:01 #16 Phase 24 File dlgbrnst.cpp, Line 1832
21:29:01 #17 Text 0 File Burncd.cpp, Line 4122
21:29:01 #18 Phase 25 File dlgbrnst.cpp, Line 1832
21:29:01 #19 Phase 36 File dlgbrnst.cpp, Line 1832
21:29:01 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2661
21:29:01 #21 Text 0 File Cdrdrv.cpp, Line 8892
End Physical Sector Number of Data Area: 25E20F h
Media type ID: A02
21:29:01 #22 Text 0 File DVDPlusRW.cpp, Line 659
21:29:03 #23 Text 0 File Cdrdrv.cpp, Line 1288
21:29:03.765 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
21:29:12 #24 Text 0 File Cdrdrv.cpp, Line 1288
21:29:12.359 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
21:52:39 #25 Text 0 File WriterStatus.cpp, Line 116
21:52:39 #26 Text 0 File ThreadedTransfer.cpp, Line 228
21:52:41 #27 Text 0 File DVDPlusRW.cpp, Line 883
21:52:41 #28 Phase 127 File dlgbrnst.cpp, Line 1832
21:53:19 #29 Phase 37 File dlgbrnst.cpp, Line 1832
David RT
Free physical memory: 1632MB (1671936kB)
Memory in use : 20
8.2.2008
Compilation UDF/ISO
19:49:57 #1 Phase 112 File dlgbrnst.cpp, Line 1832
19:49:57 #2 DVDREALLOC -21 File DVDVideoCompilation.cpp, Line 1189
Required file 'VTS_01_0.VOB' is not present
19:49:57 #3 Phase 115 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation failed
19:49:58 #4 Phase 132 File dlgbrnst.cpp, Line 1832
DVD-Video files compliance ignored
19:49:58 #5 Text 0 File Isodoc.cpp, Line 6359
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet :FALSE
19:49:58 #6 Phase 111 File dlgbrnst.cpp, Line 1832
19:49:58 #7 Text 0 File Reader.cpp, Line 127
19:49:58 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
19:49:58 #9 ISO9660GEN -11 File geniso.cpp, Line 3309
19:49:58 #10 Text 0 File Burncd.cpp, Line 3233
19:50:03 #11 Text 0 File DlgWaitCD.cpp, Line 270
Last address to be written: 2285647 (507:55.22, 4464MB)
19:50:03 #12 Text 0 File DlgWaitCD.cpp, Line 282
19:50:03 #13 Text 0 File DlgWaitCD.cpp, Line 2483
19:50:03 #14 Text 0 File DlgWaitCD.cpp, Line 448
Accessing disc...
19:50:03 #15 Text 0 File ThreadedTransferInterface.cpp, Line 838
original disc pos #0 + 2285648 (2285648) = #2285648/507:55.23
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2285648 blocks [PIONEER DVD RW DVR-109]
19:50:03 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1051
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681007104, ISRC ""
2285648 | lead-out | 1 | 0x41 | 0x00
19:50:04 #17 Phase 24 File dlgbrnst.cpp, Line 1832
19:50:04 #18 Text 0 File Burncd.cpp, Line 4122
19:50:04 #19 Phase 25 File dlgbrnst.cpp, Line 1832
19:50:17 #20 Text 0 File Burncd.cpp, Line 1689
User aborts on ExceptionIfFatalError
David RT
Free physical memory: 1647MB (1687452kB)
Memory in use : 19
8.2.2008
Compilation UDF/ISO
19:52:28 #1 Phase 112 File dlgbrnst.cpp, Line 1832
19:52:28 #2 DVDREALLOC -21 File DVDVideoCompilation.cpp, Line 1189
19:52:28 #3 Phase 115 File dlgbrnst.cpp, Line 1832
David RT
Free physical memory: 1559MB (1597204kB)
Memory in use : 23
8.2.2008
Compilation UDF/ISO
19:55:26 #1 Phase 112 File dlgbrnst.cpp, Line 1832
19:55:26 #2 DVDREALLOC -21 File DVDVideoCompilation.cpp, Line 1189
19:55:26 #3 Phase 115 File dlgbrnst.cpp, Line 1832
19:55:33 #4 Phase 132 File dlgbrnst.cpp, Line 1832
19:55:33 #5 Text 0 File Isodoc.cpp, Line 6359
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet :FALSE
Write ISO9660 ;1 file extensions : FALSE
19:55:33 #6 Phase 111 File dlgbrnst.cpp, Line 1832
19:55:34 #7 Text 0 File Reader.cpp, Line 127
19:55:34 #8 Text 0 File Writer.cpp, Line 122
19:55:34 #9 ISO9660GEN -11 File geniso.cpp, Line 3309
19:55:34 #10 ISO9660GEN -11 File geniso.cpp, Line 3309
19:55:34 #11 Text 0 File Burncd.cpp, Line 3233
19:55:40 #12 Text 0 File DlgWaitCD.cpp, Line 270
19:55:40 #13 Text 0 File DlgWaitCD.cpp, Line 282
19:55:40 #14 Text 0 File DlgWaitCD.cpp, Line 2483
19:55:40 #15 Text 0 File DlgWaitCD.cpp, Line 448
Accessing disc...
19:55:40 #16 Text 0 File ThreadedTransferInterface.cpp, Line 838
19:55:40 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1051
19:55:41 #18 Phase 24 File dlgbrnst.cpp, Line 1832
19:55:41 #19 Text 0 File Burncd.cpp, Line 4122
19:55:41 #20 Phase 25 File dlgbrnst.cpp, Line 1832
19:55:51 #21 Phase 36 File dlgbrnst.cpp, Line 1832
19:55:52 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2661
19:55:52 #23 Text 0 File Cdrdrv.cpp, Line 8892
Media type ID: A02
19:55:52 #24 Text 0 File DVDPlusRW.cpp, Line 659
19:55:53 #25 Text 0 File Cdrdrv.cpp, Line 1288
19:55:53.625 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
19:56:02 #26 Text 0 File Cdrdrv.cpp, Line 1288
19:56:02.265 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:19:29 #27 Text 0 File WriterStatus.cpp, Line 116
<PIONEER DVD RW DVR-109 > start writing Lead-Out at LBA 2285648 (22E050h), lenght 0 blocks
20:19:29 #28 Text 0 File ThreadedTransfer.cpp, Line 228
20:19:31 #29 Phase 161 File dlgbrnst.cpp, Line 1832
Burn process completed successfully with warnings
David RT
Free physical memory: 1530MB (1567480kB)
Memory in use : 25
22.2.2008
Compilation UDF/ISO
19:26:56 #1 Phase 112 File dlgbrnst.cpp, Line 1832
19:26:56 #2 Phase 114 File dlgbrnst.cpp, Line 1832
19:26:56 #3 Text 0 File Isodoc.cpp, Line 6359
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet :FALSE
19:26:56 #4 Phase 111 File dlgbrnst.cpp, Line 1832
19:26:56 #5 Text 0 File Reader.cpp, Line 127
19:26:56 #6 Text 0 File Writer.cpp, Line 122
19:26:56 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
19:26:56 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
19:26:56 #9 Text 0 File Burncd.cpp, Line 3233
19:27:02 #10 Text 0 File DlgWaitCD.cpp, Line 270
Last address to be written: 2014655 (447:42.05, 3934MB)
19:27:02 #11 Text 0 File DlgWaitCD.cpp, Line 282
19:27:02 #12 Text 0 File DlgWaitCD.cpp, Line 2483
19:27:02 #13 Text 0 File DlgWaitCD.cpp, Line 448
Accessing disc...
19:27:02 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
original disc pos #0 + 2014656 (2014656) = #2014656/447:42.6
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2014656 blocks [PIONEER DVD RW DVR-109]
19:27:02 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4126015488, ISRC ""
2014656 | lead-out | 1 | 0x41 | 0x00
19:27:04 #16 Phase 24 File dlgbrnst.cpp, Line 1832
19:27:05 #17 Text 0 File Burncd.cpp, Line 4122
19:27:05 #18 Phase 25 File dlgbrnst.cpp, Line 1832
19:27:05 #19 Phase 36 File dlgbrnst.cpp, Line 1832
19:27:05 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2661
19:27:05 #21 Text 0 File Cdrdrv.cpp, Line 8892
Media type ID: A02
19:27:05 #22 Text 0 File DVDPlusRW.cpp, Line 659
19:27:07 #23 Text 0 File Cdrdrv.cpp, Line 1288
19:27:07.062 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
19:27:15 #24 Text 0 File Cdrdrv.cpp, Line 1288
19:27:15.593 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
19:47:55 #25 Text 0 File WriterStatus.cpp, Line 116
<PIONEER DVD RW DVR-109 > start writing Lead-Out at LBA 2014656 (1EBDC0h), lenght 0 blocks
19:47:55 #26 Text 0 File ThreadedTransfer.cpp, Line 228
19:47:57 #27 Phase 37 File dlgbrnst.cpp, Line 1832
David RT
Free physical memory: 1557MB (1594396kB)
Memory in use : 23
22.2.2008
Compilation UDF/ISO
20:15:38 #1 Phase 112 File dlgbrnst.cpp, Line 1832
20:15:38 #2 Phase 114 File dlgbrnst.cpp, Line 1832
20:15:38 #3 Text 0 File Isodoc.cpp, Line 6359
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet :FALSE
20:15:38 #4 Phase 111 File dlgbrnst.cpp, Line 1832
20:15:38 #5 Text 0 File Reader.cpp, Line 127
20:15:38 #6 Text 0 File Writer.cpp, Line 122
20:15:38 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
20:15:38 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
20:15:38 #9 Text 0 File Burncd.cpp, Line 3233
20:15:38 #10 Text 0 File DlgWaitCD.cpp, Line 270
Last address to be written: 2286127 (508:01.52, 4465MB)
20:15:38 #11 Text 0 File DlgWaitCD.cpp, Line 282
20:15:38 #12 Text 0 File DlgWaitCD.cpp, Line 2483
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
20:15:38 #13 Text 0 File DlgWaitCD.cpp, Line 448
20:15:38 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [PIONEER DVD RW DVR-109]
20:15:38 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
2286128 | lead-out | 1 | 0x41 | 0x00
20:15:41 #16 Phase 24 File dlgbrnst.cpp, Line 1832
20:15:41 #17 Text 0 File Burncd.cpp, Line 4122
20:15:41 #18 Phase 25 File dlgbrnst.cpp, Line 1832
20:15:41 #19 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11 080 Ko/s)
20:15:42 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2661
20:15:42 #21 Text 0 File Cdrdrv.cpp, Line 8892
Media type ID: 004
00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._......
20:15:42 #22 Text 0 File DVDPlusRW.cpp, Line 659
20:15:44 #23 Text 0 File Cdrdrv.cpp, Line 1288
20:15:44.296 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:06 #24 Text 0 File Cdrdrv.cpp, Line 1288
20:16:06.609 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:06 #25 Text 0 File Cdrdrv.cpp, Line 1288
20:16:06.656 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:06 #26 Text 0 File Cdrdrv.cpp, Line 1288
20:16:06.703 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:06 #27 Text 0 File Cdrdrv.cpp, Line 1288
20:16:06.750 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:06 #28 Text 0 File Cdrdrv.cpp, Line 1288
20:16:06.796 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:06 #29 Text 0 File Cdrdrv.cpp, Line 1288
20:16:06.843 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:06 #30 Text 0 File Cdrdrv.cpp, Line 1288
20:16:06.984 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:07 #31 Text 0 File Cdrdrv.cpp, Line 1288
20:16:07.031 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:07 #32 Text 0 File Cdrdrv.cpp, Line 1288
20:16:07.078 - PIONEER DVD RW DVR-109\H0 T0 : Queue again later
20:16:07 #33 Text 0 File Cdrdrv.cpp, Line 1288
20:16:07.125 - PIONEER DVD RW DVR-109\H0
Modifié en dernier par
daouid le 06 Mar 2008 12:18, modifié 2 fois.
